Old 01-21-2007, 11:55 AM #16
RickyCRX RickyCRX is offline
RickyCRX is on a distinguished road
Just a slight suggestion -- if your hoist can't raise the engine high enough, you can always take the front wheels off of the vehicle, put two large floor jacks under the frame/suspension, and lower the jacks all the way down as low as they'll go. It will probably lower the vehicle a good extra 6-12 inches over what you'd get if you just left the vehicles on its regular tires.
Just a thought, in case you need just that tiny little extra clearance.
Ricky
2003 2WD Galactic Grey V8 Sport
RickyCRX is offline   Reply With QuoteReply With Quote
Old 01-21-2007, 01:26 PM #17
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
Originally posted by ysrsquid
When the engine first started knocking (really knocking to the point that there was no guessing if there was a problem) I had the car towed to a dealership. The dealership was going to drop the pan to take a look. They called back 1 hour later to say that the whole motor has to come out to drop the oilpan. The dealership wanted $1200 just to pull and inspect motor. They also quoted $8600 to pull and repair motor so I said, "No thanks. Looks like I'm pulling my own motor."
At this point the transmission is ready to come out. I decided to drop it separately from the engine because I don't want to tear anything up on the way out. I'm fairly concerned about breaking a A/C line. Also, I don't know if my engine hoist would be able to raise the engine + transmission high enough to get them out of the truck.
Besides, at this point the transmission's ready to come out. I have only a couple more of the engine/transmission mounting bolts left before dropping the transmission. After the transmission, I'll probably pull 1 or both exhaust manifolds and then the motor will be ready to come out.
If the bearings could have been replaced with the motor still in I would have left it at the dealership for them to do. But since the motor needs to come out (for either rebuild or replace), I'm saving some cash by doing the work myself.
I do agree that I am concerned about the crankshaft. Hopefully it isn't too damaged and hopefully it can be turned down if it is scored.
Wish me luck! Dave
From my experience, it is usually not necessary to remove the trans when pulling a motor. You didn't specify, but I am guessing you have a 2wd, not a 4wd, because it is a lot more difficult to pull the 4wd trans. If you just pull the motor, you shouldn't have any problem with the lift height of most engine hoists. The suggestion to remove the front wheels to lower the front end is interesting, but once you do that, you will have a problem getting under the vehicle for any last min adjustments or missed connections. And I have found that the first time you pull an engine, or a new type of engine, you usually forget something underneath. If you can get your hands on a shop manual, it will give you a good, step by step set of instructions on removing the engine along with engine rebuild info.
Good luck.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 01-21-2007, 02:34 PM #18
Well, if that's an issue and you forget something, just raise the vehicle back up. You typically will only lower the vehicle down when you're sure the engine is completely free and you're ready to move it completely away from the vehicle. By that point, you should have the engine out high enough anyways that you'll see there's nothing else connected.
I've done many (at least 6-7) engine swaps that way with CRXs where I'll get the engine up mostly free of the engine bay, then I lower the car down and push it back out of the way, then I lower the engine to the ground. This was the case when I had a fixed hoist attached to the roof of the garage and didn't have one with wheels. The car itself had to roll, as rolling the engine away from the car wasn't an option for me.
Ricky
Old 01-22-2007, 06:31 PM #19
TechWrench's Avatar
TechWrench's Avatar
Ricky
I can see how that method would help if you have a fixed chain hoist with low overhead clearance. I am lucky enough to have a freestanding engine crane, that rolls. Now all I need is a garage I can work in.
Old 01-23-2007, 10:34 AM #20
ysrsquid's Avatar
ysrsquid ysrsquid is offline
ysrsquid is on a distinguished road
ysrsquid's Avatar
Good luck.
My 4Runner is a 2WD. I pulled the transmission last night so no turning back now. All I have are the engine mounts to go and the engine comes out.
ysrsquid is offline   Reply With QuoteReply With Quote
Old 01-23-2007, 12:22 PM #21
TechWrench's Avatar
TechWrench's Avatar
Hope it all goes well.
