Old 11-18-2019, 05:47 PM #1
pinkstarjess pinkstarjess is offline
pinkstarjess is on a distinguished road
5th Gen 72k Miles, Oil Filter Leaking, Need Help
2013 4Runner with only 72K Miles. I just changed my oil on Friday, second time I've done it myself to save money. First time, with no issues. Changed the oil filter and put in new synthetic OW-20 oil. No leaks on the driveway overnight. Drove it 300(ish) miles and lost about a quart of oil, whole underside and back window is oily.
Oil looked to be coming from top of filter housing. Everything was tightened to torque specs. Removed the filter and double checked that the gasket wasn't double and it wasn't. Replaced the filter and gasket at the bottom of the threading and put back on. But it's still leaking and I'd like to rule out everything before taking it into a shop.
Need help, has anyone else seen this before?
pinkstarjess is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 05:51 PM #2
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all 2016 4Runner SR5 is a name known to all
Real Name: Chris
Maybe a crap is the cheap plastic oil cap? There is an aluminum replacement that's well worth the $20 price tag.
PM ME FOR DEALS ON CORNFED LIFT SPACERS!
2016 4RUNNER SR5 - OEM TRD PRO SUSPENSION WITH 3/8 CORNFED TOP HAT SPACERS & 1" PRELOAD SPACER FOR A TOTAL OF 2.5" FRONT LIFT, 2" CORNFED SPACERS IN THE BACK, FX PRO WHEELS, 295/70/17 MICKEY THOMPSON ATZ P3, WEATHER PACKAGE, NAVIGATION, LED INTERIOR LIGHTS, TRD INTAKE WITH AFE PRO DRY FILTER, BORLA MUFFLER, SPRINT BOOSTER, TYGER SLIDER STEPS, TOYOTA BLACKOUT EMBLEM KIT, TRD PRO GRILL, POLY FRONT AND REAR SWAY BAR BUSHINGS, OEM 3RD GEN REAR SWAY BAR LINKS, REAR DIFF BREATHER MOD, ALUMINUM OIL FILTER HOUSING UPGRADE, OIL CATCH CAN.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 05:54 PM #3
I thought that might be it. Is there a way to check that or too difficult unless fully cleaned and maybe blowing air on it? Also, how could that happen? Too much pressure by a past person tightening it? I guess that would be me because it wasn't leaking before me.
Old 11-18-2019, 05:59 PM #4
Real Name: Chris
Real Name: Chris
Crap was supposed to be crack lol. Yes, likely a clueless dealer oil change tech which there are daily posts about on here and every other forum. They spin them on and off with a gun, they couldn't care less about your property. Very possible the crack was started and you may have finished it off. Did you double and triple check the base o ring is in place properly and not cut?
Old 11-18-2019, 06:16 PM #5
Haha. I figured.
Dang techs.....wish they cared more. Hope that's all it is and an easy replacement. Worth $20 to try I think. Would I get the part just at O'Reilly's or Amazon?
Correct. When I took off the first replacement after it was leaking, I checked the gasket and it was in perfect shape. I then replaced the filter and gasket again just in case and checked it and it was all good. The gasket is right where it should be at the bottom of the threads.
Old 11-18-2019, 06:29 PM #6
Real Name: Chris
Real Name: Chris
I'm sure your local dealer stocks them but I ordered mine from Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-18-2019, 06:55 PM #7
Just placed order. Thank you!
filter , gasket , miles , oil , put
Coolant leaking above oil filter even though water pump replaced 10k miles ago bohdanprok Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-02-2019 03:05 PM
Changed fuel filter and now it's leaking like crazy 3rdgen_4runner 3rd gen T4Rs 15 06-22-2019 02:53 PM
2017 w/ 16,000 miles leaking CV boot. Presa Canario 5th gen T4Rs 27 01-04-2019 05:35 PM
Can I drive 5 miles with leaking Transmission? karyins 4th Gen T4Rs 18 09-21-2016 01:31 PM
Leaking fuel filter question clt750 3rd gen T4Rs 4 06-22-2013 09:33 PM
