Old 03-10-2007, 02:49 PM #1
subversive1 subversive1 is offline
subversive1 is an unknown quantity at this point
Car won't start
hello everyone i'm new here and i just had a problem with my car its an 05 4runner. it won't start it just clicks when i turn the ignition key, along with the clicks all the lights flash on and off as if with each click i'm flipping a light switch. after a while the battery just dies. but after i let it settle for about 10 min. the battery power is fine. i tried hooking it up to a battery charger when the battery was low and it would do the same thinkin the charger wasn't working i hooked it up to a car and still the same thing happened. my suspicion is that i triggered some sort of a kill switch from my alarm and i can't get it to reset. i tried disconnecting the battery, just the positive side but that didn't work. if somone could help me out i'd greaty appreciate it i really don't want to have my car towed and pay a mechanic to check it out and i need my car as it is my only transportation for my family and i.
subversive1 is offline   Reply With QuoteReply With Quote
Old 03-10-2007, 06:35 PM #2
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
Is your car not under warranty?
You can check all your fuses to see if any are blown.
Do you have another key you can try? Maybe the key you normally use is defective and the programming got corrupted so your truck won't start.
sharp4runr is offline   Reply With QuoteReply With Quote
Old 03-10-2007, 06:56 PM #3
greasefingers's Avatar
greasefingers greasefingers is offline
greasefingers is on a distinguished road
There is a 7.5 amp starter fuse labeled STA in the fuse block under da hood. That is the only fuse that you need to check, but I agree the security system seems whacked
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
greasefingers is offline   Reply With QuoteReply With Quote
Old 03-10-2007, 08:34 PM #4
Mark86's Avatar
Mark86 Mark86 is offline
Super Moderator
Mark86 is on a distinguished road
Super Moderator
Mark86's Avatar
Do you have an aftermarket alarm or remote starter? If you do, I would suspect those two things could be causing the problem.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
Mark86 is offline   Reply With QuoteReply With Quote
Old 03-10-2007, 09:27 PM #5
ok so i just got back from my mechanic and i feel kinda stupid. so the tow truck came and i told him my story and he tried to turn on the car. he said its not the alarm its the battery. he hooked up his charger and it didn't work so then he hooked up his tow truck a big F550 and it started. he said that my battery is jacked up and that i should go get it tested. i took it to my mechanic and he said that the battery was reading 12 volts but that it had a short. so he switched my battery and miraculously everything was fine. thanx everyone for the replies.
Old 03-11-2007, 09:46 AM #6
Well one would not suspect the battery on a 2005 model vehicle. My Panasonic battery will be 4 years old this June. I will replace it in December, if it needs it or not.
Car washing no-no's buck_sez Maintenance/Detailing 4 11-11-2009 12:14 AM
How long to wait after starting engine in cold weather? keylay31 General Discussions 138 08-31-2009 03:57 PM
New 03 V8 4runner Owner with Questions (56k No Way) sciff5 4th Gen T4Rs 6 08-31-2008 10:12 PM
my 92 wont start 4runnerlover 4th Gen T4Rs 6 01-31-2007 03:07 PM
THE Meguiar's Professional Way to Detail your Car or Truck okkin Maintenance/Detailing 6 11-27-2004 10:42 PM
