Thread Tools Rating: Thread Rating: 3 votes, 2.67 average. Display Modes
Old 08-07-2004, 09:27 PM #61
ToolmanJohn ToolmanJohn is offline
ToolmanJohn is on a distinguished road
Just the front
I don't know if both or just one was warped slightly. They turned both front rotors. It was covered under warranty. I looked at he rotors and they took a very light skim cut off the outer surface that I can see through the wheel. Probably about .020".
2003 4runner V6 Limited 4x4 - A good ten years.
4 out of 5 dentists recommend Trident to their patients who chew gum, the 5th dentist recommends chewing a cup of pure cane sugar before bedtime. Don't go to that dentist!!!
ToolmanJohn is offline   Reply With QuoteReply With Quote
Old 08-07-2004, 10:36 PM #62
Kanab Kanab is offline
Kanab is on a distinguished road
Re: Re: Re: Around 13,000 miles
Originally posted by ToolmanJohn
Yes, I did use a torque wrench at 7800 miles to reinstall the wheels when I rotated them. The problem didn't surface until a few months ago, around 10,000 miles. And I tightened in a torque distributing pattern also.
John I'm sure you use an extension on your torque wrench. Did you compensate for torque multiplication by the extension? If not you over torqued the wheels. That's why dealers use the torque sticks, you can't over torque the wheels with a torque stick. If this is what happened you will continue to warp your rotors when you rotate in the future. Hope this helps.
2004 4runner Sport V8 AWD Titanium
2003 350Z Touring Chrome
Kanab is offline   Reply With QuoteReply With Quote
Old 08-08-2004, 09:00 AM #63
Re: Re: Re: Re: Around 13,000 miles
NO extension bar EVER for installing any kind of nut or bolt. Especially on a car. It's just not neccessary. Extensions are for removing the nuts( if neccessary). I have a very nice 1/2 inch drive torque wrench, also I have 6 sided impact drive sockets too (haven't used the impact wrench in years though, it's worn out). My wrench has a torque range of 10 to 150 ft-lbs . The 4runner manual states that the lug nuts should be tightened to a torque of 83 ft-lbs so that's what they got. It's accurate, calibrated every two years, since I don't use it often.
I don't know what a "torque stick" is. Never heard of it. Maybe you are trying to describe a beam-type torque wrnech?
Also for those interested, this website is hilarious. A real "universal" torque wrench LOL.
http://www.sheldonbrown.com/tork-grip.html
Sulfur (aka. Rotten Egg) Smell on '03 4Runners-torque-wrench-jpg
Old 08-08-2004, 09:01 AM #64
Wrong thread I know
The torque for wheel nuts.
Sulfur (aka. Rotten Egg) Smell on '03 4Runners-torque-requirements-jpg
Old 08-08-2004, 10:38 PM #65
Sorry John if that wasn't it then I have no idea why they warped. Maybe you just got a bad rotor?? Sounds like you know what you are doing so it wasn't pilot error. Hope it doesn't happen again. The torque sticks are extensions that can be used with a impact wrench, they are set to a maximum torque setting when they are made so a tech can use a impact wrench when they install your wheels with no fear of over torquing your wheels. Dealers use them to eliminate the potential pilot errors that could happen.
Old 08-11-2004, 09:42 PM #66
slowginjoe's Avatar
slowginjoe slowginjoe is offline
slowginjoe is on a distinguished road
slowginjoe's Avatar
Well I brought my 4Runner in this morning for a 15k maintenance and the sulfur tsb warranty work. At 5pm the service advisor calls and says everything is done except after reprogramming the ecu the yaw sensor needed to be reprogrammed and they can't figure out how to do it. They'd flash it and then drive around and the vsc light comes right back on due to the yaw sensor. Now I need to leave my truck there overnight so they can call Toyota Tech Line in the morning to figure out how to program it and make it stick. Now I'm stuck driving the Corolla rental! Anyone had this problem while getting the sulfur tsb?
