08-09-2009, 02:48 PM
Left Blinker Problem *NEED HELP*!
Hi all,
Hope the summer is going awesome for everyone!
I noticed yesterday when I locked my truck with the fob..the left blinker turn signal light was not flashing.
I jumped in the car and used the left turn signal and the turn signal light was not flashing and the green arrow on the dash was clicking reallly fast . I tested the right turn signal and everything worked normal and the green arrow moved normal and blinked fine.
This afternoon I jumped in and the left turn signal works and the blinker works normal now??? It seems fine? What was the problem??
What do you think this is? Bad fuse? Bad turn signal bulb? loose bulb? I am nervous now that there is a issue.
Any Ideas? What should I do?
Silver 2004 V8 SE Leather
3/2 Cornfed lift
Spidertrax spacers
33" Cooper STT's
08-09-2009, 02:50 PM
The fast turn signal to me indicates the fuse for the turn signal is going. At least all the other cars I've owned I've found this.
Have a look in the T4R manual and see where the fuse is.
I'm sure others on here will offer more indepth insight.
2007 4runner Sport Edition V6, Black.
2011 BMW 335Xi Special Edition, Jerez Black.
08-09-2009, 03:38 PM
.. left turn signal and the turn signal light was not flashing and the green arrow on the dash was clicking reallly fast ..
Were both front and rear left turn signal light not flashing? also do you have DRL in your turn signal lights?
2017 SR5 4WD - Blistein 5100s - Cooper AT3s - HID Lows - LED Fogs
2003 SR5 V8 - Sold
08-09-2009, 04:19 PM
Banned
Banned
Check both. Bulbs and fuses.
08-09-2009, 04:37 PM
First place I'd look is the bulb.
2006 Limited V8 4x4, Shadow Mica/Stone
08-09-2009, 04:51 PM
Banned
Banned
I'd look at the fuse first. It's easier to get into and replace.
08-09-2009, 11:39 PM
Super Moderator
Super Moderator
I am 100% sure that it is the sign of a failing bulb. The blinker should flash very quickly if one bulb is burnt. On my parents GX, the left signal bulb started to fail intermittently and finally went a week or two later. This occurred when the truck was 1 year old.
It is funny because the left signal bulb decided not to work for 30 minutes during our road trip. Luckily, it came back on after an hour or so. I am starting to wonder if this issue was related to the severe rain storm we drove through.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
08-09-2009, 11:50 PM
It would be a bulb or wiring problem, fuse would cause multiple lights to be out.
08-10-2009, 10:08 AM
Most likely a bulb issue. The filament in the bulb is broken on one side and re-attaching itself every now and then.
08-10-2009, 11:15 AM
Agreed it is likely a bulb issue. 'Fast blinking' indicates a malfunctioning or burned out bulb 99% of the time - on all modern makes and models.
If it were the fuse, it would not be affecting just 1 bulb (would likely be affecting all turn bulbs on all corners, parking lights too, maybe even more).
If it happens again, park, check to see which lights are working and which aren't. My bet says it is a lone turn signal bulb.
2008 Limited 4WD V8 - Titanium Metallic
Factory Nav Sys, Moonroof, Adjustable Height Control, X-REAS, most everything but rear-seat DVD system...Sirius Sportster 4 controlled via Nav Sys with Sirius Toyota interface and SVCDOC1
08-10-2009, 08:10 PM
Thanks guys for all your info!! I will check the fuse...and the bulb....and give a update...hope its the fuse..
is it hard to get into the left turn signal bulb casing?
3/2 Cornfed lift
Spidertrax spacers
33" Cooper STT's
08-10-2009, 11:46 PM
Super Moderator
Super Moderator
You can either access the bulbs from under the hood or from underneath the truck. It is not too hard.
Mark
08-12-2009, 02:59 AM
Super Moderator
Super Moderator
It's going to be a bulb, more likely than a fuse.
I disagree, it's much easier to check a bulb. Put the signal or hazard on and do a walk around.
Most Japanese cars when the signals flash rapidly, it's a indication a bulb has gone out. You should replace the bulb quickly as extended rapid flashing will shorten the flasher's life.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
08-12-2009, 06:47 AM
Thanks!....The bulb it was! Took 5 mins.!
3/2 Cornfed lift
Spidertrax spacers
33" Cooper STT's
05-31-2015, 04:56 PM
Turn signal is out but don't think it's the bulb/fuse
Hi all,
I have the same problem with my 04 except it's with the right side turn signal. It is also DRL. I've tried replacing the bulbs, I checked the fuses and no
problem, and I even replaced the bulb connector! Nothing has worked that I've tried. The back blinker is working but it's blinking really fast and as well as
the green arrow on the dashboard. Do I have a wiring or grounding problem? Help!!!
Reason: spacing
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
