Old 03-19-2010, 02:54 PM #1
Maui04 Maui04 is offline
Maui04 is on a distinguished road
04 runner radio and a/c controls wont turn off
Need some help. My 04 runners radio and a/c control panel won't turn off when I turn off the ignition. I pulled out the key locked the doors no change. I manually turned off the radio but a/c clock, temp panel wont turn off. Any Ideas. Aloha Mark.
Maui04 is offline   Reply With QuoteReply With Quote
Old 03-19-2010, 03:20 PM #2
MikesToy MikesToy is offline
Banned
MikesToy is on a distinguished road
Banned
that is spooky.
MikesToy is offline   Reply With QuoteReply With Quote
Old 03-19-2010, 03:27 PM #3
borgzman's Avatar
borgzman borgzman is offline
borgzman is on a distinguished road
borgzman's Avatar
You can disconnect the battery, allow time, and back on.
Or check the fuse box, clean with soft paint brush, and spray with non-conductor cleaner.
2017 SR5 4WD - Blistein 5100s - Cooper AT3s - HID Lows - LED Fogs
2003 SR5 V8 - Sold
borgzman is offline   Reply With QuoteReply With Quote
Old 03-19-2010, 05:10 PM #4
Banned
Banned
Have you seen this thread?
Stock radio possessed
Old 03-19-2010, 09:10 PM #5
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Swap out the ACC CUT Relay in the under hood fuse box.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 03-21-2010, 07:56 PM #6
Thanks for the input. Swapped out the ACC CUT relay and the radio went off. The multi-info display light and clock still stays on. Any other possible suggestions?
Old 03-21-2010, 09:42 PM #7
drmorbius's Avatar
drmorbius's Avatar
Have you added anything to the truck? Any mods?
Larry
Old 03-21-2010, 11:46 PM #8
There's been no mods to the vehicle. It's the stock JBL stereo. As I was looking into why the Multi-infor display was on (only the clock and light stays on) the stereo unit began to go on and off on its own without the key even in the ignition. I removed the ACC Cut relay and the problem continue to persists. The only way to date that I can turn both units off is by pulling the Radio 2 fuse. With that fuse removed, my multi-info display unit as well as the radio goes on and off as normal. The only difference is that I have no sound out of the radio. Channels and various modes can be changed, just no sound. I've checked all the connections at the rear of the deck, as well as the multi-info display. All connections were intact and secure.
Old 03-22-2010, 11:22 AM #9
drmorbius's Avatar
drmorbius's Avatar
The 20 amp radio #2 only gives power to the power amp mounted on the subwoofer in the rear. There was a service bulletin on the amp but I don't recall there being an interaction with the A/C display. I think I would show this to the dealer and mention the TSB. They should give you a new amp.
Larry
Old 03-22-2010, 04:13 PM #10
mrapex mrapex is offline
mrapex is an unknown quantity at this point
Exact Same Problem - Radio wont turn off
I have the same problem - just started after a week of rainy weather. Need to manually turn off the radio but a/c clock, temp panel wont turn off. This is draining the battery overnight. Seems to be Acc Cut Relay or Ignition switch? Has anyone else had a similar problem and or solution? Thanks
mrapex is offline   Reply With QuoteReply With Quote
Old 03-22-2010, 08:58 PM #11
drmorbius's Avatar
drmorbius's Avatar
For now you can pull the 20 amp radio#2 fuse. Get the JBL amp replaced.
Larry
Old 03-24-2010, 01:16 PM #12
Work Around
Here is what I did to by-pass the circuit and have the system work exactly as before - on with Acc and off when key is off. I went and got two mini "add a circuits". Plug one into the Radio 20A slot under hood - remove the main fuse and use only the new accessory fuse slot.
Take the second add a circuit and tap into the Cigarette Lighter circuit (this is in the cabin drivers side fuse panel). You will need to run a wire through the firewall - fairly easy look where the Hood latch cable goes and you can stick it through the same large rubber grommet.
Use the Cigarette lighter circuit to supply power to the Radio 2 and it should work fine - at least until you can find a new AMP then can easily revert to original set-up. Let me know if you need more clarification.
Old 04-12-2010, 01:34 PM #13
I finally found the problem. Water overflowed my rear sunroof drain while parked on my steap driveway. Normally the truck parks on flat ground or in a garage so we never had a problem. I guess the rear drain get handle large amounts of water on its own. I tested the truck on flat ground and it never overflowed. Once on the driveway it did well with a light rain but failed when it came down hard or you washed the truck.The water ran down the wiring harness and filled up a junction connector were the Radio 2 fuse power as well as the acc circuts run to feed the amp. The water caused a back feed of 6 volts to the radio and muti display unit since the radio 2 fuse is a constant hot. Thanks for all the suggestions and don't park on steap driveways with sunroof models. Aloha Mark
Old 04-12-2010, 01:42 PM #14
drmorbius's Avatar
drmorbius's Avatar
Nice detective work and glad you didn't have to replace the amp. Where exactly is the junction connector, for future reference?
Larry
Old 04-12-2010, 03:02 PM #15
Thanks
That sounds like it could be it. I have had the front drain tubes leak with subsequent water on the drivers feet. Once I get the time I will check out the rear tubes.
Cheers.
