Thread Tools Rating: Thread Rating: 11 votes, 4.91 average. Display Modes
Old 12-21-2005, 04:01 PM #1
digphisher's Avatar
digphisher digphisher is offline
digphisher is on a distinguished road
digphisher's Avatar
Rear window, defroster, wiper wont' work? Look here!
For the past two weeks, my rear window wouldn't go down, the rear defroster wouldn't go on, and the rear wiper and fluid wouldn't work. I check all of the fuses but everything looked ok. I took it to the dealership today, and they told me to try two things:
1. Make sure your rear wiper is in the proper neutral position.
2. Try putting your window up.
The dealer told me that if the window is almost up, but not quite all of the way that it won't go down. If it's not all the way up, the defroster won't work and the wiper won't work because the truck thinks that the window is down.
I went and played with the positioning of the wiper, and then used the button to make sure the window was all the way up (which it seemed to be), and now they all work!
Just wanted to let y'all know how to fix this if you ever have this problem.
2005 Black Sport Edition 4x4
Magnaflow Catback exhaust,rear lens mod, fog light mod, T4R.ORG sticker, Hella FF50 driving lights, Alpine 9857 HU, Sirius, Infinity Reference 6.5" components, Ample Audio Exonic amp 60 x 4, Alpine 350 amp powering an L5 solobaric 10" square subwoofer sitting in a custom TRD stealthbox
red map lights, Overland Warehouse 2.0 3"lift, Cooper STT 285/70/17's
Valentine One Radar Detector with concealed display
digphisher is offline   Reply With QuoteReply With Quote
Old 01-16-2006, 11:53 AM #2
truckstoy truckstoy is offline
truckstoy is an unknown quantity at this point
rear window problem
thanks!!!!!
it did the trick.
this is the 2nd time i had this problem, now i know for the future.
04 4 Runner SR5 4x4
DBL G 405 20" chrome wheels
Falken Ziex S/TZ-04 275/45/20
Alpine CDA-9855
JL Audio 1000/1
JL Audio 13 W7
JL Audio 300/2
Diamond Audio M6651 comps
1/0g kit
Rockford/Stinger wiring
Alpine Sirius Tuner
truckstoy is offline   Reply With QuoteReply With Quote
Old 07-29-2007, 08:29 PM #3
Chenango21 Chenango21 is offline
Chenango21 is an unknown quantity at this point
rear wiper and rear defroster don't work
I tried the trick of putting the window all the way down and then back up and holding it a second.....no luck.
Any other suggestions how to debug this?
Thanks.
Chenango21 is offline   Reply With QuoteReply With Quote
Old 07-29-2007, 10:00 PM #4
toto toto is offline
toto is on a distinguished road
You may have to re-initialize the back window. This problem can also happen if you disconnect the battery.
See this thread for how to reset the back window.
http://www.toyota-4runner.org/showth...threadid=20637
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Old 08-02-2007, 04:37 PM #5
rear windshield wiper and defroster not working
I tried the "reinitialization" procedure many times....with ignition in "on" position, with the car running etc etc etc.
Unfortunately, it doesn't work.
Here are my symptoms:
Rear defroster: isn't working....no light on when button pressed.
No rear window wiper or fluid dispensing.
Rear window goes up and down (tho not auto)
Rear hatch does the auto close thing when you get it close.
Any tips or suggestions?
Thanks!
Old 01-16-2008, 08:51 PM #6
patpatriot patpatriot is offline
patpatriot is an unknown quantity at this point
Thanks for that tip! My rear defroster wasn't working. I checked to make sure the rear blade was in its position and played with the rear window, and now it works.
patpatriot is offline   Reply With QuoteReply With Quote
Old 01-28-2008, 03:43 AM #7
slowxturtle slowxturtle is offline
slowxturtle is an unknown quantity at this point
Thank you SOOOO much. I thought it was a fuse, but all fuses were okay. This did the trick. All my defogger, wiper, washer fluid and power window operations work now. Thanks again! The window was slightly open I guess.
slowxturtle is offline   Reply With QuoteReply With Quote
Old 03-07-2008, 01:25 AM #8
jp_over jp_over is offline
jp_over is an unknown quantity at this point
Thanks~!
