Old 04-01-2022, 07:36 PM #1
YEAHYEAHHH YEAHYEAHHH is offline
YEAHYEAHHH is on a distinguished road
Exhaust Leakage Identified - Way to Avoid Replacing Exhaust Manifold Gasket?
I smacked the cat converter pipe on the driver side where it cuts over to connect with the muffler on a rock pretty hard like a goon and a week later got a check engine + trac control off lights (P0175, P0102, and P0171 errors). Thanks to the forum, I learned how to identify that I had leakage on both exhaust manifolds and the connection points to the cat converters - basically at every gasket upstream of the muffler connection.
I replaced my full exhaust system a couple years ago when I bought the car and definitely would like to not have to take it all apart again to replace the gaskets especially for the exhaust manifold, they were really hard to get to last time and it took forever.
Is there a way to fix leaking exhaust gaskets without replacing them?
I haven't tried re-tightening or some things I saw online with high-heat epoxy yet since I wanted to learn from the crew first.
Thanks!
YEAHYEAHHH is offline   Reply With QuoteReply With Quote
Old 04-01-2022, 08:36 PM #2
Quick update - I did end up trying to tighten things and it didn't improve things. I think I'll probably just replace the gaskets on everything but the exhaust manifold. Really hoping the epoxy or something similar can be used on the leakage there.
Old 10-19-2022, 06:16 AM #3
Newshoeshughes Newshoeshughes is offline
Newshoeshughes is on a distinguished road
2004 same issue
I have an 04 with same issue. 150k on the dash. Basically every gasket has minor leaks. I am getting p0420 code. Hoping by replacing gaskets it clears code and cat operates as intended.
Newshoeshughes is offline   Reply With QuoteReply With Quote
connection , exhaust , gaskets , hard , muffler
Exhaust flange gasket between manifold and cat? Freakaccident 3rd gen T4Rs 10 09-15-2018 07:27 AM
99 2.7L exhaust manifold gasket 4SKIN 3rd gen T4Rs 8 04-02-2015 07:03 PM
Exhaust Manifold Gasket soundmanlpte 3rd gen T4Rs 3 12-31-2014 03:30 PM
4.7 Exhaust Manifold Passanger & Gasket bjump01 For Sale: T4R Items 0 04-14-2013 11:42 PM
Questions: head gasket and cracked exhaust manifold- 97 3RZ sgtlethargic Maintenance/Detailing 3 05-31-2008 08:39 AM