Old 01-23-2007, 01:02 PM #22
ysrsquid's Avatar
ysrsquid's Avatar
OK just a test to see if I can upload pictures into my post. Success! Seems to work just like described in thread http://www.toyota-4runner.org/showth...threadid=19549
In general, this isn't a view that most people want of thier recently purchased 4Runner. This is the driveshaft tunnel with the transmission dropped down.
Here's my handy-dandy A/C condensor protector. Overkill... maybe but at least I won't be hitting the condensor as the engine comes out.
Old 01-23-2007, 03:10 PM #23
Here's just a thought, but if that engine is pretty much toast when you get it out and look at it more closely, have you thought about doing a V8 swap?? I'd love to throw one of the new Tundra 5.7L V8's into one of these 4Runners.
Ricky
Old 01-23-2007, 05:17 PM #24
Fro-Runner's Avatar
Fro-Runner Fro-Runner is offline
Fro-Runner is on a distinguished road
Fro-Runner's Avatar
Ricky
Yeah, I was thinking the same exact thing except using the current V8 4.7L setup. You have ONE problem by going this route. You stated that you have the 2004 V6 Limited edition. If I am correct, all 03-04 V6 Runners came with the 3rd generation 4-speed transmission. The 05's and beyond come with the same 5-speed tranny as the V8's.
By doing this engine swap, you would have to update your ECM to recognize the new shift points. This is where you are in luck as the 02-06 Sequoia's used the same 4-speed tranny as our 03-04 V6 Runners.
You would probably have to do an update on the MAP air flow sensor, etc to keep the CEL from coming on. Then again....... this computer may just be smart enough to relearn the parameters of the new V8 and match the old trusty 4-speed tranny with it. This might be probable since you will have the battery disconnected for a period of time.
If it was me, as I hate the way my V6 engine ticks and rattles like a 50 ft. tall grandfather clock, I'd opt to buy a 4.7L V8 and use the Sequoia's manual to see the bolt setup for the engine to tranny. You will now have the oil filter located under your engine instead of on top.
Good luck in your overhaul or engine replacement..... whichever route you choose. I hope this never happens to me!
---2004 Galactic Grey SR5 4X4 V6 w/ Factory moon roof, Toyota carpet floor mats, Emergency kit, first aid kit, cargo net.
---My Mods: Rear spoiler w/ LED brake light, 17"Sport Edition rims upgrade w/ wheel locks, hood bug deflector, 3M stick-on dark gray tinted side window visors, smoked moon roof visor, polished stainless exhaust tip, Scion HU T1804, DRL's, Toyota seat covers, Factory RS3200+ Security alarm, 2nd Ashtray for extra plug, OBX racing pedals, De-badged front doors, Rear Bumper red lens mod (Stop and Tails only), front chrome Strona Bull bar, Nerf chrome side step bars, upgraded to the 7500 lb Hidden Tow Hitch.
---Future mods and wish list: 2-3" Donahoe Coilover lift spring shocks with a 1" Roger Brown body lift, Donahoe or Total Chaos control arms, bigger & better tires after the lift, A rear protection bar and Reverse sensors, or a backup camera.
Fro-Runner is offline   Reply With QuoteReply With Quote
Old 01-23-2007, 05:39 PM #25
ysrsquid's Avatar
ysrsquid's Avatar
Man I just want to get the truck running again. I'll save the engine swaps for one of my other cars.
Hopefully I have the time to get the motor out this weekend. If so, I'll begin to see 'the damage'.
My wife asked me what I was planning on getting her for Valentine's Day. I was thinking of gift wrapping the failed bearings and putting a bow on them.
