Thread Tools Rating: Thread Rating: 164 votes, 2.52 average. Display Modes
Old 05-22-2018, 05:05 PM #1
beefsix beefsix is offline
beefsix is on a distinguished road
Unhappy 96 4Runner SR5 white smoke coming from exhaust, black soot/liquid coming out, stalls
Hello,
I recently bought a 4Runner and changed out valve covers and fuel injectors. Now when I start it up, it starts up fine, then chugs along and starts to spew some white smoke along with black soot mixed with water coming out of the tailpipe. It smells like fuel, almost. The engine will also stall out. Seems to do ok if I rev it but I haven't taken it for a drive yet. Was wondering if anyone can help me troubleshoot or give me some direction. Thank you so much. Heres hoping she runs soon, because this is getting annoying :-)
beefsix is offline   Reply With QuoteReply With Quote
Old 05-23-2018, 12:01 PM #2
Update: I pulled left bank of spark plugs (cyl 1, 3, 5) and they are black with cyl 5 visibly having fuel on it. They all smell like fuel. Also, these are brand new injectors. Intake smells like fuel as well.
Old 05-24-2018, 08:42 AM #3
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Saw your post and feel your frustrations, but this is another a 4runner specific issue, it's combustion engine 101
Start with the basics, compression test, vacuum leave check, pcv valve check, etc, and work up from there.
Any codes being thrown?
Sent from my Pixel XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-24-2018, 09:27 AM #4
No codes yet. Engine will go from 1k+rpm at ignition and starting, then after a few seconds slowly crawl to 500. Then after running there for a bit, she dies.
I had a friend telling me I screwed up the vacuum lines, but I’ll be going in and checking today. Then I will check the o-rings on the (cheap) eBay fuel injectors. My guess is one of em may be stuck open. Then, I’ll do a fuel pressure check.
Also - I did replace the Pcv valve. However, where it hooks up to on the TB still seems super grimy. Would that be an issue that would cause this? Lol.
Old 05-24-2018, 10:47 AM #5
tystaco's Avatar
tystaco tystaco is offline
Real Name: Tyler
tystaco is on a distinguished road
tystaco's Avatar
Real Name: Tyler
Did you check the IAC valve that is attached to the bottom of the throttle body? If you cleaned the throttle body but didn't pull this off and clean it separately, you might be plugged up.
You can also check that the gate on the valve is working once you have it off by getting some wires and providing it 12V from the battery. IF you are sure what I am talking about, use the alternative google search with IAC valve and you'll find plenty of threads.
1999 T4R Limited (Mine)
2000 T4R Limited (Wife's)
2004 Tacoma Xtra Cab TRD
tystaco is offline   Reply With QuoteReply With Quote
Old 05-24-2018, 11:12 AM #6
I did take the IAC valve off and even replaced the gasket. I'll take it off again and see if maybe I'm an idiot or screwed something up.
Old 05-24-2018, 02:40 PM #7
For what it's worth I tried cleaning my IAC twice and ended up just replacing it with a $30 unit from eBay which is been going strong for over a year now. This solved all of my idle issues
Old 05-24-2018, 03:44 PM #8
i'll keep that in mind. I bought some cheap fuel injectors from eBay. Retested my old stock fuel injectors and the ohms are fine. I'm gonna send 'em to WitchHunter. I'll also look into a new IAC. Other one looks old.
For what it's worth your build thread was the first one I ever looked at on this site. This made me want to get a 4Runner. :P
Black soot on exhaust tip. What does it mean? alext72888 5th gen T4Rs 9 03-07-2017 02:43 PM
03 V6 stalls when coming to a stop dta1984 4th Gen T4Rs 4 09-01-2015 09:22 AM
'93 4Runner White Smoke coming from exhaust. bonzairy Problems & Warranty Issues 1 06-08-2015 02:16 PM
Another Vegas TRD Pro 4Runner Coming Soon - Bright White VegasTRDProRunner New Members 3 11-23-2014 01:44 AM
White Smoke Coming Out Of Exhaust silverwave Problems & Warranty Issues 3 07-01-2005 03:51 PM
