Sup Guys,
I just got back from the dealer. They said it was most likely the tires. It was either starting to go bad and need new ones or I need an alignment. They said there was nothing mechanicallyl wrong with it ( I hope they're right).
As far as the u-joints are concerned, they said the 01 Sport does not use a U joint but uses a "spider" joint
I do have a 2WD btw..
Anyways, I did mention about the motor mount and they said that I would definitely feel it even though it was under 60
I know my tires are almost gone... about 40-50% tread left. I might just switch them with a buddy of mines and see if it's the cause....
Thank you very much for all your replies and I will definitely let you guys know wassup...
Any other thoughts would definitely be appreciated!!!!
