Super Moderator
Super Moderator
It will depend on where it's leaking from. I'm not very experienced with transmissions -- last time I worked on one (20 years ago), it got so messed up that I had to take it to a pro to fix my mess.
My guess -- since the starter is trying to engage, it clearly is getting power. I'd suspect that the corrosion on the wiring is not the problem, but a problem about to happen. The problem you wrote about could be a bad starter (seen if on Fords before) or bad brushes inside the starter.
2003 SR5 V6 4WD Titanium with cladding
