Old 04-26-2020, 01:33 PM #61
mastee mastee is offline
mastee is on a distinguished road
Reporting another stuck tailgate on a 2004.
I went through pretty much all the troubleshooting procedures on this thread but had no luck. The bad part is that no matter what combination of actions I do up/down together/separate with the two levers it does not open the hatch.
I am not sure if I order the part how will I open the hatch in the first place; I can hear the mechanism working when I pull on the handle but the levers do not move. The window works well both with the keyfob and in the lock
mastee is offline   Reply With QuoteReply With Quote
Old 12-14-2021, 10:12 PM #62
Pabst13 Pabst13 is offline
Pabst13 is on a distinguished road
Rear window will not lower/raise with key
I just replaced my rear hatch with used door. The only thing I switched from my old door was the key switch. On my old door, the interior switch, key fob and door key switch all worked. Right now, the interior switch will raise and lower the window, but automatic doesn’t work. The key fob will not move the window and the key will not open/close the window from the rear hatch. The key will unlock/lock the doors though. Is there a component that specifically only does the key switch/key fob and automatic functions of the window? I also tried resetting the window and nothing changed. Thanks!
Pabst13 is offline   Reply With QuoteReply With Quote
Old 12-26-2021, 09:34 AM #63
coachhomer coachhomer is offline
coachhomer is on a distinguished road
So I have a similar issue but dont think the solution is the same. My passenger side window will not roll down from the drivers side panel but it will roll down from the passengers side. The drivers side works for the drivers side just not the passengers. Any thoughts?
Thanks!
C
coachhomer is offline   Reply With QuoteReply With Quote
Old 12-27-2021, 06:45 PM #64
My rear wiper also doesnt work. I’m thinking that the window doesn’t know that it’s closed but it’s not relearning it’s position through the reset.
I already tried putting on the old door ECU which worked with the key switch.
Any help is appreciated!
Old 12-27-2021, 10:51 PM #65
Thanks!
C
No one has this issue?
Old 12-31-2021, 01:50 PM #66
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
Sounds like the switch for the passenger's side window on the driver's side door maybe bad, or not getting power.
2004 Limited V8
Old 01-23-2022, 11:44 AM #67
Bsdncorco Bsdncorco is offline
Bsdncorco is on a distinguished road
Originally Posted by toto View Post
Yes, you need to reset the one-touch features on the power windows and moonroof when you disconnect the battery. The windows use less power to close these days (so they're less likely to crush hands or fingers), so they need to "remember" where the closed position is.
To reset the driver's side power window auto-close:
1. Push down and hold the driver’s door power window switch to completely open the window.
2. Pull and hold up the driver’s door power window switch until the window closes. Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the “one–touch open/close” by pushing the switch briefly to the “DOWN” and “UP” positions.
To reset the moonroof one-touch operation:
With ignition switch in the “ON” position, do the following:
1. Push and hold the “TILT UP” side of the switch until the moon roof tilts all the way up and then tilts down slightly (approximately 10 mm [0.39 in.] at the rear).
2. Check for proper operation of the “one–touch slide open/close” and “one–touch tilt up/down” functions by pushing the switch briefly to the “SLIDE OPEN” and
“TILT UP” positions.
To reset the rear window operation:
1. Turn ignition switch to the “ON” position.
2. Push the back door power window switch to the “DOWN” side to open the window.
3. Push and hold the back door power window switch to the “UP” side until the window closes. Continue holding it for approximately 1 second.
4. Check for proper operation of the “one-touch open/close” functions by pushing the switch briefly to the “DOWN” and “UP” position.
The compass will also need to be reset if you disconnect the battery. Instructions for that are in the Owners Manual. You need to look at a map of the country to determine which zone you're in, and the instuructions are slightly different for 2003-2006 vs. 2007-2009.
I also wanted to share that my rear defroster/defogger was not working until I went through this process for my driver side window auto open/close, rear window auto open/close and sunroof auto open/close. Once that was done my rear defroster/defogger button start working again.
Bsdncorco is offline   Reply With QuoteReply With Quote
Old 09-16-2022, 05:18 PM #68
laylam laylam is offline
laylam is on a distinguished road
I had the same issue a while ago, it did it for a week or two & doesn’t do it anymore. I think it was just a temporary issue
laylam is offline   Reply With QuoteReply With Quote
Rear Window not Working?? okkin 4th Gen T4Rs 21 07-17-2020 09:13 AM
window Auto up/down feature kimboy 4th Gen T4Rs 4 05-12-2005 12:38 AM
'95 Rear window stopped working AznKlique 4th Gen T4Rs 2 03-22-2005 03:38 PM
98 back window wont roll up hamster_13 4th Gen T4Rs 1 01-29-2005 03:07 PM
Power Window Auto Switch 1fastrunner Problems & Warranty Issues 1 11-05-2003 10:24 PM
