Old 03-22-2011, 10:27 PM #16
MJ Philbin MJ Philbin is offline
MJ Philbin is on a distinguished road
I have had very similar issues with check engine lights. In the past, the check engine light would come on, and the code would only reveal a problem with one of the 02 sensors. After fixing that the last time, the traction control light wouldn't go away. Local guy was chalking it up to a wheel or abs sensor, which at this stage I refused to replace. My brother in law is a mercedes electronic specialist, and he borrowed my truck and came back within a couple hours with it fixed. No parts, and this was about 5K miles ago. He claims to have re-programmed a "yaw sensor" which evidently is something that tells the "rescue me" computer that the truck is not sitting level, or at risk of tipping over. I didn't realize that a part like that could be adjusted or repaired in any way. He didn't replace anything, though, and it's been perfect ever since. The traction control system does work now (think: Chicago winter), and life is good!
MJ Philbin is offline   Reply With QuoteReply With Quote
Old 03-23-2011, 04:51 PM #17
toyotagirl22 toyotagirl22 is offline
toyotagirl22 is on a distinguished road
Ok, so I have a 2001 4-Runner with 275000 miles and my TRAC OFF, VSC OFF, and CHECK ENGINE lights have been on for over a year. Scans have pulled no codes, gas mileage hasn't changed and still runs great. Light are just annoying!
toyotagirl22 is offline   Reply With QuoteReply With Quote
Old 04-15-2011, 12:22 AM #18
Beargrass2 Beargrass2 is offline
Beargrass2 is on a distinguished road
Check engine light and VSC off and Trac off lights on
Thanks forum guys! My 2004 4-Runner had the Check engine light and VSC off and Trac off lights on after a gas stop and wash. From the Forum I tightened the gas cap (it was not apparently loose) and after about the 4th start it went back to normal, no lights!
Beargrass2 is offline   Reply With QuoteReply With Quote
Old 04-17-2011, 02:54 PM #19
ludog ludog is offline
ludog is on a distinguished road
we have been having an issue with doing the 90L recall, zero point cali is needed everytime sometimes twice. weird we know we sent a product report in, this could be the problem too. at least you got a free cat out of it lol.
ludog is offline   Reply With QuoteReply With Quote
Old 05-10-2011, 12:48 PM #20
Flo4Run's Avatar
Flo4Run Flo4Run is offline
Flo4Run is an unknown quantity at this point
Flo4Run's Avatar
CEL, VSC Trac, Trac Off - start up shaking
Originally Posted by Sgt. Boz View Post
I have a good one here.
I have an 04 SR5 V6 w/ 134,000 miles on it. I started it up one day and it shook pretty good for about 30 seconds and then went away. the CEL and VSC/TRAC off lights came on and stayed on. I drove it to work, everything was fine. Started it after 8 hrs. same thing shake for 30 sec. then runs fine. Pulled codes and had a #6 cylinder miss-fire. Changed Plugs. She ran fine for 2 days and then the same thing started. pulled code again , same thing. Swapped #6 coil pack with #4. ran for 2 days problem returned. pulled code #4 miss-fire!!!! yaa problem solved!! not quite. Put #4 pack back on #4 and changed #6 coil pack with new. Ran fine last night. Started it up this morning engine shake again for 30 seconds and CEL blinked for a couple of seconds and then went out, engine drove fine. What the heck??? Same exact problem. I will pull code again once it stays on. What would cause the eninge to shake (like a cylinder isn't firing) for 30 seconds (give or take a couple) and then run fine. No noticable loss of power. gas cap tight, just passed emmisions. I am lost on this one. ANY help would be greatly appreciated. Oh, one more thing. when the CEL was cleared why didn't the VSC/TRAC off light go out? Those are the only light that won't go out. Then come on as soon as the vehicle moves. It stays out for as long as the engine is running and you haven't moved when you first start it up. PLEASE HELP!!!
Sgt Boz & Grosse14 what were you able to find out about your problems. I'm having the same issue now with an 04 SR5 V6 w/ 125K miles. Engine shakes for a while when i start it up, and sometimes I notice after driving a while rpms go down to 500 on idle. CEL reader reported cylinder 6 misfire and I replaced all six plugs, it was good for a while but now it's happening again. I'm thinking it could be a bad distributor cap. Your input would help a lot.
