Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 08-08-2007, 10:50 AM #61
chiefjhf chiefjhf is offline
chiefjhf is an unknown quantity at this point
Mission accomplished, relay saved by Rando, no sparks..flames...just a nice steady A/C light. My $1.00 diode fit nicely without extra wire extensions and it lays covered with shrinkable spagetti along side the heater and MCR relays just as you said. Thank you sir for your fantastic assistance !
2003 4 Runner Sport Edition, V-8, Galactic Gray Metalic, Lighted Running Boards, 11/2002
chiefjhf is offline   Reply With QuoteReply With Quote
Old 11-05-2007, 11:23 AM #62
RickyCRX RickyCRX is offline
RickyCRX is an unknown quantity at this point
Well, my '03 4Runner made it to 96k miles before the A/C light started blinking yesterday. I tried to switch the A/C off and back on and it didn't work. I then turned it off for a few minutes, waited, then turned it back on and it worked all afternoon after that. I'm thinking about just swapping the relay with the foglight relay and just run with it. I almost *never* use the useless foglights, so I figure that'll give me another 50-90k miles before I have another relay start to go bad. At that point I can decide if I feel like buying the updated part number or not.
Any thoughts?
I don't really feel like rigging up the diode. Has anybody with the updated part number had the blinking A/C light problem at all? Is that new relay truly a permanent fix?
2003 2WD Galactic Grey V8 Sport
RickyCRX is offline   Reply With QuoteReply With Quote
Old 11-05-2007, 11:44 AM #63
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench is on a distinguished road
TechWrench's Avatar
Any thoughts?
I've had mine in for about 10k with no repeat of the problem. Of course, the first relay lasted about 35k before it started to fail, so who knows how long the replacement relay will last?
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 11-05-2007, 12:09 PM #64
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Originally posted by TechWrench
Nice detective work. I'm not used to seeing mechanical relays sealed like that, Thats why I thought it might be a SSR. I guess it is to keep them clean given the environment they work in. Though some of the other relays in the box aren't sealed, in any case. Those contacts are, with out a doubt, burnt. I'm hoping the fog light relay holds out until the new relay is available again. I think the original A/C relay lasted 3 years, so I hope we have some time before the next one fries.
I think the sealed relays contain nitrogen to reduce arcing, but with no diode shunt it will fail anyway.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 11-10-2007, 01:04 PM #65
yabedude's Avatar
yabedude yabedude is offline
yabedude is on a distinguished road
yabedude's Avatar
Same issue here. It's been occurring off/on by itself over the last year. Thanks to all that helped identify and especially the one that provided that awesome solution.
yabedude is offline   Reply With QuoteReply With Quote
Old 11-25-2007, 08:43 PM #66
ovrrdrive's Avatar
ovrrdrive ovrrdrive is offline
ovrrdrive is an unknown quantity at this point
ovrrdrive's Avatar
Once again T4r.org comes through. The worst part of this entire problem was trying to search for 'blinking AC" when the forum doesn't allow 2 letter search terms. A search for 'blinking button' brought this thread to the top. ;)
I do have one slight addition to the excellent information already posted though...
I did the 12V outlet mod a while back and put the relay in the glove box just in case I ever needed it. Well you guessed it, it was yet the same relay. I plugged it in and cold air is in the house again.
My '03 doesn't have fog lights and in turn it didn't have the relay there for them either. I got to thinking and checked the one in the glove box and got lucky. I figure I have another 60-70k miles to get the diode installed. Hopefully.
Thanks again everyone...
2003 Silver/Gray SE5 V8 T4R
1995 4x4 Xcab Truck 8.5" lift, 36x13.5 Iroks on M/T Classic Locks, 5.29's, Lockright locker, OBA and a Train Horn
ovrrdrive is offline   Reply With QuoteReply With Quote
Old 11-27-2007, 02:21 AM #67
yabedude's Avatar
yabedude's Avatar
Thumbs up
Hudos to Toyota of Dallas as their replacement relay fixed this defect that 1) was out of warranty and 2) isn't covered under the extended warranty and 3) was over $100 cheaper than in my back yard!
