Thread Tools Rating: Thread Rating: 11 votes, 4.91 average. Display Modes
Old 04-09-2013, 04:31 PM #46
andy2008's Avatar
andy2008 andy2008 is offline
andy2008 is on a distinguished road
andy2008's Avatar
Any suggestions?
Hey guys I just noticed today that mine wasn't working from switch on dash? I can put window up and down with the key or down with keyless entry my rear wiper ,fluid and defrost work just not the switch on dash. Has anyone had that switch go bad I can't find a blown fuse or the one labeled just for that rear window switch? Any tips greatly appreciated! sorry meant to mention its on the 08
COME AND TAKE IT!
andy2008 is offline   Reply With QuoteReply With Quote
Old 04-12-2013, 02:59 PM #47
YYZ's Avatar
YYZ YYZ is offline
Real Name: Ash
YYZ is on a distinguished road
YYZ YYZ is offline
YYZ's Avatar
Real Name: Ash
Originally Posted by digphisher View Post
For the past two weeks, my rear window wouldn't go down, the rear defroster wouldn't go on, and the rear wiper and fluid wouldn't work. I check all of the fuses but everything looked ok. I took it to the dealership today, and they told me to try two things:
1. Make sure your rear wiper is in the proper neutral position.
2. Try putting your window up.
The dealer told me that if the window is almost up, but not quite all of the way that it won't go down. If it's not all the way up, the defroster won't work and the wiper won't work because the truck thinks that the window is down.
I went and played with the positioning of the wiper, and then used the button to make sure the window was all the way up (which it seemed to be), and now they all work!
Just wanted to let y'all know how to fix this if you ever have this problem.
Awesome! Thanks a million friend. I had the same problem this morning but now it is working fine. I just buttoned down the rear hatch window once and then buttoned it up and everything is working fine.
Ash
YYZ is offline   Reply With QuoteReply With Quote
Old 04-13-2013, 07:58 PM #48
andy2008's Avatar
andy2008's Avatar
So has no one had just the switch go bad?
COME AND TAKE IT!
Old 06-06-2013, 02:21 PM #49
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
i experienced this too a few days ago when my wife told me. it didn't work, everything, wiping and water squirting. i just pressed the down read window and all the way up and it worked afterwards. that's really amazing what small things can do. that's well thought of. imagine when your read window is down and you accidentaly squirt a wiper fluid inside and wipe. thank you too!
radlynx is offline   Reply With QuoteReply With Quote
Old 08-19-2013, 07:58 PM #50
Kleyver's Avatar
Kleyver Kleyver is offline
Kleyver is on a distinguished road
Kleyver's Avatar
Greetings from Venezuela. I just bought a 2007 4runner and HAD this problem. Thanks to the guys who take the time to share their experiences on line, this is no longer an issue in my ride.
For some reason the dashboard button was not working, at all. Previous owner changed the battery so I'm assuming that triggered the whole thing. So a few minutes ago, after reading this post, I tried several times with the ignition switch and rear window switch until it finally worked. Up and down all the way and EUREKA!! hahaha... washer wiper and water are working great.
Thanks again.
First 4Runner and happier imposible.
Kleyver is offline   Reply With QuoteReply With Quote
Old 09-10-2013, 09:19 AM #51
02T4RVA's Avatar
02T4RVA 02T4RVA is offline
Real Name: Bryan
02T4RVA is on a distinguished road
02T4RVA's Avatar
Real Name: Bryan
Hi everyone.... any additional thoughts?
Rear Defrost: Works
Rear Wiper Fluid: Works
Rear Window Control from Dash: Does not work
Rear Wiper Control: Does not work
Turning the key in the back hatch works as well as the key fob. I have put them window up and down several times, but still not resetting anything.
Thoughts or something else I can do? Am I dealer bound?
Thanks!
2002 SR5 4x4 Auto 3.4L l 285/70/17 Goodyear DuraTracs Load "D" l Level 8 MK6 Matte Black -12 Offset l Toytec Ultimate Lift with Silver Adjustable Coilovers l Diff Drop l 890 OME Rear Springs l Bilstein 5125 Rear Shocks
02T4RVA is offline   Reply With QuoteReply With Quote
Old 09-10-2013, 03:33 PM #52
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
try this, for wiper make sure its on the cradle correctly, then make sure nothing is stopping the rear window from going all the way up & seating, now hold the window switch inside the vehicle in the up position with the window completely up for 2 to 3 seconds. Then roll it down and hold it for 2 to 3 seconds.
chaz is offline   Reply With QuoteReply With Quote
Old 11-22-2013, 10:56 PM #53
speedbump343 speedbump343 is offline
speedbump343 is on a distinguished road
Rear Defrost not working
I have a 93 4Runner and have a problem with the rear defroster not working. The light will come on, but nothing happens. Can someone please help me with this.
speedbump343 is offline   Reply With QuoteReply With Quote
Old 11-23-2013, 02:16 PM #54
YYZ's Avatar
YYZ YYZ is offline
Real Name: Ash
YYZ YYZ is offline
YYZ's Avatar
Real Name: Ash
Smile
Thanks again.
Congrats Buddy for the Truck. And welcome to the forum.
