Thread Tools Rating: Thread Rating: 12 votes, 4.50 average. Display Modes
Old 12-20-2010, 03:46 PM #61
ehh4rnr ehh4rnr is offline
ehh4rnr is on a distinguished road
VSC TRAC, VSC OFF and ABS Lights On - Loud Alarm Noise
For the fifth time in the last year I have an annoying problem. It seems that when it is very cold, but not all the time, all of the lights come on when I start the car. At the same time there is a high pitched alarm sound which stays on until the lights go off. When this first happened one year ago it lasted at least one hour and I was stranded in Vermont. It is now happening with increasing frequency. My Toyota dealer has no clue, says there is no record in the computer, has never heard of this and is at a loss. This is not exactly acceptable to me and I need to fix the problem as the car is not drivable with the noise and the warning lights.
Help!!!!
ehh4rnr is offline   Reply With QuoteReply With Quote
Old 12-21-2010, 10:04 AM #62
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Help!!!!
Next time it's really cold hook jumper cables prior to starting and see if that makes it cycle properly. It may be low voltage for too long a duration at start-up.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 12-21-2010, 02:01 PM #63
I would have never thought about that. We will give it a try. I read many posts here about the lights going on but without the alarm and there seems to be a fix recommended. However, do you think the alarm sounding in my situation makes it unlikely that fix will work?
Thanks for the response.
Old 12-23-2010, 09:16 AM #64
Naija4Runner's Avatar
Naija4Runner Naija4Runner is offline
Naija4Runner is an unknown quantity at this point
Hello guys,
My 4runner started displaying a VSC TRAC and VSC OFF light just about 3 years ago after my local repair man had it connected to an OBD-11 diagnostic tool for some other diagnostic check. I had it returned to have the fault cleared and had tried other places but finally gave up after a
couple of months after failed attempts and suggestions that i get a new yaw rate sensor. Thankfully i stumbled upon this blog and after following MicaBlue 03's advice, i finally got cleared myself using the Trailer Brake Jumper Harness that came with my 4runner for the zero point calibration!!! You can
imagine my delight to have an alarm that has permanently remained on my dashboard over the past three years cleared by myself!! A very big thank you to Mica and the other great contributors to this forum..
Check out the pics.
2004 Limited V8 4X4
Naija4Runner is offline   Reply With QuoteReply With Quote
Old 01-31-2011, 03:01 PM #65
JAC's Avatar
JAC JAC is offline
JAC is on a distinguished road
JAC JAC is offline
JAC's Avatar
Thumbs up
VSC Trac - Trac Off lights on after New Tire installation.
Problem solved thanks to this thread..
2004 -SR5 V6 2WD-Gold-
Front Adjustable Bilsteins Shocks/1.5 DS Backspacers,265/70/17 Firestone Destination A/T's,Eclipse AVN6000 Navi HU,Python Remote Start/Alarm,Wet Okole Seat Covers,Steelcraft Bullbar,Go Rhino HitchStep ...and more
JAC is offline   Reply With QuoteReply With Quote
Old 02-19-2011, 10:27 AM #66
matthew999 matthew999 is offline
matthew999 is on a distinguished road
2003 4Runner Limited V6 -- CEL, VSC TRAC, VSC all on due to righthand side CAT failure. CAT replaced CEL off. Move the car and VSC lights come on.
Shorted the two connections in this thread...and magically lights all go off and stay off.
Dealer wanted to charge $149.00 to 'diagnose problem' and shop that replaced the CAT said it was not their fault. Wanted more $$$ to investigate.
Did a google and fixed the problem in my garage with some romex.
Thanks!!!
matthew999 is offline   Reply With QuoteReply With Quote
Old 03-07-2011, 10:44 PM #67
bigdon's Avatar
bigdon bigdon is offline
bigdon is on a distinguished road
bigdon's Avatar
Originally Posted by Falkon View Post
Thanks a bunch MicaBlue03.
Glad you could clarify the alternatives to some of the special tools - SST. Could you show a picture of how your wires were plugged into the DLC3, please?
To further assist with your writeup, I have attached the TSB, BR005-03, you mentioned in your script. A schematic of the DLC3 unit indicating the required pins TS and CG with the re-calibration instruction is shown on page 7 of the attached TSB.
Good Luck.
THANKS SO MUCH FALKON for including this attachment !!!!!!!!!
2006 4Runner SR5
2014 FJ Cruiser
bigdon is offline   Reply With QuoteReply With Quote
Old 03-20-2011, 10:10 PM #68
Scott478 Scott478 is offline
Scott478 is on a distinguished road
Thanks MicaBlue03
Thanks to your post my daughters '04 is good to go. The thickest wire I could get in the plug was 18 gauge, but it worked like a charm. Hard to believe a designer would disable such an important safety feature just because one of the emission items triggers a code. First time it was a catalytic converter, this time the EGR valve position sensor tripped the check engine along with the TRAC and VSR lights. Appreciate your help.
