Old 10-24-2019, 12:13 PM #1
rjordan392 rjordan392 is offline
rjordan392 is an unknown quantity at this point
Windshield Water Spots
Here's a challenge for the old school mechanics:
As I was driving, it started to rain and I turned on the windshield wipers. But at the same time I noticed what looked like water spots. I thought someone had sprayed something when I was parked earlier. These spots affected my visibility by about 10 to 15%. So I applyed a glass cleaner and it 'had no effect. I also applied the cleaner on the interior side.
Next I tried 91% isopropyl alcohol on both exterior and interior and that did not work. Then I applied some cleanser and soft brillo pad and that did not work either.
It's strange that the only time the spots show up is when the windshield gets wet. But as soon as it drys, the spots disappear.
Now these spots are a recent occurance.
So does anyone have any ideas on what I have? It's a 2004 model.
rjordan392 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 03:04 PM #2
UPDATE:
My auto mechanic suspects a problem with the laminate. But he tells me to try vinegar and newspaper. He says that there is a chemical reaction between the vinegar and the ink. If that does not work then I'll have him replace the windshield. The only thing that I question is why spots would occur and not streaks on the windshield?
One other thing that I noticed is that the spots only occur when the windshield is wet and cool. The temperature went up to 85 degrees and when I sprayed water on it at that temperature, the spots were mostly gone. I believe this confirms the mechanics suspicions about the laminate.
Old 10-24-2019, 10:50 PM #3
Now rain is forcast for 10/27 and I believe the newspaper and vinegar will determine if it removed most or all the spots to make it safer to drive in the rain.
I also replaced the wiper blades.
Old 10-28-2019, 10:37 AM #4
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
long-running issue
This has been around awhile for Toyota windshields. I don't know if a Saf-Lite or something replacement would be better or not.
Need to solve this windshield problem once and for all!
Windshield Haze w/ Rain
Hazy windshield update
Windshield hazing
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:44 PM #5
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Might not be the best but I use a buffer and some compound on the rougher side to get waterspots off my wifes Highlander.
Clear in the spots I finished. Takes a bit of time though.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 08:39 AM #6
As a last resort, I applied "Rain X" and the spots did not re-appear. I read a few past threads on windshield problems and they state that this product is applied in the automatic car wash business's and is suspected of causing this problem.
So it looks like I may have to apply it when the spots show up again.
However, I find it difficult to believe that another used everything from gasoline to alcohal and had no success. But then another said he applied rubbing compound and it removed the hazing.
So its still a mystery as to why using Rain X worked for me.
Old 10-30-2019, 09:42 AM #7
GG5thGen's Avatar
GG5thGen GG5thGen is offline
GG5thGen will become famous soon enough
GG5thGen's Avatar
I was told a while back that the cleaner, Zud, was good for cleaning windshields. It might me a little abrasive for some to want to use but maybe in mild strength it would be ok. I haven't tried it.
GG5thGen is offline   Reply With QuoteReply With Quote
applied , interior , spots , time , windshield
Water Spots jmickle11 Maintenance/Detailing 12 01-22-2020 08:05 PM
Water Spots... Help? SleekRunner Maintenance/Detailing 6 04-18-2011 10:19 PM
water spots? SilverBullet01 Maintenance/Detailing 10 05-24-2009 12:13 PM
water spots ! ran Maintenance/Detailing 17 04-05-2008 12:01 AM
got hard water spots? acid rain spots? 4rnr4me Maintenance/Detailing 16 12-30-2007 12:06 AM
