Old 10-06-2018, 12:45 PM #61
gigem891 gigem891 is offline
gigem891 is on a distinguished road
My TRAC/VSC issue resolved
Wife’s 2001 Limited 2wd, 253k mi. now, has had regular TRAC/VSC Engine lights on issue for past couple of years. Pretty much just cleared codes with code reader from time-to-time, but they always came back within a day or two. Just returned from an out of state trip for wife’s mother’s funeral, and some of the worst electrical problems all along the way. Had battery replaced under warranty, and replaced OEM alternator which finally died on the trip. After replacing recharged warranty battery following new alternator install, in Autozone parking lot no doubt with wife, 2 kids, dog, and cat in tow, all dash lights off and haven’t returned in 4 days now. Me thinks faulty alternator was somehow tripping the PCM to throw the TRAC/VSC Engine lights. Will report back if they come back on.
2001 Limited, 2wd, 275k mi., 2nd owner, Texas vehicle, stock.
gigem891 is offline   Reply With QuoteReply With Quote
Old 12-08-2018, 09:15 AM #62
jhproctor jhproctor is offline
jhproctor is on a distinguished road
VCS warning and tire pressure warning lights on solutions
VSC, track, engine, and tire pressure warning lights all on for recently-purchased 2006 limited edition 4runner.
Filling spare tire to 32 psi fixed the tire pressure light.
Disconnecting car battery for thirty minutes corrected the other warning lights.
Thanks for the advice!
jhproctor is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 09:23 AM #63
ebhudgens's Avatar
ebhudgens ebhudgens is offline
ebhudgens is on a distinguished road
ebhudgens's Avatar
Similar problem here. 2018 4Runner with 18,000 miles. Six weeks while driving on the interstate close to Memphis the check engine and trac off lights suddenly came on and the vehicle went into limp mode. After getting towed to a dealer in Memphis it was determined that water had gotten into the air injector system and all injectors and the pump had to be replaced. It was covered under warranty but I was out a hotel stay while it was repaired. This week while driving close to Knoxville the same thing happened. Got a tow to a Knoxville dealer and this time it was the emission valves and some other parts. Now I'm out another nights stay in a hotel plus overages on the tow. So far I'm out about $500 for warranty work on a new vehicle, and Toyota had invested over $4,500 in parts plus shop labor for the repairs. I plan to take this up with the dealer where I purchased the vehicle and see about some help on my expenses plus a possible extension of the warranty on these systems. We've had six Toyotas over the years with no major problems and now this new one is nothing but problems.
2018 4Runner. Ham radios installed - Icom IC7000 plus two Yaesu FTM400s. Two VHF/UHF antennas on rear door clips and Tarheel HF antenna on frame bracket.
ebhudgens is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 05:13 PM #64
Shankology Shankology is offline
Shankology is on a distinguished road
VSC off, trac off, check engine on
I had the same lights come on after I let my parents borrow my 02 4runner. At first I thought it was a loose gas cap. But the lights stayed on for a few days so I took it to my local firestone to get it scanned. They told me it was likely a faulty O2 sensor. So I purchased a new one and changed it out (a quick and cheap repair) and my lights never came on again.
Shankology is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 11:09 AM #65
DevRose12 DevRose12 is offline
Real Name: Devin
DevRose12 is on a distinguished road
Real Name: Devin
vsc trac vsc off check engine 4runner
Have a 2005 Toyota 4runner Sport. I have been dealing with this issue for months now... No solution as of now. I bought a new gas cap and ensure the gas tank is sealed. I have unplugged the battery and it did make the lights away temporarily... but then 1-2 days later its right back on. I haven't changed the O2 sensor, maybe that is the answer? Everything drives fine, no issues at all. Just annoying and scary for others when they drive my car.
DevRose12 is offline   Reply With QuoteReply With Quote
Old 06-29-2019, 10:43 PM #66
wbailey wbailey is offline
wbailey is on a distinguished road
I got the same model. If youre getting a p0420 code it's likely an O2 sensor, you can get spark plug non-foulers and install them on the sensor to see if the code clears, then you know for sure before buying a new sensor. If you live in a place where they salt the roads you may have an exhaust leak so check your flanges. I bought mine in the northeast 3 years ago and recently heard a rattling near the back only to discover the tailpipe had rusted clean through just after the muffler, oh well who needs it.
wbailey is offline   Reply With QuoteReply With Quote
Old 08-03-2019, 02:02 PM #67
btownie btownie is offline
btownie is on a distinguished road
2004 SR5 here same issue.
Cleared all the codes.