Enjoy the ride.
Ash
Old 12-26-2013, 04:50 PM #55
FrankG FrankG is offline
FrankG is on a distinguished road
I had the same problem as others here but had to do an additional step to solve it. My 4Runner was a 2007 Limited model.
I made sure the rear wiper was in neutral position and tried pressing on the rear window around the edges to unjam it in case it was blocked by some of the recent snow and ice. But none of this worked. I also checked all the fuses and they were all fine. Then I found the problem:
1) The child safety lock button was depressed on the driver-side door. I must have pressed it by accident. Complicating matters was the fact that when I did it the rear window must have been slightly down and not all the way up. So once the child lock was depressed the car disabled the rear window - thereby I could not raise the window all the way to activate the defrost and wiper. Once I released the child saftey button I was then able to raise the window up - it moved just slightly but was enough to seal thereby re-enabling the defrost and back wiper. So if you get stuck check your child safety lock - that could be it.
FrankG is offline   Reply With QuoteReply With Quote
Old 04-08-2014, 01:24 AM #56
4x4Runnr 4x4Runnr is offline
4x4Runnr is on a distinguished road
Awesome - was afraid I was gonna have to start tracking down fuses, but came here first. This forum rocks! Pressed the "Up" button for the rear window, and it slid up just a tiny bit, but this fixed all my issues - no rear defrost, no rear wiper, and no rear washer fluid. I cycled the rear window down and up a couple times for good measure. Thanks so much - everything works now, and you saved me lots of time and aggravation!
4x4Runnr is offline   Reply With QuoteReply With Quote
Old 11-25-2014, 10:39 AM #57
haymaker75 haymaker75 is offline
haymaker75 is on a distinguished road
2003 4Runner Limited
Hi everyone....my situation...
Rear Defrost: Works
Rear Wiper Control: Works
Rear Window Control with Key: Does not work
Recently disconnected battery and window would work again but the defrost/wiper would not. After re-normalizing the window the defrost/wiper works but not the window. Process is repeatable...
Additionally, when key is in "Acc" location a small click from rear can be heard when pressing rear window control button from dash. Also, not sure "auto up/down" feature has been working at all.
And when window is working a snap can be heard about halfway as window is going down.
Any thoughts?
Thank you.
haymaker75 is offline   Reply With QuoteReply With Quote
Old 12-05-2014, 11:23 AM #58
shukinski shukinski is offline
shukinski is on a distinguished road
rear defoger, wash wiper and motor dont work
I had a problem that rear defoggeer, wiper motor and washer did not work. I check fuse, auto mode learning procedure, change back door module(MPX) change BCM. but is is not working. then I change rear power window motor asambly andit works but when i push button down and then up it needs to inicialization rear power window. please help what can i do?
shukinski is offline   Reply With QuoteReply With Quote
Old 01-26-2015, 03:23 PM #59
Sabu Sabu is offline
Sabu is an unknown quantity at this point
Thanks for the tip. I reseat the wiper, played with the window switch, and now everything works.
Sabu
Sabu is offline   Reply With QuoteReply With Quote
Old 01-27-2015, 12:19 AM #60
JrAdrock80 JrAdrock80 is offline
JrAdrock80 is on a distinguished road
I searched.....
Ok. So I searched and searched, but have yet to find anyone that mentions any issue like mine. I replaced my stereo in our 2005 SR5. I disconnected the battery as one should when doing this work and when everything was back together everything seemed fine. Well, it snowed. I attempted to use the rear wiper and nothing happened. No defrost, no wiper, no sprayer...... Cracked the rear window and rolled it up and everything worked. Great! Right?
Well, shut the ignition off and went around back to open the tail gate and it won't open. Get back in vehicle and turn it on. Rear wiper doesn't work again. Window rolls up and down fine. Leave ignition on and go around back and the tail gate opens. Defrost works. Sprayer works. Shut ignition off and turn back on....... Nothing works again.
So I search. I notice my auto window isn't auto anymore and I do the auto window reset procedure. Auto window works again, sprayer, wiper and the tail gate opens too. Shut off ignition and turn it back on. NOTHING!
Window works great. But if I shut off the ignition I can't open the tail gate. The key fob doesn't open the window. The lock doesn't actuate. Etc....... Why the hell does this thing reset every time the ignition is turned off? Can anyone please help. This worked flawlessly before the battery disconnect. Is this a ploy by toyota to drum up service just by disconnecting the battery? I've worked on cars for years and I can't figure this ridiculous mess out!
JrAdrock80 is offline   Reply With QuoteReply With Quote
2000 4 Runner rear window farm_dog12 3rd gen T4Rs 6 07-19-2016 07:57 PM
Rear window, rear defrost, rear wiper not working BREX25 3rd gen T4Rs 14 06-23-2013 11:22 PM
Rear Window Fiasco mac0822 4th Gen T4Rs 3 09-29-2010 07:46 PM
help - rear window - troubleshooting challenge Gretch_my_4runr Classic T4Rs 3 08-21-2010 05:18 PM
Rear window interior switch won't work Dude Problems & Warranty Issues 4 12-23-2005 10:50 PM
