Old 07-07-2018, 03:09 AM #1
AZDesertRat AZDesertRat is offline
AZDesertRat is on a distinguished road
Help! Insanely squeaky front suspension! OME BP-51
Hello all and thanks in advance for any advice or info!
I've got a 5th Gen, T4R SR5, 40K miles
Suspension: OME BP-51 system front and rear
My problem is over the course of the past week I've developed a loud squeak or creaking noise and I believe it's isolated to the passenger front. The OME suspension system has been quiet and flawless for the 20K miles that I've owned it and was installed by the previous owner.
The noise sounds like an old metal bed frame squeaking and as previously stated it's been getting worse over a weeks time. It makes the noise anytime there is any movement with the cab and can be duplicated just by getting in and out of the vehicle.
I've already tried greasing, lubricating, cleaning etc. any and all parts of that passenger front suspension system including all control arm bushings and ball joints....and the noise hasn't changed!
The vehicle has been lightly used and all the bushings throughout the front end look good. I can't pin point exactly where the noise is coming from because it's so loud and vibrates all the components in that area.
Since I've already tried lubricating everything without success I'm left wondering if it's the shock itself and maybe something internal with it? The vibrations from the squeak are definitely resonating within the coil and the shock but I can't tell if it's moreso than what I'm feeling thru the control arms at same time.
Thanks again in advance for any advice or info! Jim-
AZDesertRat is offline   Reply With QuoteReply With Quote
Old 08-21-2018, 10:00 AM #2
Cletus_G Cletus_G is offline
Cletus_G is on a distinguished road
man, my 2014 SR5 Premium with about 38,800 miles just started doing this, only from the drivers side. Stock suspension with a spacer lift.
truck rides great, just makes that squeak over small bumps and when making left turns.
i can shake the truck (standing on the running board, and shaking it like a monkey) and i can get it to replicate the sound.
did you happen to get anything figured out?
Cletus_G is offline   Reply With QuoteReply With Quote
Old 08-21-2018, 02:21 PM #3
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
On my former truck, the "old bed" creaking was caused by a worn out ball joint.
And check the shocks, a blown out shock sounds just like that too.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 08-21-2018, 11:05 PM #4
Jeffy's Avatar
Jeffy Jeffy is offline
Jeffy is on a distinguished road
Jeffy's Avatar
Check and grease/ lube the rear suspension too... I was hunting down a squeak that I was positive came from the front end but ended up being my rear LCA. Sometimes those noise just travel.
2011 SR5 Pelfreybilt :: Radflo :: Total Chaos :: Stubbs Sliders :: Prinsu :: RB BL :: 34x10.5 BFG T/A KO2 :: Rockford Fosgate, JL Audio
Jeffy is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 08:00 AM #5
jfa1081 jfa1081 is offline
jfa1081 is on a distinguished road
Did you ever figure this out? I’ve been eliminating things and I’m starting to think it’s the coilover.
jfa1081 is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 02:27 PM #6
mbmellis mbmellis is offline
mbmellis is on a distinguished road
Same problem on 2018 Offroad KDSS OME BP-51.
MBM
2007 Limited - 2012 Limited 7 Passenger - 2013 Limited 5 Passenger
2018 TRD Offroad. OME BP51 lift. 275/70R17 BFG KO2 (wrecked)
2022 TRD Offroad (Stolen)
2024 TRD Offroad
mbmellis is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 06:10 PM #7
RidgeRunner4 RidgeRunner4 is offline
Real Name: Tanner
RidgeRunner4 is on a distinguished road
Real Name: Tanner
Unhappy
HELP! I’ve been having this same exact problem. 2015 SR5 with OME BP-51s, Camburg UCAs, Drit King LCAs. The squeaks are coming from the front end, both sides and are very loud and constant, it’s driving me up the wall. It started about a month ago and I’ve been chasing it with lubricants and grease and most recently time and money.
I just replaced the bushings on the upper control arms and brand new ball joints pressed into the uppers. ZERO change. I felt sure it was the bushings.
The only thing I have found to make the squeaks go away is to douse the front end with the hose. It goes away for a day or two and then right back to Squeaks McGee. The local shop said it was coming from “the off-road coilovers” Any information or past experience would be valuable. I’ll sell the car if I can’t make it go away, it’s that bad.
RidgeRunner4 is offline   Reply With QuoteReply With Quote
Old 11-07-2021, 01:03 PM #8
I am reliably told the problem is the heim joints on BP51 shocks, which is the bottom of the shock, in what I would have thought was a bearing/bushing. Have not figured out how to order a new one and replace though.....
Check out this great fix video. ARB BP51 Suspension Squeak | How to Replace the Spherical Bearings and fix the Problem. - YouTube
MBM
2024 TRD Offroad
5th gen , bp-51 , ome , suspension help , suspension noise
Squeaky suspension FIXED falkon240 4th Gen T4Rs 1 06-04-2018 05:56 PM
squeaky suspension/coil? 08 Hilux Surf 4th Gen T4Rs 2 07-19-2013 02:25 PM
squeaky front end twocircles 4th Gen T4Rs 0 12-31-2012 05:57 PM
03 4runner squeaky front suspension sshick 4th Gen T4Rs 1 10-04-2008 12:36 AM
Insanely annoying loose vanity/sun visor shawner2713 Problems & Warranty Issues 2 05-02-2008 09:02 AM
