Old 11-24-2007, 01:12 PM #1
guitarguythingy guitarguythingy is offline
guitarguythingy is an unknown quantity at this point
VSC Trac and Trac Off lights
hi,
I have a 2003 SR5 4runner. I just took it to the dealer to get a valet key done and programmed. When I got the car back I noticed that the VSC Trac and Trac Off lights are on. So I turned off the car and then turned on the car. The lights went away but as soon as I put it in gear and start rolling a few feet the lights come back on again. I tried in reverse and Drive the lights come back on only when the car is in gear and rolls.
Can anyone please help me? I have an appointment with the dealership and the car is still in warranty since i bought the car 5 days ago used, but the car still drives fine with the lights on. Can anyone please help?
Thanks in advance.
guitarguythingy is offline   Reply With QuoteReply With Quote
Old 11-24-2007, 01:26 PM #2
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
If this happened right after the dealership was fiddling with your truck, I'd blame it on them and ask them to fix it.
Is the CEL on also? If so, this could be caused by something as simple as the gas cap not on tight enough. Tighten it until it clicks a few times.
It could also be caused by an O2 sensor failing. Or possibley an ABS sensor gone bad since VSC utilizes the ABS system.
All of this could have been found just by searching. It'll save you some time next time instead of waiting for a response
sharp4runr is offline   Reply With QuoteReply With Quote
Old 11-24-2007, 03:01 PM #3
The CEL light is off. its just the VSC and Trac off light. i'm gonna bring it back on monday since monday is my day off.
Thanks. i appreciate it :]
Old 11-25-2007, 10:35 AM #4
sharp4runr's Avatar
sharp4runr's Avatar
Try this before taking it in. Pull the negative terminal for a few minutes and then reconnect. This will reset the computer and erase the trouble codes. If there is still an issue lights will come back on.
You'll have to reprogram your radio stations and reinitialize the windows, but nothing hard.
Old 11-25-2007, 11:15 AM #5
i already tried that the lights still came on... they go away after you restart the car but they come back on when i actually drive the car.
thanks though :]
Old 11-25-2007, 01:20 PM #6
sharp4runr's Avatar
sharp4runr's Avatar
Well let us know what the dealership finds. It seems fishy that this happened right after you took it to them to get your keys programmed.
Old 11-26-2007, 11:42 AM #7
034RunnerLTDV6 034RunnerLTDV6 is offline
034RunnerLTDV6 is an unknown quantity at this point
Im having the same exact problem as we speak with my truck, let me know what the dealership says......
2003 4Runner Limited V6 4x4
<br>
Titanium Metallic / Stone
034RunnerLTDV6 is offline   Reply With QuoteReply With Quote
Old 11-26-2007, 06:13 PM #8
okie! i just got back from the dealership... and they fixed it.
The VSC Trac and Trac Off light came on because the Yaw rate wasn't calibrated.
So, they performed yaw rate zero calibration and the lights are no longer there to bother me :]
Thanks to those offering assistance :]
Old 12-03-2007, 12:24 AM #9
00328's Avatar
00328 00328 is offline
00328 is on a distinguished road
00328's Avatar
Anyone know how the 'yaw rate' becomes uncalibrated?
Seems to me, once its calibrated............its calibrated, no?
2005 4X4 V8 LTD 4Runner Black
Driver's side upper assist handle, tail/stop bumper light mod, Flowmaster 50 suv with side exit exhaust and Valor tip, 20% tint on fronts and 27% add'l tint on rear window, DIY blacked-out headlights, Stainless door sills, VIP Plus w/GBS alarm, OBX pedals, Can. hood protector, ash tray kit, '06 LED tails, T&H Euro bar, OME lift, Spidertrax spacers, LT275/70R17 Cooper AT3s, HIR bulbs in LB and fogs, VSC mod, AFE Pro Dry S filter, White LED cluster and HVAC
00328 is offline   Reply With QuoteReply With Quote
Old 12-03-2007, 12:43 AM #10
well mine became "uncalibrated" after they programed the key. So maybe the tech reset the yaw.
