Old 07-01-2013, 01:44 AM #1
zak897's Avatar
zak897 zak897 is offline
zak897 is on a distinguished road
zak897's Avatar
Unhappy 1st gen transmission problems
So I first noticed the problem whenever I was reversing. There was some sort of clanking noise. Now whenever i shift into reverse I have to hold the stick in place. So is my transmission finally giving out or is there something else?
Thanks in advance for any help guys
zak897 is offline   Reply With QuoteReply With Quote
Old 07-09-2013, 11:34 PM #2
Rando71 Rando71 is offline
Rando71 is on a distinguished road
If you have to hold the shifter in reverse to keep it from spitting it out, most likely a syncro problem, the teeth on the slider as well as the gear (rev) become worn and rounded. This is common from going reverse to 1st or vice versa in a rocking action (stuck in mud etc..). What year are we dealing with? Some were synchronized, some weren't. Some had brackets for the idler that bolted to mid plate that could have fallen out, or arm itself cracked. Been long time since rebuilding one. Is it same as supra??
Rando71 is offline   Reply With QuoteReply With Quote
Old 07-11-2013, 07:16 PM #3
txclimber's Avatar
txclimber txclimber is offline
txclimber is on a distinguished road
txclimber's Avatar
My 1st gen had a similar problem, except it kept jumping out of 3rd. I "fixed" it by holding it there with my hand until I was ready for 4th.
Don't do what I did. One day it did stay in 3rd, but it was STUCK there. I couldn't get it to budge. Even bent the shifter trying to pull it out. I was able to limp it home, but if that happens to you in reverse it would be a whole different story.
Ended up slapping a used $100 tranny in there and it's gone strong the last 20k with no issues.
BTW The messed up one was a Marlin Crawler Tranny with only 15k miles. So, the old Junk Yard one has treated me better. Hahaha.
2007 4runner SE V8 4WD: OME BP-51, SPC, Scion IM 2016+
2005 4runner SR5 V8 4WD: ICON Stage 1, Total Chaos UCA, Scion T1819 (SOLD )
1986 4Runner 4WD 22-RE: Full Rebuild, LCE Header, Custom Head, Supra AFM
txclimber is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 04:11 PM #4
huffman10x huffman10x is offline
huffman10x is on a distinguished road
transmission install issues
hey guys,
Sorry to jump on an old thread but i don't have the minimum reply count yet and need to get my 4runner back on the road. So i bought the truck missing the transmission and am putting a junkyard trans into it. Everything bolted up fine, and the motor spun just fine when i checked it prior. I got the transmission in and went to put the flex plate bolts in, but i cant get it to turn anymore. Any ideas on what the issue is? i know it sat for a while and i did drain the old fluid before installing it so there is a chance the torque converter is dry, but would that be enough to stop it from spinning? I'm a fairly big guy and i couldn't get it to budge with a breaker bar.
huffman10x is offline   Reply With QuoteReply With Quote
1st gen , maintenance , problem , reverse , transmission
Transmission problems knothead 3rd gen T4Rs 7 03-31-2013 11:41 PM
Transmission problems? Gecko123 4th Gen T4Rs 26 09-08-2012 02:56 PM
I think im having transmission problems benbec01 3rd gen T4Rs 7 08-13-2011 10:13 PM
98 transmission problems Bentspoke 3rd gen T4Rs 12 01-05-2011 04:19 PM
Transmission Problems? Xandarin 3rd gen T4Rs 1 03-15-2006 09:11 AM
