***FIXED***
I have a '99 4Runner that's been giving me some problems for the past month or so.
1999 4Runner Limited 6cyl 5vz w/ 4WD
270k miles and trying not to limp it to the 300k mile club. Lol
Codes:
P0171 random - doesn't come on reliably when issue presents itself, but on 85% of the time (system too lean bank 1)
P0110 once - only saw this one once (intake air temp sensor)
I believe it to be a fuel related issue whether it's the computer not sending the right signal or something wrong with the fuel injection system.
Symptoms:
Car cranks, battery and starter are strong. Either it will start normally, struggle to start, or not turn over at all.
Pumping the gas pedal really doesn't help unless it starts to turn over.
Car runs like it has no problems at speed, starting and idling are the issue.
Starting fluid sprayed directly into the airbox while cranking worked initially, now it's barely effective at keeping engine running after attempting to start.
What I've done to try and "fix" it:
MAF cleaned
MAF replaced
Throttle body cleaned
Hoses checked for leaks - sprayed starting fluid around engine compartment while running
Fuel filter replaced
Fuel pump tested - removed fuel filter and a ton shot out the open tube while cranking, way more than expected
Front O² sensor replaced
Fuel treatment added to tank x2
Seafoam added to tank
Disconnected battery
Disconnected ecm fuses
Disconnected ecm wiring harness from ecm
Swapped EFI Relay/new fuse
Air filter replaced
---> Fuel Pump replaced
Applicable work done within last 10k miles:
Most recent - timing belt/water pump and had hoses done in last 3k miles
Oil/filter change every 5k miles
Spark plugs, wires, and coil packs
Air filter
Here are some numbers while the car is idling (800rpm) and at 3000rpm:
(Maybe these will help, they don't mean much to me. Lol)
Timing +16° to 24°............+30°
Intake temp 113° F....................117° F
MAP 29 kPa...................30 kPa
MAF 0.7 lb/min..............2.8 lb/min
O² sensor 0.08-.725..............same
Fuel flow 0.5 gal/hr...............1.9 gal/hr
BST VAC -10.7 psi.................-10.2 psi
Fuel trims ST +17.2 to 19.5%.......3.1 to 10.9%
Fuel trims LT +39.8%..................same
Really don't want to replace the engine control module..
Other than that, I'm stumped
Here's a fun pic of the nasty fuel filter that is probably 270k miles old after cutting it open. Helped with the lurching upon quick throttle reduction at speed.
The unhappy 4Runner I want to be reliable again
Any advice is welcome and thanks in advance!
