Old 11-08-2021, 11:55 AM #31
4runn99 4runn99 is offline
4runn99 is on a distinguished road
My 99 limited code is missing cyl 3. I cannot confirm location of vacuum lines. I did find and replaced a cracked large line at top above air filter. Mine is not ruff running any more at cold start after using High Mileage Techron fuel additive, but still misses at light and some accelerating.
It maybe a fuel injector.
4runn99 is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 12:14 PM #32
spartacus's Avatar
spartacus's Avatar
Check the coil boots also swap the #3 coil with any of the other two and see if the misfire jumps. If the plugs, wires, ignition coils are good then replace the injector at 3.
How to use a usb hard drive for music poolzer 5th gen T4Rs 52 02-16-2022 06:32 PM
1995 4runner idle problem jackiemc08 Classic T4Rs 2 02-17-2012 03:09 PM
intermittent rough idle doug2004toyota 4th Gen T4Rs 3 12-19-2008 08:53 PM
rough idle 87 T4R kerry Maintenance/Detailing 3 12-01-2008 04:39 PM
4WD ignorance can cause expensive damage Thai Off-Roading 0 12-09-2003 08:42 AM
