Originally posted by lnabbster
Thanks for the reply- it won't unlock from the inside. I traced the cable from the inside door lock to the actuator and tried to pull on the actuator- but that wouldn't work either. I'm thinking the actuator is maybe broken on the inside or the lock/hinge is stuck. Not sure. wondering if I can get the actuator out of the door while is stuck shut?
Look at the end of the door. There is a set screw which holds the lock cylinder in place. Loosen or remove the set screw, put the key in the lock and wiggle it until the lock cylinder comes out. Release the cables from the inside handle/lock assembly, remove the single bolt which holds the lower rear window guide and remove the guide. Remove the three phillips head screws that hold the latch and the actuator box, and remove the box through the hole in the door.