I too thought it was a fuse but the fuses were good. Excellent advice!!!
jp_over is offline   Reply With QuoteReply With Quote
Old 03-14-2008, 02:36 PM #9
jbm03 jbm03 is offline
jbm03 is an unknown quantity at this point
Thanks for the post. Your information worked great! I have been traveling for months without the wiper working and did not want to take it to the dealer to be checked out. Glad to know that there is such a simple solution. Great information! Hope it works for others.
jbm03 is offline   Reply With QuoteReply With Quote
Old 12-06-2008, 01:50 PM #10
Tim Postmus Tim Postmus is offline
Tim Postmus is an unknown quantity at this point
Thank you for the tip! I too was checking all the fuses and couldn't figure out the issue. I lowered the window and then raised it back up and everything worked. Thanks again!
Tim Postmus is offline   Reply With QuoteReply With Quote
Old 12-09-2008, 07:41 PM #11
TW778 TW778 is offline
TW778 is an unknown quantity at this point
I had the same problem, checked all the fuses...then all of sudden today it all works....we got a bunch of snow and i had to brush it off I'm thinking my brushing moved the rear wiper back into the correct spot. Either way it's working that's all that matters.
TW778 is offline   Reply With QuoteReply With Quote
Old 01-01-2009, 09:53 PM #12
granfury granfury is offline
granfury is an unknown quantity at this point
Thanks so much!! I had the same symptoms in my 4-runner and now the windshield wiper and defroster work!!!
granfury is offline   Reply With QuoteReply With Quote
Old 01-01-2010, 11:43 AM #13
scrambler scrambler is offline
scrambler is on a distinguished road
Wink Release the window safety lock button!!
We had all the symptoms - no rear wiper, defroster, squirter, or window up/down. Thanks to gzkrutoy's simple reminder of releasing the window safety lock button, I got the rear window up the last 1/2" and all other functions work properly.
You guys ROCK!! You started my new year off in a good way. Many thanks!!
KISS! (Keep it simple, stupid)
scrambler is offline   Reply With QuoteReply With Quote
Old 01-06-2010, 10:45 AM #14
mynavy4runner mynavy4runner is offline
mynavy4runner is on a distinguished road
Smile no rear wiper,washer,defroster in my 4 runner
Thanks for your help! I was completely frustrated after SIX trips to the mechanic, both regular and Toyota, they could not fix the problem. I read this and tried it and so far everything is working! I can't believe it! Thanks so much.
mynavy4runner is offline   Reply With QuoteReply With Quote
Old 01-08-2010, 11:11 PM #15
Geneinnj Geneinnj is offline
Geneinnj is on a distinguished road
Rear wiper, washer and Defrogger not working
Thanks for the info just installed a new battery and noticed the rear defrogger washer and wiper weren't working . I went nuts checking all the fuses and then saw your post. I raised and lowered the back window all the way up and down and now everything is working fine. Guess it just needs to be reset. I had a problem with the sunroof where the auto open and close featured stoped working and that also had to be reset by opening it all the way and closing it. Little things that drive you crazy with simple fixes if you know them. Thankx
Geneinnj is offline   Reply With QuoteReply With Quote
2000 4 Runner rear window farm_dog12 3rd gen T4Rs 6 07-19-2016 07:57 PM
Rear window, rear defrost, rear wiper not working BREX25 3rd gen T4Rs 14 06-23-2013 11:22 PM
Rear Window Fiasco mac0822 4th Gen T4Rs 3 09-29-2010 07:46 PM
help - rear window - troubleshooting challenge Gretch_my_4runr Classic T4Rs 3 08-21-2010 05:18 PM
Rear window interior switch won't work Dude Problems & Warranty Issues 4 12-23-2005 10:50 PM
