Old 12-27-2016, 11:39 AM #46
daveba4 daveba4 is offline
daveba4 is on a distinguished road
I had to do reset all 3 and your instructions were perfect. Thank you!
daveba4 is offline   Reply With QuoteReply With Quote
Old 12-31-2016, 07:43 PM #47
mclovin mclovin is offline
mclovin is on a distinguished road
Thanks so much for posting this! I had my battery replaced the other day, and experienced all these problems. Genius!
mclovin is offline   Reply With QuoteReply With Quote
Old 09-01-2017, 04:50 PM #48
joshbuck28 joshbuck28 is offline
Real Name: Josh Buck
joshbuck28 is on a distinguished road
Thank you so much!! I spent hours trying to replace my rear tailgate assembly and this forum gave me all of the answers I needed!!! From removal of the old unit to installation of the new one to resetting the electronics!! Thank you so much to everyone that has contributed to this forum! You guys took a seemingly impossible-to-repair problem and helped me figure it out at the lowest cost and in the most straightforward way! Love you guys!!
joshbuck28 is offline   Reply With QuoteReply With Quote
Old 11-02-2017, 09:20 AM #49
fc2grimm fc2grimm is offline
fc2grimm is on a distinguished road
This place rocks!!
Installed a new radio a few days ago, disconnected the battery as part of the steps. Had this issue at the end, had no idea about "normalizing" the windows.
Ran the back window down and then up, everything now working. This is exactly why forums/boards like this one are the best.
2007 Sport Edition V6 with sunroof and tow package
fc2grimm is offline   Reply With QuoteReply With Quote
Old 11-20-2017, 03:05 PM #50
FiveDogs FiveDogs is offline
FiveDogs is on a distinguished road
So relieved
Just bought a 2006 4Runner last week. Yesterday I discovered the rear wiper and defroster weren't working, and I was beginning to regret purchasing an 11 year old vehicle. But a quick search on this forum revealed the solution. I had disconnected my battery a few days ago. Back in business now. Thanks!
FiveDogs is offline   Reply With QuoteReply With Quote
Old 11-25-2017, 06:05 PM #51
Valve floater Valve floater is offline
Valve floater is on a distinguished road
2001 4 R rear window
Hey I got a replacement key fob from Amazon and even with weak door lock actuators was able to get into program mode and get door locks to work with new remote, but the rear window down function won't work. The function does work with original key remote. Any Ideas/ Also the panic horn sounds wh
ether I use the window switch or panic button.
Valve floater is offline   Reply With QuoteReply With Quote
Old 12-07-2017, 05:10 PM #52
4Runnermom15 4Runnermom15 is offline
Real Name: Alysha
4Runnermom15 is on a distinguished road
Real Name: Alysha
Talking Thank you so much!
His was an extremely helpful post. Momma started to freak out a lil when things were not working!
Thanks a million!
Alysha
4Runnermom15 is offline   Reply With QuoteReply With Quote
Old 05-29-2018, 07:47 PM #53
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Originally Posted by toto View Post
To reset the moonroof one-touch operation:
With ignition switch in the “ON” position, do the following:
1. Push and hold the “TILT UP” side of the switch until the moon roof tilts all the way up and then tilts down slightly (approximately 10 mm [0.39 in.] at the rear).
2. Check for proper operation of the “one–touch slide open/close” and “one–touch tilt up/down” functions by pushing the switch briefly to the “SLIDE OPEN” and
“TILT UP” positions.
Love you guys.... Thanks for sharing all this greet info
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 07-05-2018, 04:55 PM #54
ssmithusa ssmithusa is offline
ssmithusa is on a distinguished road
Solution is Here. Please Follow Following Steps
Ensure the vehicle is in park.
Inspect the key for damage.
Ensure there is nothing stuck to the key.
Check to see if the steering wheel is locked.
ssmithusa is offline   Reply With QuoteReply With Quote
Old 09-17-2018, 12:42 PM #55
rumfoord's Avatar
rumfoord rumfoord is offline
rumfoord is on a distinguished road
rumfoord's Avatar
I just recently noticed that my moonroof isn't closing completely and is about a quarter inch low in the back when using the auto feature.
I had to go through the procedure described here after my battery was disconnected and thought everything was fine. However having a closer look from the outside it seems a bit off. I do seem to remember a strange occurrence when resetting initially and a think there was a skip/grind sound when holding the moonroof button.
Anyhow, I'm curious if there is a way to reset again without disconnecting the battery.
Cheers
rumfoord is offline   Reply With QuoteReply With Quote
Old 09-22-2018, 02:07 PM #56
KYFHO69 KYFHO69 is offline
KYFHO69 is on a distinguished road
Cheers
I had the same problem. Press the “Tilt Up” button to the roof, when the window gets to the tilt position continue to hold the button for another 3 to 5 seconds. It will reset the opening function.
KYFHO69 is offline   Reply With QuoteReply With Quote
Old 09-25-2018, 08:26 AM #57
DEDon DEDon is offline
Real Name: Don
DEDon is on a distinguished road
Real Name: Don
Fixed
Thanks for posting this thread. I'm squared away, now. Easy fux
"If ever time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." Samuel Adams
DEDon is offline   Reply With QuoteReply With Quote
Old 09-30-2018, 02:12 PM #58
rumfoord's Avatar
rumfoord's Avatar
Thanks for the reply, will remember that. Funny enough, wife offered to close it while I was driving and when I went to open again the auto open was no longer working. She must have done that when closing. Anyhow I thanked her profusely and went through the procedure to enable auto open/close again and this time we have a good seal, sits flush!
Old 01-26-2020, 04:10 PM #59
Rogue23 Rogue23 is offline
Rogue23 is on a distinguished road
Fourteen years after the original post, still a handy piece of information! Just solved something that would have driven me nuts otherwise lol...
thanks!!
Rogue23 is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 11:27 PM #60
Dlark Dlark is offline
Dlark is on a distinguished road
Hey guys I disconnected my battery and did all the auto features for driver window and Moon roof... Tried everything to re program the rear window auto settings and nothing is working. The key hole and fob only crack the window a little bit. Any ideas about this???
Dlark is offline   Reply With QuoteReply With Quote
Rear Window not Working?? okkin 4th Gen T4Rs 21 07-17-2020 09:13 AM
window Auto up/down feature kimboy 4th Gen T4Rs 4 05-12-2005 12:38 AM
'95 Rear window stopped working AznKlique 4th Gen T4Rs 2 03-22-2005 03:38 PM
98 back window wont roll up hamster_13 4th Gen T4Rs 1 01-29-2005 03:07 PM
Power Window Auto Switch 1fastrunner Problems & Warranty Issues 1 11-05-2003 10:24 PM
