Real Name: Lukas Weber
When was the last time you changed the fuel filter? If it’s been a while, it might be clogged and causing fuel starvation.
Also, check the throttle position and mass airflow sensor for any issues.
Inspect the transmission fluid level and condition.
Plus, check your air filter. A clogged air filter can restrict airflow to the engine, causing hesitation or sputtering.
