Old 12-13-2019, 01:34 AM #1
3rdgenlita 3rdgenlita is offline
3rdgenlita is on a distinguished road
Bogging and starting issue
1998 Toyota 4Runner first issue is. Cold start the motor will turn on and then die right away and if I crank it again it will start and stay running. It’s not throwing any codes. Second issue. I’ve had this issue for a while. I don’t know if it’s normal or not. When the motor is fully warmed up if I tap the throttle lightly and quickly it will stumble And bog out. Should it do that? Thanks for any help. I replaced injectors about 3k miles ago. When I did all my maintenance. New wires and plugs O2 sensor as well.
3rdgenlita is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 05:55 PM #2
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
You tried cleaning the TB?
My DD 99 accord's idle would drop real low like you mentioned after only stepping on the gas a little. Almost to the point it would die. I gave the TB a good cleaning and its like new.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
bog , issue , it’s , motor , start
Need HELP! Starting issue Jimstr8 3rd gen T4Rs 8 04-07-2016 11:05 PM
Starting Issue GreenMachine 4th Gen T4Rs 7 11-28-2015 11:23 AM
Starting issue 4RunnerBabe Problems & Warranty Issues 1 02-05-2014 11:14 AM
Starting issue Footofgod Classic T4Rs 3 01-10-2012 02:16 PM
Starting issue steak2286 Problems & Warranty Issues 3 03-04-2008 06:58 PM
