Originally posted by NoDak
also if you can find a really dark location, lift the hood and see if you can see the spark plug wires arc ing (blue color). thats a sign you may need to replace the wires also due to cracking or leakage in the wires. had this happen on my 84 celica.
I agree that the plugs is a good place to start. Also, since the plug wires are from 99, I'd probably go ahead and replace them anyway, if you can afford it. That's one area that can go bad without you realizing it, and replacing them is usually not very difficult -- you're already half done when you pull the plugs.
