Old 04-03-2003, 09:00 PM #1
Good Times's Avatar
Good Times Good Times is offline
Good Times is on a distinguished road
Good Times's Avatar
my 03 4runner had an evap leak P0442
Just wanted to let ya know that my 4runner just had a small evap leak problem. Code P0442.
I know this is an isolated problem but I just wanted to give ya guys a heads up for those who might experience the same problem (hope not).
Symptom:
Check Engine Light
OBDII Code: P0442
Error Code: Evap Leak (small)
Problem: Leak found in intake plenum area for the fuel. Not sure exactly where as they were vague on their description over the phone. When the part comes in, I'll have the part number so I'll know exactly what the problem was. I recall them telling me some valve problem... not sure... blah...
Like I said, this is probably an isolated problem and figure most everyone will not experience this. If ya do, atleast you have a general idea what the problem can be...
Lance
Good Times is offline   Reply With QuoteReply With Quote
Old 05-30-2009, 11:47 PM #2
A/V1's Avatar
A/V1 A/V1 is offline
Real Name: Brad
A/V1 is on a distinguished road
A/V1's Avatar
Real Name: Brad
Hey Lance. Well, it looks like it's been quite some time since this happened to you. Unfortunately, it just happened to me with 105K on the odometer. Do you remember any specifics on the fix? What parts etc needed to be repaired or replaced? I've got the V8.
Thanks in advance! MUCHO!
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
A/V1 is offline   Reply With QuoteReply With Quote
Old 05-31-2009, 09:49 AM #3
toto toto is offline
toto is on a distinguished road
A loose, missing, or poorly-sealing gas cap is a common cause of P044x or P045x. Evaporative emissions (a/k/a fuel vapors) from the gas tank are very tightly monitored and controlled, so the gas cap seal is very important.
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Old 06-02-2009, 02:51 AM #4
A/V1's Avatar
Real Name: Brad
A/V1's Avatar
Real Name: Brad
Yeah, unfortunately, I'd already checked the gas cap and no change. My error code is the same that Lance was getting - P0442. Evap Leak (small).
My OBDII code reader is actually a decent one, and I can clear the code, but it comes back immediately.
I don't know if Good Times is on here much any more, but it'd sure be nice to know what exactly the fix was. Anyway...
Support our troops!
Old 07-25-2009, 10:01 PM #5
a77boy a77boy is offline
a77boy is an unknown quantity at this point
Yeah, my 03 V8 is getting the same code. About 6 months ago my fuel pump went out and I dropped the tank to replace it, Something tells me that my evap leak may be somewhere within the myriad of hoses that I disconnected and reconnected while doing the job,, ughhh.
a77boy is offline   Reply With QuoteReply With Quote
Old 07-27-2009, 01:14 PM #6
A/V1's Avatar
Real Name: Brad
A/V1's Avatar
Real Name: Brad
Before you go spending any money, as was mentioned previously, check your gas cap. It actually didn't go right away on mine - even though I cleared the code with my code reader. I just basicly thought "screw it, I'll get to it when I get to it". The light stayed on a couple more weeks. But the next thing I knew, the light went out and hasn't come back on. Good luck.
Support our troops!
Old 07-27-2009, 01:56 PM #7
A/V1 Thanks for the insight,, Gonna look into that new gas cap. By the way,, you have any pics of the mods you done? Id like to check out that map light redo.
Old 11-30-2010, 02:18 PM #8
Jayzero911's Avatar
Jayzero911 Jayzero911 is offline
Jayzero911 is on a distinguished road
Jayzero911's Avatar
I know this is a 3-7 year old thread but this just happen to my 01 V6 and my traction control is off too(can't turn it back on with the button and its not disconnected)
Jayzero911 is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 07:47 PM #9
scomeau scomeau is offline
scomeau is on a distinguished road
P0442, p0455, p0456
I purchased a used 2004 4runner after my 1999 was totaled. It came with a full tank of gas. The very first fill up I could not remove the gas cap. http://www.tamemymind.com/blog/image...all-yellow.gif
Couldn't turn it at all left or right. Absolutely stuck. Left the gas station and got my 24" pliers to twist off the cap. Not easy. All seamed fine. Put the cap on went to fill up, pilers in hand. Didn't need the pliers again until after 3 fills I took them out of the runner and left them in the garage. 4 th fill up, again the cap would not budge. Got home opened it with the pliers. Broke off the gas door latch keeper. http://www.mysmiley.net/imgs/smile/c...nfused0067.gif
Broke the gas cap clicker. Made a new latch keeper out of aluminum. works great. The gas cap just sits in the opening. After two months of driving, MIL ON, VSC off. Because the MIL is on the system automatically disables the VSC features, giving the additional error lights.
The shop manual has these three codes grouped together. P0442, P0455, P0456. They are in order; Small leak, Large leak, Very small leak.
