Old 05-14-2013, 01:36 PM #31
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
That seems a little high. I still think it's the regulator.
I replaced my master window switch (for $40) and it didn't help.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 06:02 PM #32
Andrei's Avatar
Andrei Andrei is offline
Andrei is on a distinguished road
Andrei's Avatar
Thanks for your help. The toyota dealer told me it was the power window switch so....I ended up going to a local junk yard and I picked up a used (of course) master power window switch for $54. I replaced the old one with the one From the yard and now it works. I also had to reset it because it was acting weird....like rolling only half way up or not not closing or opening at all for a small period of time..... Anyways, I followed the instructions mentioned above with no success. I have an 2005 T4R SR5 V6 2WD so I found on youtube a video on how to reset on later models toyota the master power window switch. Now it works. I did the following to reset it:
1- turn your key to Accesories (ACC)
2- roll window ALL WAY down by holding the button all the way down and keep holding it down for 3 more seconds after it stops.
3- roll window ALL WAY up by holding the button all the way up and keep holding it up for 3 more seconds after it stops.
After completing the 3 steps your power window should operate properly.
In the end I saved around $600 by buying a used one from he junk yard and by replacing it on my own. It only took around 15-20min to do so.
Andrei is offline   Reply With QuoteReply With Quote
Old 10-08-2014, 10:23 AM #33
marlinsfan's Avatar
marlinsfan marlinsfan is offline
marlinsfan is on a distinguished road
marlinsfan's Avatar
LOL, I feel like a dummy! My rear wiper was not working on the ride home last night. I read this thread, went back in the car and sure enough the back window was not rolled all the way up. Works fine now.
marlinsfan is offline   Reply With QuoteReply With Quote
Old 11-21-2014, 10:39 PM #34
cedavies1 cedavies1 is offline
cedavies1 is on a distinguished road
Thanks toto this solved my problem after changing out the battery on my 2005 T4R today.
Whew I was worried I had screwed up by shorting a cable or something.
Cheers mate from Canada.
cedavies1 is offline   Reply With QuoteReply With Quote
Old 12-31-2014, 01:36 PM #35
t-man t-man is offline
Real Name: Tony
t-man is on a distinguished road
Real Name: Tony
Super old thread, still saving our asses!! Thanks for the great directions!!
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
t-man is offline   Reply With QuoteReply With Quote
Old 01-07-2015, 09:02 AM #36
JimKW JimKW is offline
JimKW is on a distinguished road
I had the steering shaft replaced on my 4Runner by an independent shop. When I stopped at the mail box on the way home, the auto window down did not work. When I drove it to work on Tuesday, the rear defroster and the auto up down on the rear window also would not work. I'm think what fuse would contol that combination? I did a search and found this thread and now everything works fine.
I actually found it through a Google search as opposed to a search on this site.
2003 Dark Blue 4Runner Limited V8
2008 Space Grey BMW 535xi Wagon
2006 Alpine White BMW 330xi
2000 Red Crownline 180BR (Lil Red)
JimKW is offline   Reply With QuoteReply With Quote
Old 03-27-2015, 01:32 AM #37
shoeless shoeless is offline
shoeless is on a distinguished road
Would this also fix the entire hatch not opening?
I would give it a try, but the dealership currently has the truck.
Thanks!
shoeless is offline   Reply With QuoteReply With Quote
Old 01-25-2016, 04:00 PM #38
ULCajun ULCajun is offline
ULCajun is on a distinguished road
Has anyone had an issue with the factory nav needing to be reset too? I can hear things working inside but it is stuck on the "insert DVD" screen.
ULCajun is offline   Reply With QuoteReply With Quote
Old 01-28-2016, 11:23 PM #39
j0ber j0ber is offline
j0ber is on a distinguished road
Originally Posted by toto View Post
Yes, you need to reset the one-touch features on the power windows and moonroof when you disconnect the battery. The windows use less power to close these days (so they're less likely to crush hands or fingers), so they need to "remember" where the closed position is.
To reset the driver's side power window auto-close:
1. Push down and hold the driver’s door power window switch to completely open the window.
2. Pull and hold up the driver’s door power window switch until the window closes. Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open/close” by pushing the switch briefly to the “DOWN” and “UP” positions.
To reset the moonroof one-touch operation:
With ignition switch in the “ON” position, do the following:
1. Push and hold the “TILT UP” side of the switch until the moon roof tilts all the way up and then tilts down slightly (approximately 10 mm [0.39 in.] at the rear).
2. Check for proper operation of the “one–touch slide open/close” and “one–touch tilt up/down” functions by pushing the switch briefly to the “SLIDE OPEN” and
“TILT UP” positions.