Old 12-03-2007, 03:41 AM #11
MicaBlue03's Avatar
MicaBlue03 MicaBlue03 is offline
MicaBlue03 is on a distinguished road
MicaBlue03's Avatar
Un-calibrating the sensors
I've been dealing with the same problem and learning a bunch about this lately. I need to find time to write up a full post on it, but the short answer is that the dealer's use of the "hand held tester" on the OBDII port to program a new key accidentally cleared the existing zero point calibration of the yaw and deceleration sensors. It's not that hard to do.
Fortunately it's also not hard to fix for yourself. See TSB BR001-04 and the last page, where they tell you how to do a new zero point calibration with only a jumper wire (they give the SST number 09843-18040, but it's just a jumper wire and not the hand held tester).
I just did this calibration myself, and fixed my problem. I'll try to write up a full explanation (new thread?) in a few days.
MicaBlue03 is offline   Reply With QuoteReply With Quote
Old 12-04-2007, 10:04 AM #12
Falkon Falkon is offline
Falkon is on a distinguished road
Re: Un-calibrating the sensors
Hey Mica,
That will be very nice of you.
2004 T4R Limited
Falkon is offline   Reply With QuoteReply With Quote
Old 01-08-2010, 03:17 AM #13
CAN-03runner's Avatar
CAN-03runner CAN-03runner is offline
CAN-03runner is on a distinguished road
VSC TRAC and VSC OFF light ON but NO CEL (Check Engine Light)
[QUOTE=guitarguythingy;273215]hi,
QUOTE]
I'm experiencing this exact problem right now. In this thread Micca mentions that he would write up a full post on this subject. I've found the post and it can be found at the link below.
http://www.toyota-4runner.org/proble...ff-lights.html
Hope this makes it easier for anyone else to locate the information they need. I just got my 4runner back from a Toyota dealer for a rear door issue. So don't know how my door is linked to my VSC....anyhow... I'm not sure if they did, but I suspect that the Toyota techs will always hook up a code reader just for the sake of verifying codes....
Read Micca's post and you'll understand the significance of the code reader in relation to this issue and a do it yourself at home fix. I'm going back to the mechanic 2morrow armed with this information and hoping to get them to do the zero fix for free...
Also some of my other research on various posts has said that while VSC is off, ABS is still active. I will verfy this 2morrow on a patch of ice. I'll post my outcome with the fix and verification of whether ABS is still active.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
CAN-03runner is offline   Reply With QuoteReply With Quote
Old 01-16-2010, 02:35 AM #14
!! Update !! Vsc trac lights !! Update !!
Ok, so I will add something else that other seem to have reported that would have causeed this issue. Having a new key programmed. So I would have had 2 things done to my 2003 4runner that seems to cause this problem. VSC TRAC and VSC OFF Led's are lit up on the dash. But NO Check Engine Light and NO ABS light.
An ODBII scanner was connected to my truck and also a new key was programed for it.
Brought it back to Toyota. Since it is a 2003 it is out of warranty. But I tried to explain these situations and they refused to acknoledge it, or look it up or research it for themselves. Anyways they ended up charging me 94$ for the Zero Calibration Reset. I got them to bring it down to on 64$ not that much better because I think they should have done it for free since it is a glitch and should be part of their procedure to reset the calibration on this particular model..... It's been a few days since the reset and the lights have come back on.
The Toyota service bulletin TSB BR001-04 shows how to reset this with the Toyota scanner and manually by shorting 2 pins if you don't want to bring it to toyota. This bulletin can be found by a quick internet search.
Old 01-16-2010, 05:19 PM #15
00328's Avatar
00328's Avatar
Were you able to reset it with shorting the two pins?
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration MicaBlue03 Problems & Warranty Issues 299 06-05-2023 01:23 PM
VSC trac & VSC off Lights still on... OMG! 4rssassin Maintenance/Detailing 2 09-24-2010 11:28 AM
Brake, VSC Off, VSC Trac, ABS Lights 024runnerrich Problems & Warranty Issues 1 01-14-2006 01:30 PM
Brake, VSC Off, VSC Trac, ABS Lights 024runnerrich Maintenance/Detailing 0 01-13-2006 10:02 PM
