Keep in mind that in Auto mode, the temperature setting is not the temp of the air coming out, but the temp you want it to be inside the car. It's just like the thermostat in your house. If you set it to 65 but it's colder than 65 inside the car, then it will throw out heat in order to get up to 65.
The A/C light will be on all the time (unless you turn it off), and the system will use it as a dehumidifier even if it's pumping out warm air. The compressor can run as long as it's above freezing outside.
2006 Limited V8 4x4, Shadow Mica/Stone