Anyway, I'll post pictures when I find the damage. Later, Dave
"No matter how bad it gets you can always drink"
'04 4Runner Limited (Running Again on Motor #4 - Long story but posted on 4Runner.org website)
'92 BMW 325ic
'88 BMW 528e
'68 Firebird Conv
'96 Ducati Monster M900
'88 YSR 50 (race bike-SOLD to Endurance Racing Partner)
Old 01-23-2007, 11:08 PM #26
jharris2 jharris2 is offline
Super Moderator
jharris2 is on a distinguished road
Super Moderator
Dave -
Then what would you plan on doing after you come to??
2003 SR5 V6 4WD Titanium with cladding
jharris2 is offline   Reply With QuoteReply With Quote
Old 01-25-2007, 06:36 PM #27
ysrsquid's Avatar
ysrsquid's Avatar
Originally posted by jharris2
Dave -
I hadn't thought about it but maybe I should be ready to run after she opens her 'present'.
'92 BMW 325ic
'88 BMW 528e
'68 Firebird Conv
Old 01-28-2007, 06:40 PM #28
ysrsquid's Avatar
ysrsquid's Avatar
Update - Motor Out. Let the fun begin
Well the motor came out yesterday. I'm glad that I pulled the transmission because I think that in the long term it made the engine comeout easier. BTW, I left the exhuast on. I also unbolted the air shocks for the hood (and removed some small trim panels at the rear corners of the hood) to get the clearance needed to remove the engine.
I also pulled the oil pan to begin searching for the damage. Once the oilpan came off I was immediately greeted with lots of metal shavings.
I checked the rod bearings because that's where I was expecting the damage. The rod bearings were bad but there was no damage to the crank. That's where the good news ends unfortunately.
I pulled the rear main bearing cap this morning. The bearing had spun and eaten the crank and the main cap. At this point I don't even know if the bottom end of the motor is salvageable. I haven't looked at any of the other main bearings but I guess I've now got a pretty good baseline of the damage.
'92 BMW 325ic
'88 BMW 528e
'68 Firebird Conv
Old 01-30-2007, 01:18 PM #29
Bluto's Avatar
Bluto Bluto is offline
Bluto is on a distinguished road
Bluto's Avatar
Sorry to read and see the bad news. If you need to look for parts or a replacement ....
http://www.car-part.com
I hope everything works out.
Bluto is offline   Reply With QuoteReply With Quote
Old 01-30-2007, 05:00 PM #30
ysrsquid's Avatar
ysrsquid's Avatar
Bluto, That's an awesome link for finding an engine. I had come across a couple of engines (ebay, other sources) but nothing in Texas. Everything was in North or NE.
I haven't given up on the engine yet. I took the spun bearing and cap to my buddy's shop and his analysis was "Not that bad." He recommended taking the crank (which will need to be turned) and the caps down to a machine shop in S. Austin for thier analysis of the damage to main journal of motor. Hopefully the motor doesn't have to be align bored.
So at this point I am disassembling bottom end to get the crank out. I got the timing cover off last night but I haven't taken off the timing chain.
Questions:
1 - How is the main timing chain removed?
Answer - Remove Tension from Tension Assy. Remove center idler pully.
2 - How is tension placed back in the chain during reassembly?
Answer. Turn latching mechanism. Push the piston back in.
3 - Is there a specific tool for removing the main bearing caps? They're almost pressed into the block...
Answer - Nope. Manual says to pry out with screwdriver. Just don't bugger up mating surfaces.
Thanks,
Dave
'92 BMW 325ic
'88 BMW 528e
'68 Firebird Conv
Nissan Pathfinder vs. 4th gen 4Runner Jed 4th Gen T4Rs 49 11-03-2010 02:51 PM
New Member - Looking to purchase a 4th Gen 4Runner Giskarded 4th Gen T4Rs 17 12-17-2009 01:41 AM
4th gen 4runner gauges whoosh Classifieds - buy & sell (no commercial ads please) 1 12-13-2009 02:05 PM
03 Taco Dcab vs. 4th Gen 4Runner headleyj 4th Gen T4Rs 3 08-19-2008 01:06 PM
4th Gen 4Runner Exhaust/Sunroof fault seamaster32 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 11-03-2003 10:29 PM