'03 Limited V8 4wd
Nav, X-Reas
Titanium
slowginjoe is offline   Reply With QuoteReply With Quote
Old 08-11-2004, 10:12 PM #67
greasefingers's Avatar
greasefingers greasefingers is offline
greasefingers is on a distinguished road
Exactly, the oil companies will not change because of our vehicle. Toyota should do something about it. I can never lower my rear hatch window. It smells every day. I took it to the dealer and they said they could do nothing about it. They told me to use BP gas, due to it’s low sulfur content. I live in NJ and typically use Exxon/Mobile petrol.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
greasefingers is offline   Reply With QuoteReply With Quote
Old 08-12-2004, 01:17 PM #68
slowginjoe's Avatar
slowginjoe's Avatar
Originally posted by 4route
i haven't experienced any loss of power or performance at all. only difference was the smell of a new weld.
Was the smell gone immediately after the service was done or did it take a couple of trips? I mean, did you rev the engine hard after getting it back from service to check if the smell was gone? I just got mine back from having this fixed and with the back window down and throttling hard, I still smelled the sulfur. Just wondering if I should take it back or wait a couple days to see if it goes away...
'03 Limited V8 4wd
Nav, X-Reas
Titanium
Old 08-12-2004, 03:42 PM #69
I changed gas stations and mine started to smell, notice it when I get home and pull into the garage. Kinda like it
Old 08-12-2004, 03:52 PM #70
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
Well i have some bad news. The smell has come back in full force. The TSB worked for about 2 weeks.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 08-20-2004, 07:29 PM #71
SilverSurfer SilverSurfer is offline
SilverSurfer is an unknown quantity at this point
I use California fuel and with the rear window down, my 4Runner can knock you out with the sulfer smell, it's THAT bad.
SilverSurfer is offline   Reply With QuoteReply With Quote
Old 09-03-2004, 08:01 AM #72
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Here is the new TSB for the Sulfur smell:
http://www.toyota-4runner.org/attach...=&postid=31585
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 09-15-2004, 11:32 PM #73
Jarbarian Jarbarian is offline
Jarbarian is an unknown quantity at this point
http://www.toyota-4runner.org/showth...&threadid=5682
Jarbarian is offline   Reply With QuoteReply With Quote
Old 09-15-2004, 11:33 PM #74
Originally posted by ToyotaDoodz
Mine was gone immediately after the fix and never came back. I looked underneath and you can clearly see two new cat converters. If you didn't get those, you didn't get the fix. Reprogramming the ECM/ECU is worthless without the new cats.
You WILL get a little smell when your cat like first thing in the morning, but it quickly goes away. I only notice it backing out of the driveway with the windows down. I also can detect what I'd call normal unleaded gas stink if I really get on the gas, but it's not even close to what it was before the fix and not a sulfur odor, just exhaust fumes.
PS, all the above is only when the back window is down.I never did smell it with the windows up.
Same here! I have new the cats and the ecu reprogramming done and NO SULFER SMELL!!! WOO WOO!
Old 10-01-2004, 04:17 PM #75
4runnerman's Avatar
4runnerman 4runnerman is offline
4runnerman is an unknown quantity at this point
4runnerman's Avatar
hi
Its my first post, and you guys guess why I came looking for a forum...
The rotten egg smell....
quick question, I did get the TSB and faxed it over to the dealer so hopefully i could take it in for a fix, because it is so embarrassing when i hit the gas... try explaining toyota's fawk up to bunch of kids before soccer practice....
so does tsb instruct to change the cats? what does it exactly tell them to do???
I took the car in twice and they turned me back with a pad on the shoulder, saying it's the gas... everyone else fawkin drives cars, how come im the only one complaining....
4runnerman is offline   Reply With QuoteReply With Quote
Rotten egg smell. Does it go away??? sharp4runr 4th Gen T4Rs 34 05-25-2012 04:43 PM
Rotten Egg smell BlueBelt 5th gen T4Rs 15 07-27-2010 10:26 PM
Rotten Egg Smell??? yobeez 5th gen T4Rs 13 04-14-2010 03:25 PM
Air filter restriction causes sulfur smell?? Fro-Runner Problems & Warranty Issues 17 09-29-2006 09:46 AM
sulfur smell stinky1 Problems & Warranty Issues 1 10-22-2003 08:07 PM
