Thread Tools Rating: Thread Rating: 12 votes, 4.50 average. Display Modes
Old 01-19-2018, 05:22 PM #241
Cm18cam Cm18cam is offline
Cm18cam is on a distinguished road
Originally Posted by oljedi11950 View Post
Happens a lot on 5th gens too ! Pass. side for some reason when they screw on clamp squeezes cable & only a slight pinch will break it & that;s all it takes to set em off !
Okay guys so I found the culprit....the abs cable was snapped on the front passenger side. Anyway to repair this or can I replace the whole cable pretty easily?
Cm18cam is offline   Reply With QuoteReply With Quote
Old 01-19-2018, 10:04 PM #242
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Either or ! Some guys have done a splice & tape , others (me) buy new cable !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 02-04-2018, 12:47 AM #243
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
Would there be any interest in a custom-made device you could plug in to the OBD2 port and push a button instead of having to mess with paperclips and stripped wires?
I made one for myself and I suppose I could make a few more if someone was interested.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 02-09-2018, 04:25 PM #244
nsxspdfreak nsxspdfreak is offline
nsxspdfreak is on a distinguished road
Definitely! I just bought a 03 with the VSC lights on. The dealer swore that they had been out until a potential customer decided to connect a reader to the port. The dealer and perhaps customer didn't realize that the reader was not compatible with the 03-04's and that it would erase the data in the stability control computer. The customer tried to get dealer to sell them at discounted price, but the dealer told him to basically F off.
nsxspdfreak is offline   Reply With QuoteReply With Quote
Old 02-25-2018, 01:19 PM #245
LC_4R LC_4R is offline
LC_4R is on a distinguished road
Wow, these problems are still around.
I have a 2004 4Runner and I always plug in the OBD while the engine is running. I then turn the car off to read/erase codes, and only take the OBD off when the 4runner is back running. I just know it works and if I take the OBD off any other way, I am in some flat parking lot with the paper-clip...
The VSC 'turn-off' is from both a O2 'fail' and sometimes a fuel cap issue. I have seen both.
I have the wife not allowed to refuel it, that solves the gascap issue, and I have rigged the wiring on the O2 sensors to trick the ECU into seeing what it wants.
Basically, the two rear O2 sensors are just there post-catalytic converter to check that it is functioning. The scheme the vehicle uses is to run a bit rich after a number of highway miles (30 or so?), and it monitors the voltage on these cheap old school O2 sensors. If they indicate rich, then the ecu sends a code, disables the VSC etc. (they should be sued), and people run to the stealership.
I am an EE and it is very easy to just send a constant voltage signal that makes the ecu think it is seeing a good-cat condition.
This is a problem across many Toyotas and Lexus (I believe). The VSC is a critical safety system built into the vehicles. To disable it for a gascap or emissions issue is crazy. I once called up the Toyota engineers in the US, they said it is meant to save the engine! I told them fvck-the-engine, this is the 'baby-car' that my wife hauls my kid around in. It got pretty intense and I wish I taped that phone call!!!
LC_4R is offline   Reply With QuoteReply With Quote
Old 02-25-2018, 01:23 PM #246
LC 4R,
I'm fascinated. Was it ever explained (either by Toyota or elsewhere) how an emissions device operating at less-than-peak efficiency warrants disabling the traction control system?
I would totally understand if it set the VVT-i system to a "flatline" position or maybe *maybe* disabled the A/C with the claim that "less strain on the engine reduces already higher-than-acceptable emission levels" but deactivating ABS baffles me.
Old 02-25-2018, 01:30 PM #247
The 'party-line' is that it is to prevent 'engine-damage'. It is total BS and they should be sued in a class-action case.
They should just flip on a CEL. That is all that is needed. Whoever coded the ECUs screwed the pooch and it would be a case of a recall where the owners would have to get either new ecus or come in and get the ecu updated somehow.
VSC has saved me on a number of occasions since living/driving in Colorado weather. I go up in the mountains and it is crazy coming down I70 to the city.
Old 03-01-2018, 10:12 AM #248
tmarton05's Avatar
tmarton05 tmarton05 is offline
tmarton05 is on a distinguished road
tmarton05's Avatar
I have a 2006 with VCS TRAC SKID and ABS lights all on. No CEL. I have replaced the gas cap, brake light switch, and attempted to complete the Zero Point Calibration several times with no success. Would appreciate if anyone has any tips or tricks that I haven't tried yet
Thanks
tmarton05 is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 08:51 PM #249
ZombieRunn3r's Avatar
ZombieRunn3r ZombieRunn3r is offline
ZombieRunn3r is on a distinguished road
Thanks
Same here. No CEL, no codes. Just the 4 lights down the speedo side.
ZombieRunn3r is offline   Reply With QuoteReply With Quote
Old 04-13-2018, 03:13 AM #250
MindGoneHaywire MindGoneHaywire is offline
MindGoneHaywire is on a distinguished road
Question
Hello, I appreciate the post. I have VSC Trac lights. I am curious about whether an OBDII scanner such as the ScanGauge II will clear VSC Off and Trac lights. If so, how? Does it actually enable or do a Zero Point Calibration?
Also,what are the differences/similarities of the Toyota Diagnostic Tester Kit and CAN Module, as compared with the ScanGauge Tool? This stuff is fascinating and I'm tired of being fleeced by the dealer.
Thank you kindly
MGH
MindGoneHaywire is offline   Reply With QuoteReply With Quote
Old 04-13-2018, 11:08 AM #251
MGH,
What year is your truck? As explained in the first post, if yours is an 03-04, using a scangauge or other similar OBD2 device is what may cause the lights to come on in the first place, assuming they are not reporting a defective sensor or other legit fault.
Old 04-13-2018, 11:59 AM #252
wtmtnrunner's Avatar
wtmtnrunner wtmtnrunner is offline
Real Name: Rolf
wtmtnrunner is on a distinguished road
Real Name: Rolf
Smile reset of Zero Pt. Calib.
So, after an oil change when I got into my truck the VSC Trac and VSC Off light were lit. I left the garage figuring give it a little time to clear. Obviously didn't. Went back to the garage they couldn't figure out what it was (no codes stored).. gave them sometime to figure it out, went back a week later. Still no codes... told them to try a zero point calib. guess what to his shock it worked... Best part is they must have used a code reader to reset the oil light. Guess its time for a new garage... Thanks for the post so many years later!
wtmtnrunner is offline   Reply With QuoteReply With Quote
Old 06-18-2018, 07:23 PM #253
danronian's Avatar
danronian danronian is offline
danronian is on a distinguished road
danronian's Avatar
Smile
Great post! Saved me after the code reader pulled a code for an upstream o2 sensor and triggered these lights to stay on. This process turned the lights off with my first try at it. I used a couple pieces of paper clip crimped on to some speaker wire so I could operate the wires from the drivers seat. Thanks!
danronian is offline   Reply With QuoteReply With Quote
Old 06-18-2018, 07:41 PM #254
What you need is a little something I call "The Zero Hero." Plugs right in and works with a thumb button instead of messing with jumper wires and such!
Message me if you're interested in one, I keep parts around and build them to order!
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration-20180219_122713-jpg
Old 06-19-2018, 07:27 AM #255
danronian's Avatar
danronian's Avatar
I used this free tool (minus the five minutes to make it).
Yaw Rate and Acceleration Sensor Zero Point Calibration iDRiVaT4R 5th gen T4Rs 100 10-09-2022 08:15 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
Got the dreaded "check engine" + "VSC off" lights bonedoctor 4th Gen T4Rs 2 11-04-2006 10:33 AM
