Old 04-03-2023, 07:44 PM #1
dshag dshag is offline
dshag is on a distinguished road
2015 SR5, 4x4, transmission issue? Advice appreciated.
I purchased this new in 2015 & it's not really been off road. It has 87k miles now. For the last 2 months I have noticed a shudder/shaking. This only occurs when I am driving along at low RPMs, usually when the transmission shifts to the next gear. It will feel like going over a gravel road/small bumps. If I floor it or give it more gas everything is fine. Plan to change the transmission fluid & see if that helps but wanted to see if anyone knows what this is likely to be?
Update 1
When I drive in S4 it does not happen anymore. Issue is most likely torque converter shudder. Plan to have dealership replace all trans fluid for $299. Will have them add lube guard & shudder fix at that time, hopefully this fixes it. I modded the 4runner because I planned on getting into offroading but plans changed & never worked out. Surprised at 87k I have this issue, never towed anything & all driving has been mainly highway. Will update after trans fluid is changed.
Update #2
Got the transmission fluid changed today, 4/10/23. Drove it to work & home, no longer notice the torque converter shudder. Dealership put the additives I provided in during fluid change. While it was getting serviced they called, got me for the battery & rear brakes, I knew I would need these done fairly soon so just let them do it . dealership also wanted to replace fluids in front/rear differential & transfer case for $500 but denied that one. Said it was due/missed at my 75k service. Owners manual never says to replace this unless "special operating conditions", says to check it fairly often though. Will check other places prices for this.
SILVER 2015 4RUNNER SR5 PREMIUM 4X4 W 3RD ROW
2.5 IN FRONT LIFT W FOX DSC SHOCKS, CAMBURG BJ UCA
1.5IN REAR LIFT W FOX DSC SHOCKS, 1.5IN COIL SPACER
22IN LED LIGHTBAR + 2 LED SPOT LIGHTS UP FRONT...
dshag is offline   Reply With QuoteReply With Quote
Old 04-03-2023, 09:02 PM #2
djeepin djeepin is offline
djeepin is on a distinguished road
I am just bored sitting up front of the computer screen, so, let me ask you, since your information limited:
you made bunch of modifications, but have not been much off-road. OK. Many people go off-road with all that mods, and every day driving in city, but continue to keep it in transmission in "D". That "D" is tricky: every time you remove your foot from gas pedal and vehicle speed above 30MPH, tranny shifts into 5th gear (look at RPM). That apply strain to tranny clutch plates, effectively wears them prematurely. That shudder is premature wear of plates. Since you were busy with all mods, I sarcastically assume that transmission fluid weren't changed not at 30K, not at 60K. I think "D" is for highway only, in city I drive in 3rd gear, try driving in different gears on various speeds, observe and think.
djeepin is offline   Reply With QuoteReply With Quote
Old 07-03-2023, 06:11 PM #3
Hungryhawk Hungryhawk is offline
Hungryhawk is on a distinguished road
Drive line shudder
I did a lot of research on this topic. See my older posts. This issue well documented and goes back decades across many Toyota models.
Quick reply: a faulty tranny valve solenoid is causing a Flex Lock torque converter malfunction.
Rebuilding the tranny valve body(inside transmission) is the cure. Under warranty my local dealer first replaced torque converter then a few weeks later replaced the transmission.
Also affected pick up trucks and cars.
Hope you can get it done properly.
Hungryhawk
Hungryhawk is offline   Reply With QuoteReply With Quote
feel , gear , gravel , road/small , transmission
3rd Gen guy looking at a 2004 tomorrow. Advice appreciated. Rancho5 4th Gen T4Rs 13 06-18-2021 12:20 PM
Transmission woes. Advice/brainstorming appreciated. johnbyebye 3rd gen T4Rs 10 01-23-2019 02:56 PM
Advice appreciated rckeat 3rd gen T4Rs 25 07-13-2018 02:12 PM
Rookie needs some advice!! (Greatly Appreciated) 4runnin4ever Classic T4Rs 13 08-24-2013 05:30 PM
n00b question -- advice appreciated Hamburglar 3rd gen T4Rs 14 11-08-2007 05:56 PM