Scott478 is offline   Reply With QuoteReply With Quote
Old 04-19-2011, 10:07 PM #69
Reznuel Reznuel is offline
Reznuel is on a distinguished road
Fix worked! Thanks for everything.
I used a cheap switch i purchased at the local store. 18 gauge wires with a toggle on/off switch. If you use something similar, just remember to have it switched on so the circuit's complete when you place it back in the second time. A million thanks to the guys who provided the detail and download. If you're ever in SLC, UT, let me buy you beer.
Reznuel is offline   Reply With QuoteReply With Quote
Old 04-24-2011, 12:43 AM #70
kobresia kobresia is offline
kobresia is on a distinguished road
I used a multimeter probe set to make the contacts, too easy.
This zero point calibration also fixes the issue when a sensor wire has been cut. Toyota wanted $200 or so for a new magical wire, saying it couldn't be spliced and still work. I spliced it anyway and just lived with the warning lights on for the past 60k miles or so. The VSC was pretty annoying before that wire got cut, though, hopefully I won't regret fixing it.
Regardless, thanks for an excellent & informative post!
kobresia is offline   Reply With QuoteReply With Quote
Old 05-23-2011, 09:43 PM #71
chrsbonner's Avatar
chrsbonner chrsbonner is offline
chrsbonner is on a distinguished road
chrsbonner's Avatar
Another happy customer [after a few tries!]
Finally, just completed the Zero Point Calibration. I tried it about 5 times with no luck. Took a deep breath, re-read the instructions, and found my mistake [I can admit my mistakes!]
I misread Step 9 which lists actually connecting the two leads. Repeated it correctly and the lights started flashing, as advertised. VSC lights are now reset.
Thanks for this great post -- because of the CEL, I was unable to get Inspection stickers [PA state]. Now that everything is reset, I'm getting my stickers in the AM.
Wahoo!
2004 4Runner V6 Sport Edition 4x4
Titanium Metallic [Debadged]
Webasto Aftermarket Sunroof
Scion T1804 Head Unit/IPOD2Car hook-up
Bridgestone Dueler AT Revo 265/70 R17
chrsbonner is offline   Reply With QuoteReply With Quote
Old 05-23-2011, 10:36 PM #72
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
Just wanted to say I also found this useful, worked like a charm! Thanks!
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 03:30 PM #73
Eastcoastrunner Eastcoastrunner is offline
Eastcoastrunner is on a distinguished road
i'm going to have to try this on the next nice day. I was driving home yesterday, and i hit a pothole. Next thing I know, vsc lights and CEL come on. And continue to be on now.
So, do you all just take two stereo wires, put one end of each wire in respective parts of OBD II connector then touch the other two ends together as per instructions?
on a side note, this is my first toyota, and I am not impressed with reliability thus far.
In last two months, i have changed front calipers/rotors/pads and rear rotors/pads and E-brake hardware. Replaced tires (i know, nothing one can do).
Last week the liftgate lock motor broke and the window regulator are shot.
Constant ticking of engine that is well documented in the forum too (v8)
Now this?
Eastcoastrunner is offline   Reply With QuoteReply With Quote
Old 06-07-2011, 04:45 PM #74
chrsbonner's Avatar
chrsbonner's Avatar
Update from my experiences: although the Zero-Point Calibration worked great to reset the lights, mine came back on within a few miles. Turns out I had a bad O2 sensor (Bank 1, Sensor 2) as confirmed by the OBDII code reader. So I picked up a new one at NAPA for $114 [Denso 234-4805] and replaced it. Pretty easy job using a 7/8" wrench. Local shop was charging $265 parts/labor. The new one even comes with anti-sieze in the box. I reset the codes, and have been driving 200 miles without issue.
Thanks again for all the great info.
Old 06-07-2011, 05:22 PM #75
Jeff4runner's Avatar
Jeff4runner Jeff4runner is offline
Real Name: Jeffrey
Jeff4runner is on a distinguished road
Real Name: Jeffrey
Now this?
Dont worry about "reliability." Its a toyota, enough said.
Some things you listed are maintenance. Pads, rotors, and hardware all wear out just like every other car. Needing new calipers, cant say much, but that may be from neglect on a shops part. Tires, wear out.
Everything that broke in the back door could be from water damage. You probably need to replace the dew guards on the bottom of the window. VSC, just sucks, but I can deal with it failed on mine. Lets me drift...
ASE Certified Automotive Technician
President: Storm Engineering, LLC
04' 4Runner 255 HP V6, Custom CA Intake, Spectre Filter, Custom Interior Light, General Grabbers 265/70/17, Catalytic converter deletes, Flowmaster High Flow Muffler, JBA Performance Headers, Jet Black Bull Bar, Rear Diff Breather Mod, 9006/9005 Silverstar Ultras in all * 160K Club *
Jeff4runner is offline   Reply With QuoteReply With Quote
Yaw Rate and Acceleration Sensor Zero Point Calibration iDRiVaT4R 5th gen T4Rs 100 10-09-2022 08:15 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
Got the dreaded "check engine" + "VSC off" lights bonedoctor 4th Gen T4Rs 2 11-04-2006 10:33 AM
