Thread Tools Rating: Thread Rating: 2 votes, 1.50 average. Display Modes
Old 02-22-2007, 07:21 PM #1
Raph25 Raph25 is offline
Raph25 is an unknown quantity at this point
Air Conditioner Problem
Well the problem is that it doesn't blow cold air, settings are low temp, a/c on; but its like is in Fan only.
any comments?
Raph25 is offline   Reply With QuoteReply With Quote
Old 02-22-2007, 08:35 PM #2
toto toto is offline
toto is on a distinguished road
The system could be low on refrigerant.
Fortunately, most Toyota products still have a sight glass in the refrigerant line in front of the radiator.
See the attached for how to use the sight glass.
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Old 02-23-2007, 10:17 AM #3
zig zig is offline
zig is an unknown quantity at this point
zig zig is offline
It may also be the relay. This has happened on several 4th gens, mine included. You may want to try that before spending more money of coolant. It's in the main fuse box under the hood.
zig is offline   Reply With QuoteReply With Quote
Old 02-23-2007, 10:43 AM #4
thanks! i'll check both things this morning.
Old 02-23-2007, 12:02 PM #5
forgot to mention is a 2005 diesel engine.
check the relay and its ok
Old 01-10-2008, 10:16 PM #6
Coralkillah's Avatar
Coralkillah Coralkillah is offline
Registered User
Coralkillah is an unknown quantity at this point
Registered User
Angry A/C Light blinking / A/C dead???
Aloha folks, dont know i any of you had this problem before your A/C units crapped out...
3 days ago, I noticed that it was getting warm...when I looked at the A/C light, it was blinking on/off.
I'd press the A/C button to turn it off then back on and no problem.
Yesterday it happened a few times with me doing the same thing and it giving the same result.
Today, the light blinked and keeps blinking and No Coolness im my ride---dont' really appreaciate the A/C until you have none!!!!
I can turn it off and when I turn it back on, WARMNESS!!!! and more WARMNESS and if I leave it on, HOTNESS!!
I've been reading the other posts and no one mentioned anything like this as a symptom for a blown system, or just a part.....
I have an 03' V8 with 81K miles and this is the first major problem I've had in a while.
Oh, I always run with the A/C on Auto with it on the lowest setting most days.
Any info or .02$ would be appreciated! Thanks
Coralkillah is offline   Reply With QuoteReply With Quote
Old 01-10-2008, 10:31 PM #7
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
The blinking light is THE symptom for a bad a/c relay. Many have said just take it out and bang it on the table a couple of times. Usually fixes it. A better approach is to go to your friendly neighborhood Toyota parts department and pick up the new relay that supersedes the original part.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 01-11-2008, 09:02 AM #8
greasefingers's Avatar
greasefingers greasefingers is offline
greasefingers is on a distinguished road
Classic bad relay issue (Toyota used the wrong part)
So many 2003 4runners had that bad relay (and corolla
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
greasefingers is offline   Reply With QuoteReply With Quote
Old 01-11-2008, 07:15 PM #9
Registered User
Registered User
Thats why I love this site better then the Service Centers....people know more about the 4R's here than the actual mechanics the are supposed to be fixin em!!!
Mahalo Nui Loa!!!
Old 01-12-2008, 04:20 AM #10
Registered User
Registered User
Well 60$ and my A/C is Blowing COLD!!!!! Thanks all for your assistance.
In case anyone reading this is like me and DONT KNOW WHERE THE DAMN RELAY GOES!?!?! -----It is located inside your engine compartment on the drivers side middle area, theres a rectangular box. Pop off the lid and inside the lid is a DIAGRAM for which relay is which.
A Toyota Mechanic actually did give me a really good tip today....
If you have this relay die on you and you absolutely cannot stand the HEAT, The HORN relay can be swapped out with the A/C one.
Your decision will come down to how badly you really want your horn!!
Peace!
Old 01-27-2008, 02:28 PM #11
retco retco is offline
retco is on a distinguished road
I have a 03 T4R sport . the A/C prob is the relay under your hood in fuse box. I took the the relay from my fog lights and used it for the A/C untill i got a new one, they are the same. RELAY ABOUT 70$ AT AUTOZONE. My buddy has been a toyota mechanic for 40 years he got me one at his cost 38$.
retco is offline   Reply With QuoteReply With Quote
Old 05-03-2010, 11:20 PM #12
V8 AWD 4EVR V8 AWD 4EVR is offline
V8 AWD 4EVR is on a distinguished road
FYI, the proper relay is marked "MG CLT" for magnetic clutch.
Photos are here:
http://www.sparkys-answers.com/2009/...s-cooling.html
V8
V8 AWD 4EVR is offline   Reply With QuoteReply With Quote
Old 12-30-2010, 08:42 PM #13
jj4runner jj4runner is offline
jj4runner is on a distinguished road
i was having the same problem with my 03 v8 sr5 and pulled the relay and tested it, 175 ohms on the coil which is good. put it back and a/c worked!!! thanks guys
jj4runner is offline   Reply With QuoteReply With Quote
Old 08-24-2011, 08:36 AM #14
TNT TNT is offline
TNT is on a distinguished road
TNT TNT is offline
control head
I have a 2005 Toyota 4runner. My air conditioner suddenly started blowing hot air. Took it to the dealership yesterday and was told the control head is not grounding the magnetic clutch. Cost to replace control head is $1069.07 not including labor! Please help!
TNT is offline   Reply With QuoteReply With Quote
Old 08-25-2011, 11:54 AM #15
Rix's Avatar
Rix Rix is offline
Rix is on a distinguished road
Rix Rix is offline
Rix's Avatar
The new relay should have 02028 as the last 5 of the part number.
The original is 02022 IIRC.
(first 5 is 89667 or something like that)
Rix is offline   Reply With QuoteReply With Quote
DIY : Load Leveler Air Bags - 3rd Gen T4R legokcen 3rd gen T4Rs 27 11-01-2019 09:30 AM
Air conditioning trouble-shooting Thai Problems & Warranty Issues 1 05-23-2011 11:22 PM
Help: Air conditioner not working sas727 Problems & Warranty Issues 1 08-08-2007 02:03 PM
Air Conditioner & heating for 2006 model year 007Runner 4th Gen T4Rs 13 07-24-2006 03:09 PM
K&N air filters Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-02-2003 09:26 AM
