Thread Tools Rating: Thread Rating: 11 votes, 4.91 average. Display Modes
Old 01-28-2015, 08:11 PM #61
Haynesja1 Haynesja1 is offline
Haynesja1 is on a distinguished road
Battery change stopped rear window and wiper to stop working
The kid lock and the all the way up button and down button worked for me as was posted.
BTW Toyota installed a recall computer upgrade on my 2004. Be sure to take all your keys as they will have to be reprogrammed. Cost me an additional trip to the dealer.
Haynesja1 is offline   Reply With QuoteReply With Quote
Old 01-30-2015, 04:46 AM #62
Oneluv13T4R's Avatar
Oneluv13T4R Oneluv13T4R is offline
Real Name: Miah
Oneluv13T4R will become famous soon enough
Real Name: Miah
Originally Posted by JrAdrock80 View Post
Ok. So I searched and searched, but have yet to find anyone that mentions any issue like mine. I replaced my stereo in our 2005 SR5. I disconnected the battery as one should when doing this work and when everything was back together everything seemed fine. Well, it snowed. I attempted to use the rear wiper and nothing happened. No defrost, no wiper, no sprayer...... Cracked the rear window and rolled it up and everything worked. Great! Right?
Well, shut the ignition off and went around back to open the tail gate and it won't open. Get back in vehicle and turn it on. Rear wiper doesn't work again. Window rolls up and down fine. Leave ignition on and go around back and the tail gate opens. Defrost works. Sprayer works. Shut ignition off and turn back on....... Nothing works again.
So I search. I notice my auto window isn't auto anymore and I do the auto window reset procedure. Auto window works again, sprayer, wiper and the tail gate opens too. Shut off ignition and turn it back on. NOTHING!
Window works great. But if I shut off the ignition I can't open the tail gate. The key fob doesn't open the window. The lock doesn't actuate. Etc....... Why the hell does this thing reset every time the ignition is turned off? Can anyone please help. This worked flawlessly before the battery disconnect. Is this a ploy by toyota to drum up service just by disconnecting the battery? I've worked on cars for years and I can't figure this ridiculous mess out!
Your in lockdown mode..Complete LOCKDOWN
Just had the same thing happen to my 03' 4runner SR5. Two days of completely freaking out til ...I read so much that i started reading between the lines of the repair manuel.
What you need is 2 keys
1 key goes in the ignition and turn it to "ON"
2nd key goes in the rear hatch door using it to work all the functions of the rear door. Do the typical turn and hold down turn hold up etc etc.
Why 2 keys? cause its a safety mechanism as if a child was stuck in the door it will noit come out of that mode until two keys are used assuming two people are verifying everything is ok..and walah
Oneluv13T4R is offline   Reply With QuoteReply With Quote
Old 02-27-2015, 07:06 PM #63
triadNC4runner triadNC4runner is offline
triadNC4runner is on a distinguished road
Awesome.Thank you.. rear wiper & washer would not work. I checked the fuse first (2010) inside the cabin..not blown. Googled problem.. took me to this site. Fixed in seconds. Rear window was down ever so slightly. I must have hit the button accidenatlly a few weeks ago? Most appreciative!
triadNC4runner is offline   Reply With QuoteReply With Quote
Old 05-05-2015, 07:25 PM #64
springlizard springlizard is offline
springlizard is on a distinguished road
Thanks for the info. I just had the sunroof worked on and then the rear wiper/washer didnt work. The rear window wasnt seated all the way up as previous poster said. Now all is well. Thanks again.
springlizard is offline   Reply With QuoteReply With Quote
Old 05-27-2015, 08:58 PM #65
CitizenX CitizenX is offline
CitizenX is on a distinguished road
Have same problem, and tried the above. Didn't work! Already been to the dealer and of course there it all worked fine. Thankfully I have an honest dealer and they didn't charge anything for the diagnostics. Anyone else have any ideas?
2009 Limited V8 4WD, Silver
CitizenX is offline   Reply With QuoteReply With Quote
Old 08-15-2015, 02:38 PM #66
Seahawksfan Seahawksfan is offline
Seahawksfan is on a distinguished road
9 years later this was still helpful
Thanks for the post, I ran into this issue. Tried to change the fuse, no help. Fixed the back window and everything is working properly.
Seahawksfan is offline   Reply With QuoteReply With Quote
Old 10-27-2015, 09:49 PM #67
Dobich39's Avatar
Dobich39 Dobich39 is offline
Dobich39 is on a distinguished road
Dobich39's Avatar
06 Window issues
Hi guys hoping you can help. I have been having problems with my rear window, defroster, wiper and figured I should get it fixed since winter is approaching. My window does not go up and down with any method. The defroster and wiper also do not function. I have tried moving them around in different positions and still nothing. Anyone have any ideas?
