Old 09-18-2023, 11:19 AM #1
thefatcat thefatcat is offline
thefatcat is an unknown quantity at this point
Engine Sputter Going Up Slight Inclines
I have a weird issue with my 2016 4Runner Limited:
When going up a very slight incline at low speed I get a sputter / stutter in the engine or drive train (I cannot tell which). It occurs only when the engine is around 1100-1200 RPM and speed is anywhere between 15-30 MPH. It disappears as soon as I step on the gas a little more. It does not happen every time that I am on a slight incline but enough to where I am annoyed by it.
I just replaced the ignition coils and that did not do the trick like my mechanic and I thought. The spark plugs are maybe 2-3 years old. When I hook up my little handheld Motopower scanner it does not pick up any codes either.
Any thoughts on what the issue might be?
thefatcat is offline   Reply With QuoteReply With Quote
Old 05-21-2024, 07:14 PM #2
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
When was the last time you changed the fuel filter? If it’s been a while, it might be clogged and causing fuel starvation.
Also, check the throttle position and mass airflow sensor for any issues.
Inspect the transmission fluid level and condition.
Plus, check your air filter. A clogged air filter can restrict airflow to the engine, causing hesitation or sputtering.
weberlukas74 is offline   Reply With QuoteReply With Quote
engine , issue , slight , speed , sputter
slight engine vibration on occasion, V8 Jasonredwood 4th Gen T4Rs 0 06-05-2017 03:35 PM
Engine sputter mtb97 3rd gen T4Rs 6 08-15-2015 03:45 PM
Engine sputter's makin me NUTZ! jado6006 Classic T4Rs 5 07-25-2013 04:58 AM
92 - Slight Engine Knock 92TXT4R Classic T4Rs 2 12-04-2009 02:18 AM
