Old 06-18-2019, 11:40 PM #1
boomtown757 boomtown757 is offline
boomtown757 is on a distinguished road
Lost acceleration while driving.
Today while driving, I experienced a very sudden loss of acceleration. I attempted to press the accelerator with no response at all. After pulling off the road, the engine died as I came to a stop. I attempted to start the engine, but it would only turn over, i only got it to start once in the hour that I was waiting for a tow, it ran for about 20 seconds before dying again. The engine will turn over, but will not start. After getting it home, I removed and cleaned the MAF sensor with MAf sensor cleaner, let it dry, and reinstalled it. This seemed to fix the issue, as the engine fired up like normal on the first attempt. About an hour later I went to start it again, only to find it turning over , and not starting, in the same manner as when the engine initially died. As far as I can tell, it isnt a battery issue as I still have power to everything. My questions are, has anyone seen this before?, what could be causing this?, and what is the best cousre of action to fix the issue? For reference it is a 2005 SR5, with 192K miles on the 4.7L V8.
boomtown757 is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 06:24 AM #2
Spec-7 Spec-7 is offline
Spec-7 is on a distinguished road
From the outside looking in and with no experience with those specific engines, it sounds like a fuel delivery issue. I had a Nissan that would do like that and it was due to a clogged fuel filter and the fuel pump dying a slow death. With the ignition switched on for long enough, the fuel pump would prime and eventually build enough pressure to start the engine, but it couldn't maintain adequate pressure to keep the truck running.
Hopefully others with more experience with this engine chime in soon, but if you choose to investigate the fuel delivery start at the injectors and work your way back.
2018 T4R Silver SR5 4x4
Spec-7 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 06:01 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Has the timing belt been replaced recently?
If so one other member had a very similar if not an exact experience, his problem ended up being the wire/s for a cam position sensor was routed incorrectly when the timing belt was replaced and had been rubbing on a pulley or something else and wore through grounding out the wire/s, once he isolated it and repaired the wire all was fine.
2004 Limited V8
acceleration , died , engine , issue , start
Lost all electrical power while driving down the road? swheele 3rd gen T4Rs 0 08-14-2017 07:32 PM
T4R suddenly lost power while driving xwhenximxgonex 4th Gen T4Rs 3 07-28-2017 10:27 PM
In memory of those lost and those who have lost SV_Dude Off Topic 5 09-11-2013 09:58 PM
TJM Xray Driving Light - 220mm QH Driving zooroadbaja For Sale: Non-T4R Items 1 05-16-2013 09:35 PM