Fuel tank cap is mentioned twice as the trouble area. Then there is the canister or its lines or the tank itself leaks. Cleared the codes.
Going for a new gas cap this weekend.
scomeau is offline   Reply With QuoteReply With Quote
Old 05-30-2011, 10:08 AM #10
Rickrunner Rickrunner is offline
Rickrunner is on a distinguished road
2001 4runner
Jayzero. was wondering if you have had the vsc off and vsc trac lights come on?
I don't have one of thoes fancy dancer computers but took it to the local autozone to have them hook theirs up. It came up with the po442 code. Wondering if the two are related.
Thanks in advance.
Rick
Rickrunner is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 01:25 PM #11
suprafaye's Avatar
suprafaye suprafaye is offline
suprafaye is on a distinguished road
suprafaye's Avatar
Thanks in advance.
Rick
I will chime in here!
Yes - the VSC and TRAC lights come on in addition to the MIL in many cases. Once you fix the p0442, then you can reset everything and the VSC and TRAC lights will go off as well.
suprafaye is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 10:58 PM #12
Jgomez88 Jgomez88 is offline
Jgomez88 is on a distinguished road
05 4Runner charcoal canister wiring harness
Hey guys, 2005 4Runner sport. getting tons of codes, I replaced my charcoal canister about a month ago, light came back on instantly. Tons of codes, been trying to figure it out. Turns out the wiring harness that plugs into the canister pump module on the charcoal canister broke off some pins and are now stuck inside the wiring harness. Does anyone know part numbers for the wiring harness? Thanks
Jgomez88 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 11:49 PM #13
joelhorton joelhorton is offline
joelhorton is on a distinguished road
I pulled a P0440, then a P0442, I ended up replacing the MAF sensor and the vent solenoid. The CEL turned off after that.
joelhorton is offline   Reply With QuoteReply With Quote
Old 06-29-2022, 06:27 PM #14
jack715 jack715 is offline
Real Name: jack
jack715 is on a distinguished road
Real Name: jack
Hey guys,
Please be-a-where, that if your gas cap is REALLY the problem then of the 8 or so manufacturers of gas caps probably won's fix your problems for long. I know, I tried 3 different caps. None of them consistently worked. The parts stores took them back with no questions. One old salt parts guy said the aftermarket caps have a real problem sealing on 4runners. I was ding donned if I would pay the outrageous price of an OEM cap. After some research I replaced the o-ring on my original cap and it worked fine. Later I happened to talk to a garage mechanic of 40+ years and he said the OEM cap fixes it but the o-ring is the problem after 16+ years.
About 6 months later the leak came back. This time I cut a sticky backed flat rubber type gasket and carefully fit it to the older gasket on the old cap. Has worked fine for last 2 years.
Good Luck if you have this problem. The gas cap is only one of several causes of a "very small leak".
jack715 is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 07:22 PM #15
tlp123 tlp123 is offline
tlp123 is on a distinguished road
Memory lane.
Lots of good info in this thread, and brings back moments in my 2002 4Runners
EVAP SYS/MIL history of hell. Not really....I digress ;)
@ 278,000MI, I got a P0446 & P0440. Replaced the gas gap, reset/cleared ECU.
Light came back on @ 100,000MI. Ran all tests I was able to out of the manual. Still very intermittent.
I lived with this over 2 years and because the fix was elusive, I would just let the light stay on till' right before state inspection. I would clear the codes, and drive it 100 to 500MI so all sensors would set. In my state (TX) you are allowed one and only one non continuous sensor that is not ready at test for emissions for vehicles newer than 2001. This is for gasoline engines. Diesel engines have a different restriction. Can't remember it exactly at the moment.
This year MIL comes back every 200-300MI consistenyly with P0440 & P0446.
CAT and EVAP will never set after clearing codes. No check engine light immediately after reset, but EVAP and CAT IM's never ready. Will not pass emissions with 2 sensors not ready.
After reading through diagnostic tests and doing all those I could do myself, I just said the hell with it and replaced the EVAP cannister ASSY with a new Toyota OEM unit.
I drive 90 miles round trip work and back 4 days a week. It took 447 MI for the EVAP IM to ready. But this time all 7 sensors were ready. Passed emissions state inspection.
Blimey!!
That took care of it. I just got lucky.
tlp123 is offline   Reply With QuoteReply With Quote
Generations of 4runners dirk diggler 4th Gen T4Rs 28 12-25-2023 04:21 PM
Advice on a 1999 4x4 4Runner - high miles Kimm 3rd gen T4Rs 29 10-21-2020 12:11 PM
Frustrated Vibes!! last chance for 4runner buckz6319 Classic T4Rs 0 03-29-2009 08:10 PM
2005 Toyota 4Runner fluid leak? rgcary General Discussions 0 09-17-2008 12:36 PM
4th Gen Toyota 4Runner Reviews Thai Comparisons & Reviews 49 12-10-2007 04:23 AM