Flo4Run is offline   Reply With QuoteReply With Quote
Old 09-30-2011, 11:12 AM #21
junbug119 junbug119 is offline
junbug119 is on a distinguished road
Hello everyone,
I've had the check engine light, VSC, and TRAC light on for about a month now on my 03 4Runner with about 19,000 miles (It's my weekend vehicle and I take the train commuting to work ). Went to Autozone to get the codes read but they told me they don't offer that service anymore. Vehicle runs great and the gas mileage hasn't changed. I've tried the usual tightening the gas cap and resetting the computer. But, after driving for about 15 minutes, they all light up again. I did just read in some other forum that low brake fluid can also cause the lights to light up. I will have to check up on that once I get home from work. I'm really hoping there is something else I can do before I really have to take it to a mechanic.
junbug119 is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 01:04 PM #22
Liftproduction's Avatar
Liftproduction Liftproduction is offline
Liftproduction is on a distinguished road
Vsc , check engine, anti lock , low tire pressure
I had low tire light come on my 2005 4runner sport v8 4wheel drive. I did not take care of this right away, and it set off lights "vsc, anti lock brakes" . I solved it after proper air in all 5 tires including spare. The lights were still on, so disconnected battery waited 15 minutes, hooked battery up and all lights shut off.
Liftproduction is offline   Reply With QuoteReply With Quote
Old 11-13-2011, 09:26 PM #23
whitfam whitfam is offline
whitfam is on a distinguished road
I have the same exact issue with my 2004 4Runner Limited v6 4x4. Except now my heater does not work. Has anyone resolved their issue yet? Any help would be greatly appreciated.
whitfam is offline   Reply With QuoteReply With Quote
Old 11-13-2011, 09:26 PM #24
check engine
Old 12-02-2011, 12:12 PM #25
bk4runner bk4runner is offline
bk4runner is on a distinguished road
engine shake
had same problem except when it was done shaking it sounded like water rushing into the dash for like 5 seconds. turns out i had a head gasket and water pump gone bad , that week was a pain in the ass
bk4runner is offline   Reply With QuoteReply With Quote
Old 02-01-2012, 04:57 PM #26
Trail4Runner Trail4Runner is offline
Trail4Runner is on a distinguished road
VSC Light and CEL fix
I had the same issues CEL and VSC light came on at the same time.
Took it to Autozone and code came in as exhaust/catalytic convertor code.
Autozone guy suggested possible hole in exhaust system. My mechanic wanted me to spend $900 to replace cc. When we put the car on the lift it was hard to see but the gasket just before the cc was leaking. We changed the gaskets on both sides...CEL cleared VSC no longer illuminated.
total cost $100
Trail4Runner is offline   Reply With QuoteReply With Quote
Old 03-04-2012, 09:33 AM #27
AurelioDiez AurelioDiez is offline
AurelioDiez is on a distinguished road
Smile VSC off, TRAC off and check engine light on!
Had a similar problem with my 2005 4 Runner. I fixed it by cleaning the battery poles from a greenish powder.
AurelioDiez is offline   Reply With QuoteReply With Quote
Old 04-11-2012, 10:01 AM #28
azurez14 azurez14 is offline
azurez14 is on a distinguished road
Smile 03 4runner CEL VSC TRAC OFF
Actron code reader said it was passenger side 0xygen sensor downstream(the one after the catalytic converter). I replaced it with OEM Denso and cleared the code. Two days later CEL and VSC TRAC OFF lights came back on. Checked with reader again and code came back as the same Oxygen sensor downstream on passenger side even though it was already replaced with new one. Any ideas anyone?
azurez14 is offline   Reply With QuoteReply With Quote
Old 04-13-2012, 11:37 AM #29
4run4BuxandTako 4run4BuxandTako is offline
4run4BuxandTako is on a distinguished road
That sounds like my problem...We have replaced all O2 sensors with factory parts now, at first we used after market (which I have heard that can trick the Codes to pull). Also new battery, MAF sensor...and my VSC Trac, VSC Off, and check engine lights are still on!! They are haunting me. I have noticed the exhaust has a bit of an eggy smell to it occasionally...gaskets sound like my next step ?
4run4BuxandTako is offline   Reply With QuoteReply With Quote
Old 12-17-2012, 05:00 PM #30
WJB75 WJB75 is offline
WJB75 is on a distinguished road
VCS off / track and check engine light on
Hey this just happened to me also. So; as many rational people do I scanned through my owner’s manual and as usual it suggested that "I SHOULD DRIVE STRAIGHT TO A DEALER!" "F that" so I googled my issue and found this sight after reading through a dozen of post ranging from bad cat's to lose gas caps I ventured out to my 2002 SR5 LTD 4WD and started the rounds as follows. I tightened my gas cap ...nope. Then I checked my abs fuse box...nope. I checked fluid levels all good...nope. Then I said what the Hey and opened up the old air cleaner box .....Guess what folks some damn rodent had stored at least 100 acorns in there via my air induction port on the passenger side wheel well...lol. Following a quick WAP VAC maneuver the lights went out. So, add this one to the possible fixes regarding warning lights.
WJB75 is offline   Reply With QuoteReply With Quote
