Old 08-21-2024, 11:41 PM #1
jonbert jonbert is offline
jonbert has a little shameless behaviour in the past
2011 SR5 Driver side window problem
I tried to do something with my 2011 SR5's power lock on the driver's side front window/lock controller, more specifically the wiring to it. Without getting into detail why or what I was trying to do, I made small wire insulation openings to access each of the copper wires. Visually it does not look like I cut the copper at all so continuity should still be there. So, I wasn't able to do what I set out to accomplish, i covered the exposed copper with Plasti-Dip to re-insulate them separately. Now, my driver door window and lock buttons don't work. Neither does the rear window up/down switch work, which I never touched. I believe I covered and checked all the fuses that may have blown associated with window operation. I bought a new driver's side window/lock up/down switch, but it still doesn't work. I'm going to re-check wire continuity and power tomorrow. If anybody has any other ideas of what else may have happened, I'd appreciate to hear from you.
jonbert is offline   Reply With QuoteReply With Quote
copper , side , switch , window , work
Driver's Side Passenger Window Anti Pinch Problem CutthroatSlam 5th gen T4Rs 3 03-07-2022 04:43 PM
1998 Limited Driver Side Power Window problem CamdenG 3rd gen T4Rs 1 09-12-2017 12:01 PM
Driver side power window problem Brutus 3rd gen T4Rs 6 07-18-2011 07:20 PM
2011 SR5 4Runner Leans on Driver Side Sandpiper 5th gen T4Rs 9 05-08-2011 06:18 PM
driver's side window problem sahtt Classic T4Rs 5 07-30-2006 12:56 PM