The trac lights came back on immediately but the check engine light stayed off for a couple days before coming back on.
I'm hoping the block isnt cracked but thats for another post.
btownie is offline   Reply With QuoteReply With Quote
Old 09-16-2019, 07:51 PM #68
bkvollmer bkvollmer is offline
bkvollmer is on a distinguished road
Originally Posted by Flo4Run View Post
Sgt Boz & Grosse14 what were you able to find out about your problems. I'm having the same issue now with an 04 SR5 V6 w/ 125K miles. Engine shakes for a while when i start it up, and sometimes I notice after driving a while rpms go down to 500 on idle. CEL reader reported cylinder 6 misfire and I replaced all six plugs, it was good for a while but now it's happening again. I'm thinking it could be a bad distributor cap. Your input would help a lot.
My ‘04’ t4r Ltd v8 having this problem. Will try the gas cap deal, but my mechanic told me I have a cracked manifold where it attaches to the Head causing quite a “ticking” sound. Typical problem with the v8, maybe v6 also. That can create an exhaust leak and trip a Cel if it progresses and get bad enough. I might be there now. 😡
bkvollmer is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 11:03 AM #69
Update on my end.
I (carefully) cleaned the rear ABS sensors and reinstalled them.
The VSC and trac lights are no longer throwing a code!
They do come on automatically when the check engine light comes on fyi.
Old 01-02-2020, 08:33 PM #70
nvestor88 nvestor88 is offline
Real Name: j
nvestor88 is on a distinguished road
Real Name: j
Having similar issue. There would be a series of beeps, Then three lights come on, on my 03. After adjusting the cap, they go off. The old gas cap looked pretty worn. After today, they came on and stayed on. Tried playing with the cap, same thing. Changed it out for a new one. The lights are still on.
nvestor88 is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 12:03 PM #71
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
You need to pull the codes to see what the computer says is causing it. God to the local auto parts store and have them get the codes, or get one of these from Amazon: Bluetooth OBD Scanner $11
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Yokohama (stock) Geolandar G015; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 02:46 PM #72
Eliasj Eliasj is offline
Eliasj is on a distinguished road
Hi All,
I have a 2011 4Runner with 70k miles on it. Automatic transmission. the car feels like it doesn’t positively shift into drive, and the drive gear indicator does not illuminate after you shift into drive from park. drives fine though....? Anyone have any suggestions? It’s doesn’t do this all the time. Only when the cars been sitting for a day. Once I drive it it goes away. Could it be a rusting shifting cable?
Eliasj is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 09:43 AM #73
syncretic.buffalo syncretic.buffalo is offline
syncretic.buffalo is on a distinguished road
Bumping an old thread
Hi All -
bumping an old thread here, hoping for some clarification.
2007 4.7 4wd here, 191k on the clock.
Been having some rear driveshaft issues lately, planning on dropping the truck off to have them grease the spline of the DS first before we swap in a new one if it doesn't work. I'm also 99% sure my manifold is cracked, i have the bad sulfer smell as well as the tick on startup.
This morning when I turned the truck on for the first time EVER i had the CEL, VSC, and TRAC OFF lights on. Obviously immediately panicked - haven't had time to check the codes yet..though I did check the gas cap and it seemed loose..
Question: would a cracked manifold throw codes, and if so - is it possible to do some kind of a bypass?
I've already had to bypass the AIP system with a fix from one of the members here on the forum.
Cheers
syncretic.buffalo is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 10:30 AM #74
TeryT's Avatar
TeryT's Avatar
Originally Posted by syncretic.buffalo View Post
Hi All -
Cheers
I haven't had a cracked manifold but have some experience with the "Christmas tree lights." I would say that a cracked manifold might throw the codes as the sensors could be picking up a different mixture than they want to see. Just my opinion though. (My experience was when the cats went bad and I replaced them. I tried various things, but in the end replacing the cats made the lights go away.)
Old 07-07-2020, 10:37 AM #75
yeah - we'll see what happens. I just wasn't sure if replacing the o2 sensor was in the realm of possibility as a solution.
i'll have to run the codes first obviously - hopefully it's a loose gas cap and that's it...
will report back
