Old 12-21-2019, 04:30 PM #1
GreenMountainOwl GreenMountainOwl is offline
GreenMountainOwl is on a distinguished road
5th Gen P2443 Code/Secondary Air Injection
(MODS/ADMIN: I realize I have no concerns for warranty work on this vehicle yet, so I cross-posted this to the 5th Gen forum where I think it is more appropriate at this time. Please delete the thread here under the Problems/Warranty forum. )
I have searched here and elsewhere and generally only find information about this issue with Tacomas from roughly 2005-2012. There is almost no commentary about this issue or solutions with a 5th Gen T4R.
I have a 2014 LE with 75k miles. Just bought it CPO about a month ago. It has had no notable concerns until today.
Air temperature about 18 degrees, although this past week we have had several days below zero when the 4Runner ran fine.
Hopped in, started it up, and immediately see the CHL and Traction Control lights illuminated. Shut down, restarted, same thing. Pulled out my code reader and saw P2443. Cleared the code, warning lights shut off, and I drove to work like normal.
We are supposed to take this vehicle to visit family next week and I don't want to have it break down and leave us stranded. There are some horror stories on Tundra forums. I live in the middle of nowhere in Vermont with no Toyota dealer close by, although I could get to one if I had to.
How should I proceed? Don't worry about it? Bring it to the dealer? Buy a bypass kit?
GreenMountainOwl is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 05:30 PM #2
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
Bringing this topic up. I have a 2018 and I'm pulling P2441, 2443 and 2445 codes, all related with Secondary Air Pump.
I tried to find without success what the Sec Air Pump warranty is.
Does anybody know?
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 03:58 PM #3
rpjtremblay's Avatar
rpjtremblay rpjtremblay is offline
Real Name: Richard
rpjtremblay is on a distinguished road
Real Name: Richard
Following up with this thread. I have a '13 Ltd, same three p codes. Any help would be appreciated!
2103 Limited/3" Icon Stage 2/Method Wheels/ARB 3421520/Smittybilt X2O/Nitto Trail Grapplers 285/70/17/RCI Skids/RCI Sliders/Baja Ditch
rpjtremblay is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 01:10 PM #4
JJEC17 JJEC17 is offline
JJEC17 is on a distinguished road
Following thread, 2017 4runner had 3 p2443 codes this morning temp was 9F above this morning. Could not clear the permanent code.
JJEC17 is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 01:36 PM #5
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
Does anybody know?
After some research, I found out that Maryland's emission system warranty is covered by 2 warranties: performance and design and defect ( https://mde.maryland.gov/programs/Ai...anties2008.pdf ). There are several states covered by design and defect beyond the factory warranty so I suggest checking with your state and push back to the dealer if it is a defect (covered by 8 years or 80 000 miles).
I need to mention that I do have an on-board air compressor installed on C4Fab second battery tray (on the passenger side) very close to the passenger side secondary air valve. In my case, last week I discovered that the small plastic neck piece from the top of the valve was broken. Probably this happened while offroading, and due to air compressor move, this fragile plastic broke off.
I removed the air compressor, glued the tube neck and reattached the tube that triggers the pressure switch to open the air valve (this acts similar with an electric relay but based on air pressure).
The codes have not re-appeared since then. I did not have time to check if the permanent codes are erased - I will wait another week to check since I did not drive too much lately.
The way I discovered this, I tried to troubleshoot the issue to see if the air is blocked from the air pump to the air valves: I checked that the air pump works then I moved to the air distribution tubes to the air valves and then I moved to the air "relay" pressure.
I suggest inspecting small tubes first to see if they are clear or blocked. If they are blocked, the air valves will not open and will trigger these 3 codes. Be very careful removing the pressure tubes as the plastic tube is fragile; use a heat gun or hair dryer to loosen up the small tube. At the bottom, the tube is connected to a metalic neck so is safe.
My concern is that even thought only the passenger air valve side was at fault, I had also the air pump and driver side codes triggered...
2018 TRD OR
Old 12-26-2020, 11:25 PM #6
Gt4r08 Gt4r08 is offline
Gt4r08 is on a distinguished road
You ever find a solution to the p2443? Sadly experiencing this in my new to me 2016 SR5P at 45k
Gt4r08 is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 12:02 AM #7
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
Check my post, it was the passenger side valve.
2018 TRD OR
Old 04-30-2022, 07:09 PM #8
srp365's Avatar
srp365 srp365 is offline
srp365 is on a distinguished road
srp365's Avatar
I had the same P2441, P2443, and P2445 Codes that TodiN mentioned, AND after installing the C4Fab battery tray he installed. Thanks to his post I knew what to look for. Saved me a ton of diag time, so thanks, I owe you a beer!
srp365 is offline   Reply With QuoteReply With Quote
Old 01-04-2023, 04:43 PM #9
The_kiddos_trd The_kiddos_trd is offline
The_kiddos_trd is on a distinguished road
Did you have pictures of what tubes you damaged by any chance?
I have the same issue after installing the second battery tray, but I removed it and can’t figure out where I may have damaged the hose/tube. Did anyone take pictures of it that they could share? Thanks for the input
QUOTE=TodiN;3575301]After some research, I found out that Maryland's emission system warranty is covered by 2 warranties: performance and design and defect ( https://mde.maryland.gov/programs/Ai...anties2008.pdf ). There are several states covered by design and defect beyond the factory warranty so I suggest checking with your state and push back to the dealer if it is a defect (covered by 8 years or 80 000 miles).
My concern is that even thought only the passenger air valve side was at fault, I had also the air pump and driver side codes triggered... [/QUOTE]
The_kiddos_trd is offline   Reply With QuoteReply With Quote
code , dealer , gen , lights , shut
Secondary Air Injection Pump Failure on V8's! Important! Billynath1988 4th Gen T4Rs 545 02-05-2024 08:24 AM
secondary air injection help Txjcb5002 4th Gen T4Rs 10 08-27-2020 12:21 PM
Secondary Air Injection Pump (aka - should I buy this truck?) he's gone 4th Gen T4Rs 5 09-12-2018 05:34 PM
Bad Secondary Air Injection on V8?? Soneill 4th Gen T4Rs 3 04-14-2017 01:41 PM
Code P2432, Secondary Air Injection b.miller123 Problems & Warranty Issues 4 12-11-2014 02:43 PM
