Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 07-01-2007, 10:51 PM #46
a77boy a77boy is offline
a77boy is an unknown quantity at this point
About two months ago I took out the relay and banged it on my kitchen counter top. It has been working since (see previous post). Last week it gave out again, I pulled over at a gas station, took it out and banged all sides on the concrete. No big deal if I break it I figured,, was going to have to buy another one anyway. Needless to say it started working again,, will see how long it goes this time :-)
a77boy is offline   Reply With QuoteReply With Quote
Old 07-02-2007, 02:56 PM #47
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
Update;
I re-ordered the new, replacement A/C Mag Clutch relay from Partznet, and they indicated the order was filled, and shipped today, should get it tomorrow. $57.06. w/shipping. When it arrives, I get my fog lights back, whoopie........
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 07-02-2007, 08:19 PM #48
greasefingers's Avatar
greasefingers greasefingers is offline
greasefingers is on a distinguished road
Yea you have not missed much since the fog lights are pretty useless.
As far as relays go, it was the most that I have ever spent on one.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
greasefingers is offline   Reply With QuoteReply With Quote
Old 07-03-2007, 08:00 AM #49
Sac State's Avatar
Sac State Sac State is offline
Real Name: Mushmouth
Sac State is on a distinguished road
Sac State's Avatar
haha, Texas A&M engineering solution at its best.
'14 SR5
'08 FJ Trail Teams 6MT, '03 4Runner Sport V8, '02 4Runner Sport, '80 SR5 Pickup 5MT, all of them 4WD.
Sac State is offline   Reply With QuoteReply With Quote
Old 07-03-2007, 08:45 AM #50
TechWrench's Avatar
TechWrench's Avatar
What we need is a good 'redneck' engineering solution. Some one needs to rig up a solenoid driven impact device to mount next to the relay, controlled by a push button on the dash. A/C stops, hit the 'easy' button a few times, and yer good to go.
Old 07-03-2007, 09:30 AM #51
rando's Avatar
rando rando is offline
rando is on a distinguished road
rando's Avatar
The diode jammed down into the relay contacts doesn't qualify as red neck? Maybe if remove the shrink tube and wires and just jam the raw diode in there, I can qualify for the prize!
rando is offline   Reply With QuoteReply With Quote
Old 07-03-2007, 11:59 AM #52
I now keep a big rock in the glove box, IF it goes out again I will bang it.
Old 07-03-2007, 05:37 PM #53
TechWrench's Avatar
TechWrench's Avatar
Sorry, but the diode thing just doesn't make it for a 'redneck' type of 'fix'. The diode, no matter how inelegantly installed, addresses the cause of the problem. A good 'redneck' solution deals only with the symptoms, not the cause. That 'n more beer will 'fix' anything, for a while.
Old 07-10-2007, 06:27 PM #54
chiefjhf chiefjhf is offline
chiefjhf is an unknown quantity at this point
Thumbs up A/C Light Flashing
Oh wow, hope I'm doin' this right...just joined forum! My A/C quit working too, located the relay with the help of you folks.
The dealer wanted to charge me $60.00 bucks to diagnose the problem because the svc mgr said the relay does lots more than control the A/C.
Using the info you super folks provided, I pulled the relay, than reinserted it and .... lo and behold, it must have had dirty contacts because for 2 months now, no problemo's.
Ya'll are way too kewl...thx so much for the help...!
chiefjhf is offline   Reply With QuoteReply With Quote
Old 07-10-2007, 07:24 PM #55
welcome to the Forum!! we kid around allot but you can find LOTS of useful info here with the help of all these 4 Runner owners! Glad to see that your problem worked itself out.
Old 07-12-2007, 12:23 PM #56
Thumbs up A/C Light
Thx A77, I think I'll like it here.... ;)
Old 07-12-2007, 12:59 PM #57
rando's Avatar
rando's Avatar
Re: A/C Light Flashing
Find yourself a new service center / dealer -- the relay doesn't do ANYTHING more than control the A/C compressor clutch.
Now save yourself the future repair cost and install the diode while your relay still has life. As is, it's not a question of if it will fail, but when.
Old 07-12-2007, 06:28 PM #58
and don't forget the rock!
Old 07-28-2007, 07:35 AM #59
:awais: Rando, thanks for the awesome information. Just a dummy here who is not sure about the IC4 tap. If you tap D1 at the IC4 connector, where does the other end of the diode go to get it to ground?
Are you removing a spade terminal and inserting the diode between it and the connector? If so, which direction does the anode point to.
Sorry for being such an airhead.
2003 4 Runner Sport Edition, V-8, Galactic Gray Metalic, Lighted Running Boards, 11/2002
Old 08-04-2007, 08:49 PM #60
rando's Avatar
rando's Avatar
Any ground will work. Check the schematic and pictures on the previous page. I didn't hook mine up at IC4 instead opting to insert it directly under the relays in the relay box. I soldered a piece of wire to each side of the diode and then jammed the other end of each wire directly into the relay spade terminals. Once the relays are reinstalled, it's secured.
The diode cathode goes to the load side of the circuit. The anode is connected to ground.
As shown in the schematic and pictures on the previous page, the diode cathode
A/C Light Blinking on 2003 LTD bluduk15 Problems & Warranty Issues 60 06-18-2019 06:55 PM
D light on dash not lighting up (sometimes): DRC 4th Gen T4Rs 4 10-17-2013 02:09 PM
1st gen brake and charge light flashing?? Leo Ahearn Classic T4Rs 10 05-14-2012 10:09 AM
a/c light burnt out nc211 4th Gen T4Rs 2 01-27-2009 11:22 AM
AC problem: light flashing, no cold air buwen 4th Gen T4Rs 2 03-30-2006 01:31 AM
