Old 08-20-2018, 12:28 PM #1
ggrant ggrant is offline
ggrant is on a distinguished road
Unhappy Fuel pump or fuel pressure regulator?
Hey guys need help here..call me crazy but I am restoring my 99 4runner Limited 4x4 with 330k on it....it is family.
Here's the issue: at cold start it has a rough idle for about 15-20 seconds that then goes away. I have also noticed a very "rich" gas smell also when it does this. Also when accelerating onto the freeway it acts as if it is gasping for fuel but not getting it. Just had the the heads rebuilt and all seals and gaskets replaced this winter due to a burnt valve on #4. 2 cylinders have 150psi and the other 4 are at 125. Darn near everything has been replaced over the last 12-18 months. Once it is warmed up the rough idle goes away at start up. Any help would be greatly appreciated. THANKS!!!!!
ggrant is offline   Reply With QuoteReply With Quote
Old 08-24-2018, 07:15 AM #2
blanchard7684 blanchard7684 is offline
blanchard7684 is on a distinguished road
A sensor is not reading right and telling the ECU to run way rich or way lean.
An injector may be stuck as well.
Pull plugs and check for excessive richness.
Or get a code reader and check for any codes.
Possible list of sensors that can do this:
MAF, Eng. coolant, intake air temp sensor.
When cold your ecu "ignores" feedback from o2 until certain engine temp. don't think its o2 sensor related.
You can also get a fuel pressure test to rule out fuel pump just to be certain. but most fuel pumps would have insufficient flow at all engine conditions.
blanchard7684 is offline   Reply With QuoteReply With Quote
Old 08-24-2018, 12:19 PM #3
Spktyr Spktyr is offline
Spktyr is on a distinguished road
I second that - get a code reader and pull codes. If that doesn't work get a Wifi OBD2 adapter (~$20) to connect to a computer or phone/tablet so you can see things like fuel trim in real time and perform better diagnosis.
Spktyr is offline   Reply With QuoteReply With Quote
Old 08-24-2018, 02:50 PM #4
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
is it using any coolant? do you ever have to add any?
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-29-2023, 10:54 AM #5
Cookie1498 Cookie1498 is offline
Cookie1498 is on a distinguished road
2002 limited. Good fuel pressure out of tank (42-48psi). Engine starts and shuts off within a few seconds. Regulator or injectors? Or is there something else stopping fuel flow?
Cookie1498 is offline   Reply With QuoteReply With Quote
Anyone Had A Fuel Pressure Regulator Go Bad? RiFF RaFF Classic T4Rs 9 04-29-2022 11:03 PM
95 Fuel Pressure Regulator Install smallstar Classic T4Rs 6 03-04-2022 10:42 AM
1st Gen Fuel Pressure Regulator Source?? eimkeith Classic T4Rs 8 10-30-2016 04:34 PM
fuel pressure regulator Schady44 3rd gen T4Rs 4 03-11-2014 09:34 PM
Fuel Pressure Regulator billsheila 3rd gen T4Rs 0 10-20-2010 09:11 AM
