Old 10-31-2007, 05:33 PM #1
05 BlSp4runner 05 BlSp4runner is offline
05 BlSp4runner is an unknown quantity at this point
4WD Indicator Lights?
The 4WD indicator lights on my 05 V6 Sport are not coming on when I put it in 4WD. Not sure if 4WD system is working or not. About 2 months ago I had a new receiver installed. I don't know if they could have left something off. Everything worked fine before this. Trying to decide if I should return it to them or take to dealer. I would appreciate any help!
05 BlSp4runner is offline   Reply With QuoteReply With Quote
Old 10-31-2007, 08:53 PM #2
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
When you put it in 4WD, you should here a slight clicking. That's the sound of the solenoid engaging the 4WD. Also you should be able to feel the difference when in 4WD compared to being in 2WD, I can anyways. Maybe the light in the dash is just dead.
What about when you lock the center diff when you're supposedly in 4WD, does that light come on? Can you put it in 4LO and does that light come on?
I'm assuming your truck is under warranty, why not bring it in? I understand it's a PITA, but at least it's covered under warranty.
sharp4runr is offline   Reply With QuoteReply With Quote
Old 11-01-2007, 08:03 PM #3
I don't hear any clicking noise. I guess I really can't tell if it's going into 4WD because I've only used it a few times. I tried the things you mentioned and still no lights. If the shop that installed my stereo did something wrong that won't be covered under the warranty. Thanks for the reply!
Old 11-01-2007, 10:21 PM #4
rook's Avatar
rook rook is offline
rook is on a distinguished road
rook's Avatar
When they removed the silver center dash trim piece, they probably disconnected the 4wd switch. This switch should be illuminated when the headlights are on, it will be an easy diagnostic to see if this is the case.
rook is offline   Reply With QuoteReply With Quote
Old 11-02-2007, 05:09 PM #5
The switch does light up when turning on the lights. Thanks!
Old 11-18-2007, 02:36 PM #6
I thought I would give an update on my problem. Friday I scheduled an appointment with the dealer to get my 4WD problem and driver's seat movement looked at. Well yesterday I decided to try and disassemble my truck and see if the 4WD switch was connected. It was connected but one of the pins inside the connector was bent. Straightened out the pin and put everything back together. 4WD system is now working! I knew those damn installers had something to with it. I'm keeping my appointment to see if they can fix my seat. I've noticed a few people have the same issue. Will update later.
'01-up 4wd System (A-TRAC, VSC) and TORSEN T-3 Thai General Discussions 57 09-01-2020 09:35 PM
Won't go into 4 wheel drive Torinate 3rd gen T4Rs 28 04-15-2019 05:43 PM
4WD system maintenance? longhaul747 3rd gen T4Rs 13 11-18-2012 04:24 AM
4WD vs. AWD eorange 4th Gen T4Rs 19 03-16-2005 12:10 AM
'01-up 4wd System (A-TRAC, VSC) and TORSEN T-3 Thai 3rd gen T4Rs 45 05-24-2004 08:33 AM
