Old 12-09-2013, 04:52 PM #1
ak2mt4runner ak2mt4runner is offline
ak2mt4runner is on a distinguished road
'91 Stuck in Reverse
My 1991 is stuck in reverse but my stick shift is free... not sure how this happened. Any suggestions on what/where to look at to see if linkages are broken or what should be examined first?
This happened when my clutch pedal bracket busted at the corner from fatigue.
Working on a welded/ modified bracket and putting it in first. I cant imagine that it will fix my simultaneous stuck-in-reverse problem though.....
ak2mt4runner is offline   Reply With QuoteReply With Quote
Old 12-11-2013, 02:28 AM #2
92-SR5's Avatar
92-SR5 92-SR5 is offline
Real Name: Cory
92-SR5 is on a distinguished road
92-SR5's Avatar
Real Name: Cory
Take apart your interior around the shifter. There will be 4 bolts holding in the shifter to the tranny, take those off and see what is going on.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
92-SR5 is offline   Reply With QuoteReply With Quote
Old 12-11-2013, 06:10 PM #3
already did. everything is good there. bushing is fine
Old 12-12-2013, 08:34 PM #4
92-SR5's Avatar
Real Name: Cory
92-SR5's Avatar
Real Name: Cory
Maybe the sychros are shot?
Have you drained the oil and refilled? If so, how did the oil look?
Old 12-19-2013, 04:24 PM #5
i found a forum that helped me figure it out. when these 4runners get stuck in reverse due to getting jarred or a sudden stop then you can manually move them out of gear by pulling the reverse light switch off the passenger side of the transmission and pushing the rods backwards. I did this and it freed up my gears.
5 speed stuck in reverse - Pirate4x4.Com : 4x4 and Off-Road Forum
"Anyways here's the break down, the 5th gear is heavy enough to "fall" and knock the tranny into reverse, with that the shifter is still in the (N) position therefor your not able to shift out of (R). So what you have to do is remove the (R) light plug on the side of the tranny *(Passenger side)* and in there with some small needle nose pliers you will see a metal tab, grab onto it and move it "back" *(towards the rear of the tranny)* till it can't move any further."
Old 12-19-2013, 06:31 PM #6
92-SR5's Avatar
Real Name: Cory
92-SR5's Avatar
Real Name: Cory
Interesting.
Old 12-19-2013, 07:03 PM #7
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
I don't understand how the shifter can be returned back to neutral if the gear is stuck in reverse.
or, was the shifter also stuck in reverse?
my nephew had a trans lock up in 4th gear. we pulled it apart, and found the shift detents had been installed incorrectly. we fixed it, and put it back together. it was fine, for a few months then it locked up again.
not sure why that time. I sold him a different transmission and he swapped it out.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 12-19-2013, 08:20 PM #8
I was really baffled by this too. My stick was completely free and the gear was stuck in reverse. I could move my stick around but I couldn't move it into any gear positions, it was the strangest thing. I did all sorts of things to try and "free up" my transmission, but manually pushing it back after removing the reverse light indicator was the only thing that worked.
Thinking back on it now, I remember that it happened when I killed my engine while I was moving backwards in reverse. I had to kill my engine because my clutch bracket is busted and the only effective way of stopping the vehicle was to turn if off ....so that I wouldn't run into the parked cars behind me. Then when I tried to put it into first gear after killing the engine I realized that my stick was not going into any gears... so I tried to wrestle it into gear for awhile thinking that it wouldn't go into gear because my clutch wasn't getting full stroke because the broken clutch bracket was flexing off the firewall. I then started the engine thinking that the transmission was in neutral and it immediately started moving backwards in reverse much to my surprise and horror. I immediately killed the engine.... and then I struggled with it for hours. Finally I wedged my broken clutch bracket to where I could push my clutch in enough to where I was not longer engaging my reverse gear... and then my friends pushed me into my garage. I then discovered the above posted forum (5 weeks later) and after reading it I was able to free my transmission from reverse.
Old 12-19-2013, 08:22 PM #9
so now I'm going to carry a crescent wrench and needle nose pliers in my 4runner at all times in case it happens again.... along with the rest of my usual tools
Old 04-06-2019, 05:52 AM #10
El Samster. El Samster. is offline
El Samster. is on a distinguished road
How exactly did you do it because my pickup got stuck in reverse but shifter on neutral 2 days ago while reversing and my engine died.. 04/06/19
El Samster. is offline   Reply With QuoteReply With Quote
1991 4runner , gear , problem , reverse , stuck
Reverse Camera Install -- Need to wire to reverse switch tyrenta 3rd gen T4Rs 2 07-14-2017 02:56 PM
Stuck With No Reverse?? TRDCal 4th Gen T4Rs 1 02-03-2012 08:10 PM
921 LED reverse lights GottaBeTRD Classifieds - buy & sell (no commercial ads please) 7 03-07-2011 09:05 PM
4WD in reverse? Camprunner 4th Gen T4Rs 2 12-02-2007 09:09 PM
4WD in reverse ? Fred MaN 4th Gen T4Rs 2 11-08-2006 10:00 AM
