Originally Posted by tcatl
I have a 97 4runner. The problem is when i try to crank the car, it acts as if its gong to then i hear a clicking noise. It cranks fine when I jump start it. After jump starting it, i let it charge for a while and even have drove around for 30 mins or so.
After letting it charge. i would turn it off for about 5-10 mins and it would crank back up but if i let it sit longer than that, it will not start again. I have had some corrosion on the battery connections and did the coca cola thing. it came off fine and still same thing.
Im very low on money so im just looking to narrow down the possible solution b4 buying a new battery. Is it the battery or could it be something else?
Originally Posted by delz05
Sounds like the battery has drained down. ... have the alternator output checked as well, just in case it has become faulty (should be putting out aprox 14.5v).
Good luck!
Cleaned your battery connectors really thoroughly?
if you did, yep, sounds like weak battery that does not charge well anymore, or alternator that does not charge the battery anymore.
When you try to start and it sounds like it will, your starter is trying to draw hundreds of amps from your battery, This drops the battery voltage so low that its not even enough to keep relays energized. The clicking sound is from your relays DE-energizing.
