Originally posted by wlrunner
The noise is always there unless I press the brake really hard to stop the excess movement when shifting. If it's the auto-level,is it normal? Any part I can lube to stop the noise? Anybody else has the same noise? Thanks.
You are supposed to come to a stop to shift from D to R or R to D.
If you shift while it is still going in the first dorection then your dash lights will come on and the trans will make a grinding/clicking sound.
That sound is the T4R saying "If you keep doing this you are going to break something"
Actually it is the same sound that you hear when you allow the truck to slip backwards after coming to a stop on a hill, taking your foot off the brake and not giving it any gas.