Part # 90987-02028 for $45.56. Up here in Ripeoff Country the stealer wanted over $160 bills for the exact same relay!! Canadian Stealers should wave flags that have us fools bent over with them stickin' it to us. Bast.ards! :xnuts:
Old 01-12-2008, 02:16 AM #68
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
I'm having problems with my AC. It only feels like the fan is on vs. the AC. However...the light doesn't blink. I've checked my relay, and...frankly I saw 5 with the 90987-02022 code. Could my AC problem be with the Relay being bad even though it doesn't blink?
simple is offline   Reply With QuoteReply With Quote
Old 01-12-2008, 03:05 AM #69
yabedude's Avatar
yabedude's Avatar
I guess you could swap one of the other relays (fog lights) and give it a try.
Old 01-12-2008, 03:17 AM #70
simple's Avatar
simple's Avatar
Well Hello Captain Obvious. I just read this whole thread and I can't believe I didn't think of that!!!
However, with that being said...isn't that the same relay therefore not fixing the problem? Why does the same part work in all those other relays, but not the magnetic clutch? Anyway, I will definitely try that tomorrow and take my car for a long drive and see how it works. Thanks!
Old 01-12-2008, 04:27 AM #71
yabedude's Avatar
yabedude's Avatar
Presumably, the (old model) relay will die a slow death as an AC relay due to the power surge when the AC powers off (or is that on). That level of voltage isn't present in other devices. So if you do swap them and it works, I'd swap the relay back and buy a newer model replacement relay cause you'll eventually destroy the swapped one too.
Old 01-12-2008, 04:39 AM #72
Coralkillah's Avatar
Coralkillah Coralkillah is offline
Registered User
Coralkillah is an unknown quantity at this point
Registered User
I just had the same problem on my 03 today.
Swapped out the old relay for a new one and viola, No HEAT!!!
The Mechanic said the Horn Relay can be used as a replacement while you go and get the new A/C one. The Horn and A/C relays are apparently the same part.
Just no horning anyone! Yelling does the same trick though
Coralkillah is offline   Reply With QuoteReply With Quote
Old 01-24-2008, 01:09 PM #73
webshot's Avatar
webshot webshot is offline
webshot is an unknown quantity at this point
webshot's Avatar
NEVERMIND! SOLD!
Thanks...
If anyone needs one of these relays, let me know! I have an extra brand new, never used, sitting on the shelf in my garage. I'll sell it for $20 plus shipping.
Thanks,
webshot
webshot is offline   Reply With QuoteReply With Quote
Old 05-11-2008, 11:55 PM #74
4Runner2003's Avatar
4Runner2003 4Runner2003 is offline
4Runner2003 is an unknown quantity at this point
You Guys Rock
Mine started Blinking on Friday. I was bummed all weekend as I was expecting to have to shell out some cash to get the A/C fixed. I decided to search, found this, swapped out the Fog Light relay and I have A/C. Going to the dealer tomorrow to get a new one. Guys thanks again!!
Scott
2003 Black 4Runner LTD V8 4WD
Rear-air Suspension, NAV, XM Satelite Radio
Mods: Hood Scoop
http://community.webshots.com/user/4runner2003
4Runner2003 is offline   Reply With QuoteReply With Quote
Old 05-25-2008, 05:14 PM #75
snowjay snowjay is offline
snowjay is an unknown quantity at this point
Thank goodness for this thread, I thought I was going to have to go to the dealer.
This past winter my light started to flash and since I didn't need the a/c I just turned it off. About a month ago I tried it again and it was working, until today.
Did a quick search here and found the problem was easy to diagnose and even fix. For now I banged the relay against the ground and its working again but I just ordered the newer relay from Partznet so hopefully I'll have the permanent fix soon.
Jay
snowjay is offline   Reply With QuoteReply With Quote
A/C Light Blinking on 2003 LTD bluduk15 Problems & Warranty Issues 60 06-18-2019 06:55 PM
D light on dash not lighting up (sometimes): DRC 4th Gen T4Rs 4 10-17-2013 02:09 PM
1st gen brake and charge light flashing?? Leo Ahearn Classic T4Rs 10 05-14-2012 10:09 AM
a/c light burnt out nc211 4th Gen T4Rs 2 01-27-2009 11:22 AM
AC problem: light flashing, no cold air buwen 4th Gen T4Rs 2 03-30-2006 01:31 AM
