Old 04-05-2021, 06:46 PM #16
k2damfc k2damfc is offline
k2damfc is on a distinguished road
Trying to bump this post, but still having same problem. I got an oil change the other day and it seemed to help a bit, probably keeping it cooler. But now itís doing it all over again. Iíve replaced TB gasket again, cleaned TB and MAF again. Looking at replacing spark plugs and wires soon, cuz why not, but not sure whatís going on to begin with. Only happens on hot days and usually including elevation.
The kicker this time though was while it started to happen pulling up to a red light, I threw it in park and I could feather the gas pedal and it kept revving up like it should, then when I put it into gear it died down almost right away. Got thru the light, so I could pull over somewhere decent, by just keeping the pedal 3/4 of the way down and let it jump a few times to get me thru. Once thru the intersection it didnít seem to want to die right away.
Any help would be great. Thinking of doing the evap canister delete to see if that helps. But Iím not sure. It just feels like itís starving for gas, Iíve slammed a pedal once or twice in my life and usually smell gas real bad if I did it too much, but I donít get any smell.
Things replaced since:
Fuel pump
Fuel sending unit
Fuel filter
TB gasket
Pressure valve selenoid on fuel rail
k2damfc is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 12:07 PM #17
spartacus's Avatar
spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold
spartacus's Avatar
Fuel pump
Fuel sending unit
Fuel filter
TB gasket
what year gen ? Cleaning the iac and testing the tps would be my next suggestion.
Driving down hill, shifted into lower gear? cwest94 4th Gen T4Rs 6 11-08-2007 09:48 AM
Driving in Mexico - OK or terrible? spud72 4th Gen T4Rs 21 09-26-2007 06:18 PM
Hella 500, or any other driving lights for that matter... hulk311 4th Gen T4Rs 4 05-01-2007 10:30 AM
Use The Oem Nav System While Driving LukeSKY Engines / Suspension / Wheels / Tires / Audio / Accessories 9 05-03-2006 12:28 PM
Rear door auto lock while driving? slam_w2k 4th Gen T4Rs 1 10-16-2005 02:24 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
