Old 09-02-2019, 09:10 AM #1
zhallman zhallman is offline
zhallman is on a distinguished road
2006 leaking antifreeze
I noticed an antifreeze leak on my 2006 Toyota 4runner but I'm hoping it's not a huge expense to fix. I've attached pictures to help identify the spot of the leak, any insight would be appreciated
2006 leaking antifreeze-20190902_081308-jpg  2006 leaking antifreeze-20190902_081303-jpg  2006 leaking antifreeze-20190902_081225-jpg
zhallman is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 09:13 AM #2
The hose runs from the bottom of the radiator to a metal piece where it splits into the engine which is where it is leaking
Old 09-04-2019, 09:20 PM #3
mdusek1576 mdusek1576 is offline
mdusek1576 is on a distinguished road
Is this a v6 or v8?
mdusek1576 is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 10:23 AM #4
Isabella Isabella is offline
Real Name: Isabella
Isabella is on a distinguished road
Real Name: Isabella
You’re leaking coolant. If it leaks when you start the vehicle, check your radiator (Front of the engine behind the grill), water pump(Usually by a motor mount, connected to a belt via a pulley) and coolant lines for leaks. If it only leaks after getting to engine temperature, check the heater core lines for busted hoses, or even a heator core leak (Signaled by wetness in cab, and maybe some leaking outside).
Isabella is offline   Reply With QuoteReply With Quote
antifreeze , attached , identify , leak , pictures
2006 V6 Leaking Radiator Driver Side ArthrusRunner 4th Gen T4Rs 12 02-01-2016 05:09 PM
Leaking Antifreeze…... Clone of the Mean Classic T4Rs 3 04-09-2014 08:16 PM
antifreeze leaking please help. Baker11 Classic T4Rs 10 01-07-2013 01:06 PM
Antifreeze.......... brian4t 3rd gen T4Rs 0 10-28-2011 04:26 PM
Leaking antifreeze packers15 Classic T4Rs 5 01-15-2011 10:29 AM