Dobich39 is offline   Reply With QuoteReply With Quote
Old 11-14-2015, 12:39 AM #68
PLP418 PLP418 is offline
PLP418 is on a distinguished road
Originally Posted by digphisher View Post
For the past two weeks, my rear window wouldn't go down, the rear defroster wouldn't go on, and the rear wiper and fluid wouldn't work. I check all of the fuses but everything looked ok. I took it to the dealership today, and they told me to try two things:
1. Make sure your rear wiper is in the proper neutral position.
2. Try putting your window up.
The dealer told me that if the window is almost up, but not quite all of the way that it won't go down. If it's not all the way up, the defroster won't work and the wiper won't work because the truck thinks that the window is down.
I went and played with the positioning of the wiper, and then used the button to make sure the window was all the way up (which it seemed to be), and now they all work!
Just wanted to let y'all know how to fix this if you ever have this problem.
What is the trick to do to fix this ? Thank
PLP418 is offline   Reply With QuoteReply With Quote
Old 12-12-2015, 06:28 PM #69
russman1963 russman1963 is offline
russman1963 is on a distinguished road
Same here, no wiper/defroster following a battery replacement. The reset worked perfectly!
Originally Posted by toto View Post
You may have to re-initialize the back window. This problem can also happen if you disconnect the battery.
See this thread for how to reset the back window.
Auto window roll down feature stopped working - Toyota 4Runner Forum - Largest 4Runner Forum
Russ
2003 4Runner LTD V8
2005 Sequoia SR5
russman1963 is offline   Reply With QuoteReply With Quote
Old 01-28-2016, 08:16 PM #70
treyk13 treyk13 is offline
treyk13 is on a distinguished road
same problem but my window want even go down!!!
I have read through here and i am having the same problem nothing on the back window works ( defrost, wiper or window rolling down)! I have moved the wiper around to different positions and I believe it is in the right position. When I hit the button inside to roll the window down I can hear a click and that is it! please help lol
treyk13 is offline   Reply With QuoteReply With Quote
Old 01-31-2016, 01:49 PM #71
FELLPEEPZ FELLPEEPZ is offline
FELLPEEPZ is on a distinguished road
This worked like a charm. I had an alternator and battery replacement and after, the sunroof, rear defrost, rear wiper did not work. My back window would not automatically roll down either.
After reading this thread, I rolled the back window all the way down and then up and held the button in the up position for 10 seconds. This fixed the rear defrost, wiper and the window all in one try.
The sunroof kicked in a day after the alt/battery replacement. At first there was no power to the roof at all. I pulled fuses and none were bad but the next day I had power to the roof. I had to open it and then close it and hold the button in the close position for 10 seconds and it cycled back to normal. Thanks again for the tip!
FELLPEEPZ is offline   Reply With QuoteReply With Quote
Old 01-31-2016, 01:59 PM #72
saabpowered's Avatar
saabpowered saabpowered is offline
saabpowered is on a distinguished road
I had the same thing happend on my 2006 4 runner when i disconnected the battery to replace the radio. There is a step to get this all to work and its in the manual if iam right. you have to zero point the back window for the defroster wiper auto front window and sunroof to work... kind of a stupid setup but after the first time its easy and takes less then a min to do
saabpowered is offline   Reply With QuoteReply With Quote
Old 02-11-2016, 02:49 PM #73
LM727 LM727 is offline
LM727 is on a distinguished road
Smile Thank you so much!!
This worked perfectly, and now my rear wipers and defrost are working fine.... Thank you very much!!
LM727 is offline   Reply With QuoteReply With Quote
Old 02-19-2016, 01:09 PM #74
Valve_Timing Valve_Timing is offline
Valve_Timing is on a distinguished road
2000 4runner rear defrost and window work just fine no rear wiper or washer .have attempted to normalize the window several times . no luck I assume.my.next step is to check the harness at the wiper motor itself ? My switch is good as all other functions for front wiper and washer work 100%
Valve_Timing is offline   Reply With QuoteReply With Quote
Old 02-27-2016, 05:30 PM #75
Well I can hear the sprayer motor whine when I try to release washer fluid nothing comes out so likely a leak somewhere along the line so nothing from the rear wiper
2000 4 Runner rear window farm_dog12 3rd gen T4Rs 6 07-19-2016 07:57 PM
Rear window, rear defrost, rear wiper not working BREX25 3rd gen T4Rs 14 06-23-2013 11:22 PM
Rear Window Fiasco mac0822 4th Gen T4Rs 3 09-29-2010 07:46 PM
help - rear window - troubleshooting challenge Gretch_my_4runr Classic T4Rs 3 08-21-2010 05:18 PM
Rear window interior switch won't work Dude Problems & Warranty Issues 4 12-23-2005 10:50 PM
