Old 09-06-2019, 01:41 PM #1
skiadero's Avatar
skiadero skiadero is offline
Real Name: Christian
skiadero is on a distinguished road
skiadero's Avatar
Fog Lights not turning on
Fog lights are not coming on in my 16 Trail... fuse is okay, not sure what else it could be, they were fine, than nothing. I have the new LED ones that go in the TRD. Any help? Thank you
2016 Trail Premium - Black
skiadero is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 02:42 PM #2
TheLincolnGreen TheLincolnGreen is offline
TheLincolnGreen is on a distinguished road
MY GARAGE
MY GARAGE
Might be obvious, but are you trying with the low beams on? Not sure about the newer ones, but the 3rd gen only works with low beams.
TheLincolnGreen is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 03:32 PM #3
Dillusion Dillusion is offline
Dillusion is a jewel in the rough Dillusion is a jewel in the rough Dillusion is a jewel in the rough Dillusion is a jewel in the rough
Hook them straight up to the battery and see if they even work out of the box.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 04:32 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice Bumbo is just really nice
Bumbo's Avatar
Not sure if these are just bulbs or new lights with relay harness...
Troubleshooting ideas:
Confirm the lights work (connect directly to battery)
Check the relay for function (measure voltage at output and confirm its even switching)
Check for voltage at the switch
Check the switch for function using the continuity function on the meter.
If it's just a bulb, you can connect that directly to a battery to make sure it works. Alternately, put the stock bulb back in and make sure the system as a whole still functioning.
Old 10-15-2019, 11:20 PM #5
hockeygurl39 hockeygurl39 is offline
hockeygurl39 is on a distinguished road
could be a fuse or wiring... hook up to battery I had the same problem
hockeygurl39 is offline   Reply With QuoteReply With Quote
fine , fog , led , lights , trd
Help! Fog lights not turning on KalihiRunner 5th gen T4Rs 15 09-14-2016 07:46 PM
Turning off all interior lights woodyc 4th Gen T4Rs 1 09-28-2009 12:06 AM
2003 Dome Lights--turning on an off? doubled Problems & Warranty Issues 13 06-25-2004 04:58 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