To reset the rear window operation:
1. Turn ignition switch to the “ON” position.
2. Push the back door power window switch to the “DOWN” side to open the window.
3. Push and hold the back door power window switch to the “UP” side until the window closes. Continue holding it for approximately 1 second.
4. Check for proper operation of the “one-touch open/close” functions by pushing the switch briefly to the “DOWN” and “UP” position.
The compass will also need to be reset if you disconnect the battery. Instructions for that are in the Owners Manual. You need to look at a map of the country to determine which zone you're in, and the instuructions are slightly different for 2003-2006 vs. 2007-2009.
My rear wiper/windshield washer fluid and rear defrost stopped working after i disconnected my battery.
At the time i didn't thought it was related to the battery being disconnected.
I took my 4R to the mechanic shop. They waste 2hrs trying and checking everything.
When i came back it worked but they had no explanation of what caused the problem and what resolved it. They said maybe something was frozen or just a bad connection.
It cost me about 180$. Problem solved but i feared it will be back sometime.
That's exactly what happened about a month later. I disconnected the battery again and the problem was back.
I then realized it has something to do with the battery disconnection... But didn't know what.
I was about to take the 4R to a good shop specialized in electric problems. I was thinking about all the $$$ going out of my pockets again and i took a chance... What about a little Google search on that problem?
That's what i did and i just found this post and saying to myself "I couldn't be just that?". I ran to my 4R and followed the rear window reset instructions and guess what?
PROBLEM SOLVED! It only took 30 secs! You made my day!
You just saved me some $$$. I can't believe professionnals didn't find that, and that i paid 180$ for nothing...
This forum will be a must from now on...
Thanks again!
j0ber is offline   Reply With QuoteReply With Quote
Old 01-28-2016, 11:29 PM #40
Real Name: Tony
Real Name: Tony
Thanks again!
Sunroof and drivers window does it too. Also, whenever I unplug my battery for a few hours to reset everything it usually stalls on the first crank and then fires up and runs fine.
Old 03-23-2016, 10:59 AM #41
Ausumm's Avatar
Ausumm Ausumm is offline
Ausumm is on a distinguished road
Ausumm's Avatar
I know it's an old thread, but I have a similar question.
I am having the opposite problem.
I want to STOP the window from doing the AUTO UP and AUTO DOWN feature.
My window will ONLY go all the way down with one touch,
or all the way UP with one touch.
And I know you're supposed to hit the button to stop it part way...
but my window doesn't work that way.
If you hit it once, it starts to go all the way down,
if you hit it quickly in mid run, it simply goes all the way back up.
Anyone know how to UN-program the window?
Ausumm is offline   Reply With QuoteReply With Quote
Old 06-20-2016, 11:33 PM #42
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
Do you have to do this? I absolutely HATE auto roll features and would prefer to leave themy non auto if that won't hurt anything
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 06-27-2016, 08:38 AM #43
BC813 BC813 is offline
Real Name: Ben
BC813 is on a distinguished road
Real Name: Ben
Perfect! Thank you!
2008 2WD Limited V6 Galactic Grey 4Runner 2.5/1.5 Daystar leveling kit, usb plug switch replace, Aux always on relay bypass, 8in sub replaced many more mods planned!
In wine there is wisdom, in beer there is freedom, and in water there is bacteria" -NOT Ben Franklin
BC813 is offline   Reply With QuoteReply With Quote
Old 07-18-2016, 08:59 PM #44
orangelion orangelion is offline
orangelion is on a distinguished road
thanks for the info, had to use reprogram the drivers window and rear door window today.
2006 SR5 4x4 - dipped front grill, Stealth light bar in lower grill, Thule 725 Ski racks, Pioneer deh80prs, tru technology b475s, Polk sr6500, tru technology b2110s modded, 2004 RE XXX 12" 30Hz 2.25ft3, line 8s v2
2005 C55 AMG sold, 2005 STI sold, 1994 Supra TT will never be sold
orangelion is offline   Reply With QuoteReply With Quote
Old 12-05-2016, 06:13 PM #45
Sabaka Sabaka is offline
Sabaka is on a distinguished road
Thank you! Very helpful.
Sabaka is offline   Reply With QuoteReply With Quote
Rear Window not Working?? okkin 4th Gen T4Rs 21 07-17-2020 09:13 AM
window Auto up/down feature kimboy 4th Gen T4Rs 4 05-12-2005 12:38 AM
'95 Rear window stopped working AznKlique 4th Gen T4Rs 2 03-22-2005 03:38 PM
98 back window wont roll up hamster_13 4th Gen T4Rs 1 01-29-2005 03:07 PM
Power Window Auto Switch 1fastrunner Problems & Warranty Issues 1 11-05-2003 10:24 PM
