Originally posted by nc211
I've got an 05 V8 4x4 SR5, and my heat setting appears to be way off too. It's 20 degrees here in the morning. I'm not running the a/c compressor. Yet if I set the temp to "lo", I get outside air "warmed up a bit, but still cool". Then, if I bump up the temp to 65, it's WARM...bump it to 67-69, and it's HOT! Way too hot! It's like my heater is set to "all or nothing". It's not in auto, and no a/c running. I don't understand how setting it to auto would fix this though? I'm in manual mode, and just want a little warmer air coming in from the outside, through the dash vents. Auto wants it coming through the floor boards. The temp sensor grill is clean, engine isn't running hotter or cooler, everything seems normal, except for the sensitivity of the temp setting in relation to what I get. Anything above 69 degrees, and I'm down to my shorts, and that ain't good for anybody!
I hear you on that.., the heater is way too warm/hot, like you said it is all or nothing.... does running on auto help this rather than just trying to set the temp and the fan speed? Seems like the heater is too hot, and the AC is not cold enough, again, does auto help this?
I have an 03 V-8 with 77K miles. The AC light does not flash yet, but thinking of replacing that relay to see if that will help with the AC.
