Old 01-22-2008, 10:57 PM #1
coolvman83 coolvman83 is offline
coolvman83 is an unknown quantity at this point
Post 2003 4Runner- VSC Trac/ Trac Off Lights Only
Hi Everyone,
I hope someone can help me... I have a 2003 4Runner, 46k miles, with the V6 engine. Most mornings when I start the truck, the 'VSC Trac' and 'Trac Off' lights come on. Both lights definitely seem to only come on when the truck is cold (has been sitting all night). I'll then shut the truck off and restart it and the lights will go off. I don't know if anyone has come across this and I will entertain all advice. Thanks in advance!
coolvman83 is offline   Reply With QuoteReply With Quote
Old 01-29-2008, 09:34 PM #2
buferd buferd is offline
buferd is an unknown quantity at this point
VSC LIGHTS
mine stay on all the time, the book says okay to drive but take it into the dealer. Who trusts the dealer? im going to take mine to someone with a code reader.
buferd is offline   Reply With QuoteReply With Quote
Old 01-29-2008, 10:05 PM #3
Thumbs up Let me know...
Glad I'm not the only one... Let me know if you can, if you find anything out by using the code reader...
I saw a couple suggestions here and there that it is the Zero Point Calibration.... not positive though...
Old 01-30-2008, 08:19 PM #4
96dcmss 96dcmss is offline
96dcmss is an unknown quantity at this point
Good luck with a generic code reader......you'll end up at the dealer. Only Toyota scan tools can get manufacture specific code information, and as far as I know that is the only equipment you can use to calibrate the system.
If you don't trust your dealer, why not find one that you can trust?
2005 4Runner SR5 2WD, bone stock, hers
1996 Impala SS lightly modded, mine of course
1990 volvo 240, gets me where I'm going for little to no $$
http://memimage.cardomain.net/member...80_80_full.jpg
96dcmss is offline   Reply With QuoteReply With Quote
Old 02-10-2008, 12:25 AM #5
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
Re: Let me know...
download the tsb by searching "zero point calibration" and follow the instructions near the end of the tsb. I just did it today and the lights went away.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 02-10-2008, 01:20 AM #6
this is weard.my vsc track and vsc off lights have been on for over a week the other night i drove home from the store in drive 2 the lights went out and have not come bace on since. its been three days so far and no lights! they still come on when the ignition is turned on so i know they are still working.
buferd
Old 02-11-2008, 10:58 AM #7
retco retco is offline
retco is on a distinguished road
My VSC lights are on also, took it to a toyota dealer and they pluged it in to a code reader and NOTHING, gave NO codes and said i needed to bring it in to dig alittle deeper. It does not dammage anything to drive w/out VSC, but it bothers me.
retco is offline   Reply With QuoteReply With Quote
Old 02-11-2008, 11:53 AM #8
Like I posted earlier, before taking it to the dealer try doing the calibration yourself. If it doesnt work, then something may be wrong with the components itself.
2004 V8 LIMITED 4WD
Old 12-17-2010, 01:38 PM #9
EAX's Avatar
EAX EAX is offline
EAX is on a distinguished road
EAX EAX is offline
EAX's Avatar
Hello fellas,
I have the problem that originally coolvman83 posted where the lights come on ONLY WHEN THE VEHICLE IS COLD and GO OFF when you turn it off and back on and everything is fine. IT ONLY HAPPENS WHEN VEHICLE IS COLD.
I wouldn't think that would have something to do with the "Zero point calibration" but maybe a loose/malfunctioning sensor that starts working when the vehicle warms up.
Did anyone find a resolution on that? I don't think the "Zero point calibration" has anything to do with my problem(COLD start ONLY).
Thanks!
EAX is offline   Reply With QuoteReply With Quote
Old 01-13-2011, 03:57 PM #10
mabguru's Avatar
mabguru mabguru is offline
mabguru is on a distinguished road
mabguru's Avatar
Originally Posted by EAX View Post
Hello fellas,
Thanks!
Hello, I'm new to the forums and I have the same exact problem as the post above and the OP. The lights only come on when I'm starting the vehicle in the morning after a very cold night. Here in LA, it's only a handful of times a year.
Has anyone had any luck? I've searched all over the internet and can't find anything.
2003 4Runner Sport 2WD V6
mabguru is offline   Reply With QuoteReply With Quote
Old 01-24-2011, 10:59 AM #11
4Beast 4Beast is offline
4Beast is on a distinguished road
! just had the identical experience with my truck this am. It was very cold this morning (-4 when i woke up!) but they went off when I got to work and turned the engine off then on again. I am not terribly concerned, but try to have as few lights lit on my dash as possible!!
Gallivanting Grey 2003 4R V8 Sport 4X4, 255/75/17 Wrangler SAs, 3/2 lift (Bilstein 5100s, FJ springs, Daystar spacers), Running board delete
4Beast is offline   Reply With QuoteReply With Quote
Old 11-14-2011, 05:09 PM #12
ryannemeth ryannemeth is offline
ryannemeth is on a distinguished road
Has anyone found a cause or solution to the cold start VSC issues?
Thanks for any help!
Ryan
ryannemeth is offline   Reply With QuoteReply With Quote
Old 01-08-2013, 11:48 AM #13
JohnPips JohnPips is offline
JohnPips is on a distinguished road
VSC Lights & Check Engine Light
Last night as I was driving, both the VSC Lights and the check engine light came on at the same time. Does anyone know how they are connected?
JohnPips is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 11:05 AM #14
rjtoney rjtoney is offline
rjtoney is on a distinguished road
Any updates on this?
Woke up this morning it was 4 degrees, once I got to work the same lights came on my 06 v8 4runner.
rjtoney is offline   Reply With QuoteReply With Quote
VSC Trac, TRAC Off, CEL Rockets34Life 3rd gen T4Rs 2 05-17-2010 03:59 PM
Auxilliary Lights on 2003 4Runner rupren Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-05-2010 10:13 PM
4th Gen Toyota 4Runner Reviews Thai Comparisons & Reviews 49 12-10-2007 04:23 AM
TRAC OFF, VSC TRAC, ABS lights on mini_fly Problems & Warranty Issues 4 11-19-2004 09:57 AM
VSC TRAC lights feloniousQ Maintenance/Detailing 0 03-03-2004 09:30 PM
